disarming the security system completely
10-30-2016, 14:22
After reading the Manual several times I realize the alarm sytem is very complicated. The last thing I want is it to go off at an RV park, and I dont know how to shut it off. I will use the key to lock the door. Question is I don't see a fuse or circuit marked Security system. Does anyone know how to dis-arm it completely, there is a red light and a toggle switch under the steering wheel, the light is on and the switch is down?? 2004 M380..
Mike Richard
Monson, MA.
2004 M380
2004 PT Cruiser Toad
11-01-2016, 13:17 (This post was last modified: 11-01-2016 13:19 by Dc2x4drvr.)
RE: disarming the security system completely
I don't use the security system in my 380, it's functional and worked last time I tried it. I think the brain is behind the instrument cluster.
11-04-2016, 11:45
Mine has a control panel behind the left door under the dash. There is an on/off switch, I just turned it off.
Morey Zuber
99LXi41
11-06-2016, 09:36
380 doesn't have that switch..
2004 M380
#234
11-11-2016, 22:30
My prior owner disabled the alarm the old fashioned way,.... he cut the wires to the alarm horn. So much faster than trying to understand the system! ?
2001 LXi43 DS
