Keeping My 2001 LXi Warm in Winter
11-23-2019, 17:56
Hi
We were always comfortable in the winter while driving my 83 FC35
My 2001 LXi does not seem to be near as comfortable. We have the engine heat on - the three furnaces on and I still get complaints.
Any suggestions?
While parked all seems to be fine. Not sure if the insulation is not sufficient or the windows.
thanks
Urnie
Urnie & Medie Krueger
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
11-24-2019, 19:28
RE: Keeping My 2001 LXi Warm in Winter
Are you running the AquaHot furnaces and the electric furnaces or just one or the other? I haven't run in Chicago cold temps yet, but we have traveled several times in freezing temps and have been warm enough so far.
96 42 big bird
11-25-2019, 13:31
I forgot to ask, were the bay heaters going, too?
96 42 big bird
11-25-2019, 14:10
Thanks for replying. The aqua hot is on - but not the generator.
Should I have to run the generator as well?
I will check the temperature setting on the bay heaters. What temp setting do you recommend. It seems like the last time I check them they were in the 50 degree range.
Thanks
Urnie
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
11-25-2019, 19:53
I would consider running the generator, as it would allow you to turn on the electric baseboard heaters in addition to running the aquahot heaters. When it gets colder, I will run the basement at almost what I've got he house set at. Helps to warm the floor some.
96 42 big bird
