Level lights starys on
04-08-2012, 04:32
Hello All,
I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem. Thanks in advance, Nelson Slinkman Westminster, Md 40' wb |
04-08-2012, 06:20
04-11-2012, 04:55
Hello Mike,
Sorry for he delay in getting back hd to go out of town on business. The red level lights stays on even when the leveling rods are stored and I can see that they are all completely up. Thanks Nelson --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@...> wrote: > > Nelson, > > Just so I am clear, you mean the red level lights stay on even when the Leveling Master switch is turned to the off position? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- On Sun, 4/8/12, nelsons > > From: nelsons > Subject: [WanderlodgeForum] Level lights starys on > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, April 8, 2012, 11:32 AM > > > > > > > > > > > > > > > > > Ã > > > > > > > > > > Hello All, > > I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem. > > Thanks in advance, > > > > Nelson Slinkman > > Westminster, Md > > 40' wb > |
04-11-2012, 05:46
The way I read Mike's note and yours it sounded to me like you were talking
about different lights. I'm not sure, but probably worth asking the question. I'm assuming, Nelson, that you are talking about the warning light that says the jacks are down, while it appeared that Mike was asking about the lights on the leveling controls. If I am right, the first thing to check is that, with the jacks fully up, the fluid level in the reservoir is high enough. On 4/11/2012 at 4:55 PM nelsons wrote: >Hello Mike, >Sorry for he delay in getting back hd to go out of town on business. >The red level lights stays on even when the leveling rods are stored and I >can see that they are all completely up. >Thanks >Nelson > >--- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@...> >wrote: >> >> Nelson, >> >> Just so I am clear, you mean the red level lights stay on even when the >Leveling Master switch is turned to the off position? >> >> Mike Bulriss >> 1991 WB40 "Texas Minivan" >> San Antonio, TX >> >> >> --- On Sun, 4/8/12, nelsons >> >> From: nelsons >> Subject: [WanderlodgeForum] Level lights starys on >> To: WanderlodgeForum@yahoogroups.com >> Date: Sunday, April 8, 2012, 11:32 AM >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> Ã >> >> >> >> >> >> >> >> >> >> Hello All, >> >> I have a 1994 40' bus. My problem is the level red light stay on even >thought all the leveling rods are up all the way. Any help would be >apreciated on where to start to fix this problem. >> >> Thanks in advance, >> >> >> >> Nelson Slinkman >> >> Westminster, Md >> >> 40' wb >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
04-11-2012, 05:54
There is a magnetic pick up on the jack proper that senses the jack retracted.
If it has not slipped out of place or the wiring is not broken or connectors corroded, then check the ground in the jack area. The red light should go out when you turn the jack activation panel off after the jacks are in the store position or travel position. I would heavily suspect the ground though. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "nelsons" Sender: WanderlodgeForum@yahoogroups.com Date: Wed, 11 Apr 2012 16:55:54 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Level lights starys on Hello Mike, Sorry for he delay in getting back hd to go out of town on business. The red level lights stays on even when the leveling rods are stored and I can see that they are all completely up. Thanks Nelson --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@...> wrote: > > Nelson, > > Just so I am clear, you mean the red level lights stay on even when the Leveling Master switch is turned to the off position? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- On Sun, 4/8/12, nelsons > > From: nelsons > Subject: [WanderlodgeForum] Level lights starys on > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, April 8, 2012, 11:32 AM > > > > > > > > > > > > > > > > > Ã > > > > > > > > > > Hello All, > > I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem. > > Thanks in advance, > > > > Nelson Slinkman > > Westminster, Md > > 40' wb > ------------------------------------ Yahoo! Groups Links |
04-11-2012, 06:42
Thanks Ralph,
I will check to see if there is a magnet closing the reed switch. Do you know where the leveling module is located under the coach? Thanks Again, Nelson --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > There is a magnetic pick up on the jack proper that senses the jack retracted. If it has not slipped out of place or the wiring is not broken or connectors corroded, then check the ground in the jack area. The red light should go out when you turn the jack activation panel off after the jacks are in the store position or travel position. I would heavily suspect the ground though. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "nelsons" > Sender: WanderlodgeForum@yahoogroups.com > Date: Wed, 11 Apr 2012 16:55:54 > To: > Reply-To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Level lights starys on > > Hello Mike, > Sorry for he delay in getting back hd to go out of town on business. > The red level lights stays on even when the leveling rods are stored and I can see that they are all completely up. > Thanks > Nelson > > --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@> wrote: > > > > Nelson, > > > > Just so I am clear, you mean the red level lights stay on even when the Leveling Master switch is turned to the off position? > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- On Sun, 4/8/12, nelsons > > > > From: nelsons > > Subject: [WanderlodgeForum] Level lights starys on > > To: WanderlodgeForum@yahoogroups.com > > Date: Sunday, April 8, 2012, 11:32 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ã > > > > > > > > > > > > > > > > > > > > Hello All, > > > > I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem. > > > > Thanks in advance, > > > > > > > > Nelson Slinkman > > > > Westminster, Md > > > > 40' wb > > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
04-11-2012, 06:46
Your module should be center just back of the front tires, give or take.
Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "nelsons" Sender: WanderlodgeForum@yahoogroups.com Date: Wed, 11 Apr 2012 18:42:56 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Level lights starys on Thanks Ralph, I will check to see if there is a magnet closing the reed switch. Do you know where the leveling module is located under the coach? Thanks Again, Nelson --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > There is a magnetic pick up on the jack proper that senses the jack retracted. If it has not slipped out of place or the wiring is not broken or connectors corroded, then check the ground in the jack area. The red light should go out when you turn the jack activation panel off after the jacks are in the store position or travel position. I would heavily suspect the ground though. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "nelsons" > Sender: WanderlodgeForum@yahoogroups.com > Date: Wed, 11 Apr 2012 16:55:54 > To: > Reply-To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Level lights starys on > > Hello Mike, > Sorry for he delay in getting back hd to go out of town on business. > The red level lights stays on even when the leveling rods are stored and I can see that they are all completely up. > Thanks > Nelson > > --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@> wrote: > > > > Nelson, > > > > Just so I am clear, you mean the red level lights stay on even when the Leveling Master switch is turned to the off position? > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- On Sun, 4/8/12, nelsons > > > > From: nelsons > > Subject: [WanderlodgeForum] Level lights starys on > > To: WanderlodgeForum@yahoogroups.com > > Date: Sunday, April 8, 2012, 11:32 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ã > > > > > > > > > > > > > > > > > > > > Hello All, > > > > I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem. > > > > Thanks in advance, > > > > > > > > Nelson Slinkman > > > > Westminster, Md > > > > 40' wb > > > > > > > ------------------------------------ > > Yahoo! Groups Links > ------------------------------------ Yahoo! Groups Links |
04-11-2012, 08:20
Thanks for the info Ralph.
--- In WanderlodgeForum@yahoogroups.com, "Ralph" > > Your module should be center just back of the front tires, give or take. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "nelsons" > Sender: WanderlodgeForum@yahoogroups.com > Date: Wed, 11 Apr 2012 18:42:56 > To: > Reply-To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Level lights starys on > > Thanks Ralph, > I will check to see if there is a magnet closing the reed switch. Do you know where the leveling module is located under the coach? > Thanks Again, > Nelson > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > There is a magnetic pick up on the jack proper that senses the jack retracted. If it has not slipped out of place or the wiring is not broken or connectors corroded, then check the ground in the jack area. The red light should go out when you turn the jack activation panel off after the jacks are in the store position or travel position. I would heavily suspect the ground though. > > Safe travels, Ralph & Charolette Fullenwider > > '84 FC35 "Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original Message----- > > From: "nelsons" > > Sender: WanderlodgeForum@yahoogroups.com > > Date: Wed, 11 Apr 2012 16:55:54 > > To: > > Reply-To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Level lights starys on > > > > Hello Mike, > > Sorry for he delay in getting back hd to go out of town on business. > > The red level lights stays on even when the leveling rods are stored and I can see that they are all completely up. > > Thanks > > Nelson > > > > --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@> wrote: > > > > > > Nelson, > > > > > > Just so I am clear, you mean the red level lights stay on even when the Leveling Master switch is turned to the off position? > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > > > > --- On Sun, 4/8/12, nelsons > > > > > > From: nelsons > > > Subject: [WanderlodgeForum] Level lights starys on > > > To: WanderlodgeForum@yahoogroups.com > > > Date: Sunday, April 8, 2012, 11:32 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ã > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Hello All, > > > > > > I have a 1994 40' bus. My problem is the level red light stay on even thought all the leveling rods are up all the way. Any help would be apreciated on where to start to fix this problem. > > > > > > Thanks in advance, > > > > > > > > > > > > Nelson Slinkman > > > > > > Westminster, Md > > > > > > 40' wb > > > > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
