Mirror set screws
04-26-2009, 11:44
Mirror set screws
So, has anyone had to do battle with the set screws on their mirrors? The PO
had the mirrors set to his specifications and it serves my purposes for the most
part. But, I wanted to tweak them and was unable to loosen hex screws on the
bottom or side. I sprayed the set screws with PB Blaster and let it set
overnight. I put a breaker bar on the hex key and was still unable to budge
them.
Any thoughts????
Jerry
85 PT40
04-26-2009, 12:04
Mirror set screws
Jerry - far as I know, my mirrors are identical to yours.
Those set screws are a royal PITA when stuck. Along with penetrating oil, I
used heat from a propane torch. This method is not without problems. For the
screw on the bottom, your heater wires travel through this area. For the screw
in the mirror head the mirror glass is mounted with a rubber gasket.
If you concentrate the heat carefully the screw may come loose without damaging
the wiring or gasket.
I had to remove the mirrors and take everything apart. Of course, those
decades-old plain steel screws had rusted so several holes had to be drilled
out, then drilled deeper and re-threaded. The screws were then replaced with
longer stainless screws. New set screws, new wires and mirror glass while I was
at it. Everything back together with anti-seize in the right places.
This job did not happen overnight but the reward has been solid adjustable
mirrors for the past 5 years.
Or, 600 bux or so will buy you a new set of heated remote control mirrors.
Bob Griesel '84 FC31 WLII WA
them.
> Any thoughts????
> Jerry
> 85 PT40
04-26-2009, 12:51
Mirror set screws
Bob,
Good post. I'm experiencing the drivers side mirror will move and needs to be adjusted. So far, So good.
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
On Sun, Apr 26, 2009 at 5:04 PM, freewill2008 <"sundance101@comcast.net"> wrote:
Those set screws are a royal PITA when stuck. Along with penetrating oil, I used heat from a propane torch. This method is not without problems. For the screw on the bottom, your heater wires travel through this area. For the screw in the mirror head the mirror glass is mounted with a rubber gasket.
If you concentrate the heat carefully the screw may come loose without damaging the wiring or gasket.
I had to remove the mirrors and take everything apart. Of course, those decades-old plain steel screws had rusted so several holes had to be drilled out, then drilled deeper and re-threaded. The screws were then replaced with longer stainless screws. New set screws, new wires and mirror glass while I was at it. Everything back together with anti-seize in the right places.
This job did not happen overnight but the reward has been solid adjustable mirrors for the past 5 years.
--- In "WanderlodgeForum%40yahoogroups.com", "jburgessx2" wrote:
> So, has anyone had to do battle with the set screws on their mirrors? The PO had the mirrors set to his specifications and it serves my purposes for the most part. But, I wanted to tweak them and was unable to loosen hex screws on the bottom or side. I sprayed the set screws with PB Blaster and let it set overnight. I put a breaker bar on the hex key and was still unable to budge them.
> Any thoughts????
> Jerry
> 85 PT40
04-26-2009, 14:42
Mirror set screws
If you end up having to drill the set screws out of the housing, be careful.
The set screws (on my rig) don't go all the way to the ball at the bottom of the
mirror. The set screws go to a split bushing that the ball at the bottom of the
mirror rides in. The set screw compresses the split bushing which, in turn,
secures the ball at the bottom of the mirror.
After bending a long handle allen wrench, I chose to drill out the set screw and
install a stainless steel "Helicoil" in the aluminum housing. The stainless
Helicoil with a stainless set screw should be a happier arrangement than the SS
set screw in the aluminum housing. Note: If you chose to put a Helicoil in the
blind hole you will have to grind down the Helicoil tap to permit the Helicoil
to be set in the blind hole.
Eric Perplies
96 42' WBWL
currently in Littlerock, WA
04-26-2009, 15:07
Mirror set screws
and install a stainless steel "Helicoil" in the aluminum housing. The stainless
> Eric Perplies
> 96 42' WBWL
In my experience if you drill out the allen screw with a drill just slightly
smaller than the screw the heat generated by drilling will usually break the
screw free much like using a torch without the collateral damage. Get a left
hand drill bit and when it breaks free the drill will back it right out.
Kevin Ridley
79 35FC XV
Spokane WA
04-26-2009, 15:34
Mirror set screws
To clarify - I had to drill and re-tap some of the #8 screws holding the mirror
frame and retainer ring to the mirror body and swing arm. Once the mirror was
apart, the hex-head set screws came out easily with liberal heat, oil, patience,
and an allen wrench.
> > Eric Perplies
> > 96 42' WBWL
> Kevin Ridley
> 79 35FC XV
> Spokane WA
04-27-2009, 08:10
Mirror set screws
I bought a set of BB mirrors at FMCA for $150.00. Some guy had a bunch. I can call a friend and see if more are available.
John Redden
91 PT 40
NC
Sent from my BlackBerry® smartphone with SprintSpeed
Date: Sun, 26 Apr 2009 23:44:33 -0000
To:
Subject: [WanderlodgeForum] Mirror set screws
Any thoughts????
Jerry
85 PT40
04-27-2009, 08:24
Mirror set screws
Are these the mirrors with the BB logo on them?
83PT40
Wanderlodge
--- On Mon, 4/27/09, jvredden@... wrote:
Subject: Re: [WanderlodgeForum] Mirror set screws
Date: Monday, April 27, 2009, 3:10 PM
John Redden
91 PT 40
NC
To:
Any thoughts????
Jerry
85 PT40
04-27-2009, 08:34
Mirror set screws
Yes
John Redden
91 PT 40
NC
Date: Mon, 27 Apr 2009 13:24:05 -0700 (PDT)
To:
83PT40
Wanderlodge
John Redden
91 PT 40
NC
To:
Any thoughts????
Jerry
85 PT40
04-27-2009, 10:36
Mirror set screws
If these are new ones, I could use a set.
Bob Lawrence
84 PT36
Mathis, Texas (with screwed up mirrors)
> Yes
> John Redden
> 91 PT 40
> NC
> -----Original Message-----
> From: Ernie Ekberg
> To:
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
> http://autos.groups.yahoo.com/group/erni...gandrepair
> From: jvredden@...
> John Redden
> 91 PT 40
> NC
> From: "jburgessx2"
> To:
them.
> Any thoughts????
> Jerry
> 85 PT40
