Bulk oil system
11-03-2008, 07:44
Bulk oil system
I looked in the little bit of documentation I have and searched this
forum on bulk oil.
Can someone please explain how the bulk oil system works and where the
tank (and fill) are located?
Thanks,
GPSGary
1984FC35
11-03-2008, 08:41
Bulk oil system
Gary,
On my coach88 WLWL the bulk oil tank in at the rear curbside Starboard of the coach. It is a switchable pressurized tank that has a dispenser with a hand held wand. it has a meter that keeps track of oil dispersed. Great option.
Jim Riordan
Sent: Monday, November 3, 2008 2:44:40 PM
Subject: [WanderlodgeForum] Bulk oil system
forum on bulk oil.
Thanks,
GPSGary
1984FC35
11-03-2008, 08:46
Bulk oil system
What is the purpose of that?
Dorn Hetzel
77FC35
Hogansville, GA
On Mon, Nov 3, 2008 at 3:41 PM, jim riordan <"jqrjr@yahoo.com"> wrote:
Gary,
Jim Riordan
forum on bulk oil.
Thanks,
GPSGary
1984FC35
11-03-2008, 08:48
Bulk oil system
to fill the engine oil eaisly ant to have oil onboard, very nice option!
Jim RIordan
Dorn Hetzel
77FC35
Hogansville, GA
Gary,
Jim Riordan
forum on bulk oil.
Thanks,
GPSGary
1984FC35
11-03-2008, 09:01
Bulk oil system
On my 83 Fc the tank is in the LP Compartment just forward of the door.
My understanding of the the system is this.
When you need to fill engine oil you flip a lever on the tank that will put pressure from the air system into the oil tank.
Then you go to the engine and dial up how much oil you wish to add, then squeeze the trigger and it will dispense that much oil though the hand wand.
I am very new at this, but that is the way I understand it to work
thx
John
Sent: Monday, November 03, 2008 11:44
forum on bulk oil.
Thanks,
GPSGary
1984FC35
No virus found in this outgoing message
Checked by PC Tools AntiVirus (4.0.0.26 - 10.100.050).
http://www.pctools.com/free-antivirus/
11-03-2008, 09:51
Bulk oil system
Thanks,
That's what I needed. Perfect except there is no lever on the tank.
Regards,
GPSGary
door.
> thx
> John
> From: hippieforever3
this
> forum on bulk oil.
where the
> Thanks,
> GPSGary
> 1984FC35
11-03-2008, 10:27
Bulk oil system
It's an electric toggle switch..and I think it's there in the engine. It might even have an indicator light on the switch panel. You need to have the engine off..but have plenty of air pressure built up at the time.
Date: Mon, 3 Nov 2008 21:51:11 +0000
Subject: [WanderlodgeForum] Re: Bulk oil system
Thanks,
Regards,
GPSGary
door.
> thx
> John
this
> forum on bulk oil.
where the
> Thanks,
> GPSGary
> 1984FC35
Store, manage and share up to 5GB with Windows Live SkyDrive. Start uploading now
11-03-2008, 11:15
Bulk oil system
Gary,
There are 2 switches on my 84FC. One on the right side lower dash and
the other is under the engine doghouse left side mounted on the bracket
that holds the dial where you select the amount of oil to be dispensed.
David Hollis 84FC35 Springfield,IL
--- In WanderlodgeForum@yahoogroups.com, "hippieforever3"
> Thanks,
> Regards,
> GPSGary
11-05-2008, 16:22
Bulk oil system
Hey Gary,
http://www.ryanwright.com/tmp/eng-gauge1.jpg
This is my '86 PT-40. Not sure if yours would be setup similarly or
not, but the blue gauge on the right is the bulk oil fill gauge. This
tells you how much oil you've dispensed. The on/off switch is right
there immediately by the gauge, upper left side of it. That energizes
a solenoid to send air pressure into the tank. No air pressure = no
bulk oil filling.
As others said this is, indeed, a very nice option. It ensures I have
plenty of oil on board for just about any situation I might encounter,
which is nice since the right type of oil for my 8V92, Delo 100 40wt,
is difficult to find and I have to special order by the case. If I'm
in the middle of nowhere and need oil, I have it. I actually do my oil
changes right out of this tank, then fill the tank back up with fresh
oil. This keeps the oil in the tank from getting too old and it's
easier to add oil with that handy little dispensing wand vs. right out
of the 1 gallon jugs.
-Ryan
'86 PT-40 8V92
On Mon, Nov 3, 2008 at 1:51 PM, hippieforever3 wrote:
> Thanks,
> Regards,
> GPSGary
11-08-2008, 00:29
Bulk oil system
I am a little behind on this, but this bulk oil conversation brings up the
question. Would an 81fc have this bulk oil system and if so how would i
know?
Chuck
81FCSB FLORIDA.
> the engine off..but have plenty of air pressure built up at the time.Brad
> Barton 00LXiDFW bbartonwx@...
> To: WanderlodgeForum@...: debra@...: Mon, 3
> Nov 2008 21:51:11 +0000Subject: [WanderlodgeForum] Re: Bulk oil system
> Thanks,That's what I needed. Perfect except there is no lever on the
> tank.Regards,GPSGary--- In WanderlodgeForum@yahoogroups.com, "John"
> wrote:>> On my 83 Fc the tank is in the LP Compartment just
> forward of the door.> > My understanding of the the system is this.> >
> put pressure from the air system into the oil tank.> Then you go to the
> and it will dispense that much oil though the hand wand.> > I am very new
> at this, but that is the way I understand it to work> > thx> John> > >
> ----- Original Message ----- > From: hippieforever3 > To:
> WanderlodgeForum@yahoogroups.com > Sent: Monday, November 03, 2008 11:44>
> Subject: [WanderlodgeForum] Bulk oil system> > > I looked in the little
> bit of documentation I have and searched this > forum on bulk oil.> > Can
> someone please explain how the bulk oil system works and where the > tank
> (and fill) are located?> > Thanks,> GPSGary> 1984FC35> > > > > > No virus
> found in this outgoing message> Checked by PC Tools AntiVirus (4.0.0.26 -
> 10.100.050).> http://www.pctools.com/free-antivirus/>
> _________________________________________________________________
http://skydrive.live.com/welcome.aspx?pr...e_102\
008
