Reset switch on Kohler generators?
10-04-2008, 05:56
I blew the fuse on the generator a few days ago and replaced it. I've
checked the battery, ground, power at the solonoid.
I get NOTHING when I hit the generator start switch.
Any more ideas?
Regards,
GPSGary
84FC35
10-04-2008, 06:08
You blew a fuse and replaced it. Did the new fuse blow? Check the new fuse for continuity. If the fuse is good then hopefully Chuck Wheeler or someone of his electrical calibar will chime in here.
2008/10/4 hippieforever3 <"debra@ticogps.com">
Any more ideas?
Regards,
GPSGary
84FC35
Rob, Sue & Merlin Robinson
94 WLWB
10-04-2008, 07:05
New fuse is fine.
I've even jumped a car battery directly to the heavy post on the
solenoid just in case it was poor contacts and get nothing.
Regards,
GPSGary
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
new fuse
someone
it. I've
> > Any more ideas?
> > Regards,
> > GPSGary
> > 84FC35
> 94 WLWB
10-04-2008, 13:38
Flakey fuse cap. Inserted small ball of aluminum foil.
Fixed
Regards,
GPSGary
