Bulk Oil Fill
12-18-2007, 13:56
Bulk Oil Fill
Bulk oil was kinda nice to have on a highway bus because after
300,000 miles the Detroits 8v92 and 6v92 two stroke engines used oil. A Bus drivers cargo is people and the bulktank kept the driver presentable. In the lodge the bulk oil tank is a luxury. I think it is the rings that pass oil because in the two stroke design the exhaust is in the piston wall. whereas in the 4stroke (thumpers)the rings never pass obstacls. The 3208 Cats, and the Detroit60's are four strokes. good illustration of 2 and 4 stroke 2stroke ( without exhaust gas blower) http://tinyurl.com/27auhb 4 stroke http://en.wikipedia.org/wiki/Four-stroke_engine --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The bulk oil fill makes it easy to add oil to the engine. On diesel pushers it is always a bit tough to pour oil in the fills - little room for a container or funnel. > > The tank is easy to access and add several gallons of oil. It is air pressurized (switch turned on pressurizes it), and there is a fill nozzle with valve on a hose, along with a rotary counter that tells you how much you are dispensing. > > Greatest thing since sliced bread! > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > On 12/17/2007 at 9:05 PM bubblerboy64 wrote: > > >While I have your collective ears. I've notice the term "Bulk oil > >Fill" this seems to be applied to the Detroit Diesels. Would some one > >explain what that is about. > |
12-19-2007, 02:42
Bulk Oil Fill
The bulk oil filler survived onto the Series 60 ... and it's a great
convenience. My coach doesn't use much oil, so I don't often need to add any (perhaps reflected in the 3 gal capacity of the bulk tank in my coach). However, I still like to remain presentable -- and besides, with the Series 60 in a pusher location, it's near- impossible to get to the top of the engine where you'd normally put oil in anyway -- at least not without becoming completely covered in the dirt that inhabits the engine compartment. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Santa Fe NM On Dec 18, 2007, at 6:56 PM, Gregory OConnor wrote: > Bulk oil was kinda nice to have on a highway bus because after > 300,000 miles the Detroits 8v92 and 6v92 two stroke engines used > oil. A Bus drivers cargo is people and the bulktank kept the driver > presentable. In the lodge the bulk oil tank is a luxury. > > > I think it is the rings that pass oil because in the two stroke > design the exhaust is in the piston wall. whereas in the 4stroke > (thumpers)the rings never pass obstacls. The 3208 Cats, and the > Detroit60's are four strokes. > > good illustration of 2 and 4 stroke > 2stroke ( without exhaust gas blower) > > http://tinyurl.com/27auhb > > > 4 stroke > http://en.wikipedia.org/wiki/Four-stroke_engine |
