					Centramatics
					10-24-2013, 20:11
				RE: Centramatics
				(10-24-2013 18:37)Robert Britton Wrote:(10-24-2013 10:43)davidbrady Wrote: Centramatics use beads of some sort in the rings. I can open my driver window and when traveling slow I can hear the beads sloshing about. Balance Masters uses a fluid, mercury I think. You probably can't hear anything with Balance Masters. Ha ha ha, maybe you can get them plated or polished Robert Jim Doel Perth, Ontario 2007 M380 Stainless Steel w/26' Featherlight trailer jimdoel@me.com  |
					10-26-2013, 08:26
				RE: Centramatics
					Since I can raise the tag, I guess I could spin the wheel and see if I can hear the beads?
Ernie Ekberg Prevost Liberty Classic XL Weatherford, Tx http://www.ernieekbergflooring.net  |
					10-26-2013, 09:11
				RE: Centramatics
					Had new tires mounted on the steers yesterday . when I asked about " balance" I was told Michelin does not recommend balancing upon purchase ? It seems we are to drive the coach for a while to determine if it is even needed . Has anyone else had this experience ?
The tire company is very reliable and installed around 50 tires over the past few days here at the WOG rally . al perna 2000 LXI ormond beach fla  |
					10-26-2013, 09:23
				RE: Centramatics
				(10-26-2013 08:26)ernie ekberg Wrote: Since I can raise the tag, I guess I could spin the wheel and see if I can hear the beads? Brilliant idea Ernie! Give it a try.   You can also check for tire flat spotting and take a peak at the shocks to look for serious oil leakage. (Koni says a misting is okay).(10-26-2013 09:11)al perna Wrote: Had new tires mounted on the steers yesterday . when I asked about " balance" I was told Michelin does not recommend balancing upon purchase ? It seems we are to drive the coach for a while to determine if it is even needed . Has anyone else had this experience ? Hey Al, Once upon a time someone over on POG (Prevost Group) marked their tire and wheel just after mounting. Then they went for a drive. The tire shifted on the wheel. Balancing at the tire shop was a waste of money! Beads, Centramatics, or Balance Masters Rule! david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right"  |
					10-26-2013, 10:53
				RE: Centramatics
					good idea , I will mark them and see if there is any change . there is a receipt in the box for the balance masters , but I did not see them
					10-26-2013, 12:29
				RE: Centramatics
				(10-26-2013 08:26)ernie ekberg Wrote: Since I can raise the tag, I guess I could spin the wheel and see if I can hear the beads? If they are working properly, my guess is that you will be able to hear them.. Robert Britton 2004 M380 Hollister, Ca  |
					10-26-2013, 19:26
				RE: Centramatics
					finished the Dynasty today. I get to play with my coach for a week.
I have 6 new Deka 4D batteries to replace the old lifelines. Wish I knew a football player that can lift those babies Ernie Ekberg Prevost Liberty Classic XL Weatherford, Tx http://www.ernieekbergflooring.net  |
					10-27-2013, 00:36
				RE: Centramatics
					would balancing all tires improve the ride vs just balancing the steer tires ?
					10-27-2013, 13:01
(This post was last modified: 10-27-2013 15:44 by Robert Britton.)
				RE: Centramatics
				(10-27-2013 00:36)al perna Wrote: would balancing all tires improve the ride vs just balancing the steer tires ? Al, I did all four corners and there is definitely an improvement in ride quality...not sure if I would have got the same results with just installing them on the front. Buying Centramatics for the rear seems like a bargain as it is installed between the duals...just one Centramatic on each side to balance out duals, lots of tire mass back there. Robert Britton 2004 M380 Hollister, Ca  |
					10-27-2013, 14:42
				RE: Centramatics
					I run them on all axles. I don't see why they'd be any less important at the rear.
