Leveling Jacks
06-15-2006, 01:19
Leveling Jacks
I am looking for some help with my 83 PT-35 leveling jack problem.
When I engage the leveling master switch the entire electrical system goes dead. The engine stops and the jacks won't work. Does anyone have any suggestions on where to start looking for the problem. Jim Ellioitt, 83-PT35 |
06-15-2006, 08:06
Leveling Jacks
If they are HWH jacks call Frank there in Customer Service. I don't
recall their number but you can find them by Googling the web. He was pretty helpful on a problem I had Lee Davis 95 BMC --- In WanderlodgeForum@yahoogroups.com, "jaelou2" > > I am looking for some help with my 83 PT-35 leveling jack problem. > When I engage the leveling master switch the entire electrical system > goes dead. The engine stops and the jacks won't work. Does anyone > have any suggestions on where to start looking for the problem. > > Jim Ellioitt, 83-PT35 > |
06-15-2006, 08:52
Leveling Jacks
--- In WanderlodgeForum@yahoogroups.com, "Lee Davis"
wrote: > Frank's number is 800 321 3494. Unfortunately I have talked to him a lot lately. Scott Forman 82 FC35RB Memphis > If they are HWH jacks call Frank there in Customer Service. I don't > recall their number but you can find them by Googling the web. > > He was pretty helpful on a problem I had > > Lee Davis > 95 BMC > > --- In WanderlodgeForum@yahoogroups.com, "jaelou2" > > > > I am looking for some help with my 83 PT-35 leveling jack problem. > > When I engage the leveling master switch the entire electrical system > > goes dead. The engine stops and the jacks won't work. Does anyone > > have any suggestions on where to start looking for the problem. > > > > Jim Ellioitt, 83-PT35 > > > |
02-28-2007, 06:16
Leveling Jacks
When I tried using the Level Master system I got alarms on 3 out of 4
of the jacks. Does the alarm mean the jack has not swung down far enough or too far? Is the spring supposed to pull the jack down as it begins to extend? |
02-28-2007, 06:57
Leveling Jacks
Keith,
If you have the HWH Levelers I'd give them a call http://www.hwh.com/ . Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Keith Strehle wrote: > When I tried using the Level Master system I got alarms on 3 out of 4 > of the jacks. Does the alarm mean the jack has not swung down far > enough or too far? Is the spring supposed to pull the jack down as it > begins to extend? > > |
02-28-2007, 13:56
Leveling Jacks
Keith,
On my bus I have to have the bags aired up before dropping the leveling jacks. Then dump the air bags. Then when preparing to leave I have to air up the air bags before lifting the jacks to horizontal. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Keith Strehle To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, February 28, 2007 1:16 PM Subject: [WanderlodgeForum] Leveling Jacks When I tried using the Level Master system I got alarms on 3 out of 4 of the jacks. Does the alarm mean the jack has not swung down far enough or too far? Is the spring supposed to pull the jack down as it begins to extend? ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.412 / Virus Database: 268.18.3/697 - Release Date: 2/22/2007 [Non-text portions of this message have been removed] |
03-01-2007, 02:03
Leveling Jacks
Jim,
I had this problem and found the solenoid in the front wheel well, passenger side to be the culprit. I think it's one of those continuous duty type deals (3 posts). Anyway, Napa can match it up for you if that's what you need. You'll find two under there. Like I said, one in the wheel well and another attached directly to the leveler motor. Ron, No. California 85PT36 --- In WanderlodgeForum@yahoogroups.com, "jaelou2" > > I am looking for some help with my 83 PT-35 leveling jack problem. > When I engage the leveling master switch the entire electrical system > goes dead. The engine stops and the jacks won't work. Does anyone > have any suggestions on where to start looking for the problem. > > Jim Ellioitt, 83-PT35 > |
