Dash A/C
12-29-2011, 04:17
Dash A/C
No compressor, no cooling.
--- In WanderlodgeForum@yahoogroups.com, "Bill Jowers" <bgjowers@...> wrote:
> Where does the dash AC get it cooling from? My 1983 PT WL does not have a
> AC compressor on the engine.
> Bill
> 1983 PT 36 BBWL
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002
> Sent: Wednesday, December 28, 2011 9:42 AM
> Subject: [WanderlodgeForum] Re: Dash A/C
> System is fully charged, but I did not think to close off the heat manual
> valves to see if that is the problem. I'll check that on the next warm day.
> , Wayne Kotila
> > Hi Ron, If your freon charge is a little low the system will work fine for
> a little while until the evap. coil under your dash freezes up turning into
> a block of ice and and then cooling stops.
> > Also like you mentioned it could be the warm air from the front heat
> warming your conditioned air, did you shut off the valve or valve's in the
> heater hose supply lines to the front heat?
> > Â
> > Wayne kotila
> > 1996 PT42
> > Â
> > ________________________________
> > From: ronmarabito2002
> > Sent: Tuesday, December 27, 2011 8:53 AM
> > Subject: [WanderlodgeForum] Dash A/C
> > Â
> > Does anyone have a schematic for plumbing and electrical on the Dash A/C
> for a 92 Wanderlodge?
> > I continue to have my dash a/c quit cooling after a short time while
> driving. System is full of freon and cools effectively for a short time.
> > It may be possible that the defrost heat is mixing with the a/c or the
> thermostat is cutting off the compressor. Anyway, any help would be
> appreciated.
