92 WB Jacks
05-18-2005, 17:10
92 WB Jacks
My buddy is having trouble with his jacks working on his 92 WB. He has changed
out 2 relays(Is there a 3rd one he hasn't found?) Every thing checks as he has
been instructed by HWH but the pump will not come on. HWH says it should work
by receiving a ground when activated. He can make it(the pump) work by
providing a hot wire, not a ground. Any ideas?
Thanks LT 90 SP in Eclectic, AL.
05-19-2005, 02:43
92 WB Jacks
Check the motor by applying power directly to the motor terminal. I
recently had a problem and it was a broken wire under the termianl to
the armature. Any generator/starter shop can repair it if it needs it.
Mine showed practically no wear inside. Will outlast me for sure.
R.E. (Ron Marabito, Dallas, TX 92WB40
Moderator
--- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell"
has changed out 2 relays(Is there a 3rd one he hasn't found?) Every
thing checks as he has been instructed by HWH but the pump will not
come on. HWH says it should work by receiving a ground when
activated. He can make it(the pump) work by providing a hot wire, not
05-19-2005, 02:56
92 WB Jacks
Ron
The pump will run when wired straight with a hot wire. HWH says + terminal
should remain hot, then ground is applied when activated, + is not
hot-ground is not applied.
Thanks Lt 90 SP in Eclectic, AL, a two Bird town, 1000 people, 2 Birds
To:
Sent: Thursday, May 19, 2005 9:43 AM
Subject: [WanderlodgeForum] Re: 92 WB Jacks
> Moderator
> Yahoo! Groups Links
05-19-2005, 08:10
92 WB Jacks
If the motor runs, then it has to be one of the two solenoids. If
they were replaced, then check to see if they are wired correctly.
I believe the key has to be on for them to be energized. Maybe
not. I'm having a senior moment. Seems like when I replaced one of
my solenoids, it required the addition of a ground wire.
If none of this works, let me know. I'll go out to my coach and run
back through it.
Moderator.
> Ron
terminal
not
Birds
> From: "ronmarabito2002"
> To:
terminal. I
termianl to
needs it.
sure.
> > Moderator
WB. He
Every
not
wire, not
> > Yahoo! Groups Links
05-20-2005, 09:34
92 WB Jacks
Thanks for the input Ron
He has decided to carry it to Ron in Knoxville for professional assistance.
LT
To:
Sent: Thursday, May 19, 2005 3:10 PM
> back through it.
> Moderator.
>> Ron
> terminal
> not
> Birds
>> To:
> terminal. I
> termianl to
> needs it.
> sure.
>> > Moderator
> WB. He
> Every
> not
> wire, not
>> > Yahoo! Groups Links
> Yahoo! Groups Links
