8V92 Won't cut off
05-09-2005, 11:09
8V92 Won't cut off
This past Saturday drove to Road Atlanta for a race. Upon arrival I
hooked up to two 30 amp power outlets. Switched the power swith over
to the 30 amp side. During this time the engine was running. After
getting hooked up I went to stop the 8V92 and it would not cut off by
the key. I checked the rear switch and could not find anything
wrong. I was about the disconnect the batteries when I decided to go
back and turn everything "off" on the power switch that way I could
make sure that the converter would not be giving 12 volt to the engine
to keep it running. I turned the power switch to off and then the
engine cut off with the use of the key as it should. Has worked fine
since then. Any ideas what was going on ? Note that this was the
first time in several months that I had used the 2 30 amp connections
and switched the power swith to the 30 amp side.
Bryan Altier
Greenville, SC
88 WLWB40 "Xanadu"
05-09-2005, 11:21
8V92 Won't cut off
If your unit is the same as our 1987 PT38...the manual doesn't state
specifically that the 8V92 might not turn off with the ignition, but it
says that if the ignition fails to shut down the 8V92, to pull the "pull
to stop" lever that is located down under the dash on the left side of
the steering column. You have to get down and look under that dash to
see the "pull to stop". I've had to do that once. Can't explain it.
> Bryan Altier
> Greenville, SC
> 88 WLWB40 "Xanadu"
05-18-2005, 11:19
8V92 Won't cut off
I also have an 88 WB40. I just replaced my transfer switch
(Off/Gen/50/30) switch assy. I was having generator voltage
fluctuations. When I lifted the cover of the switch, to my surprize I
found the switch completly submerged in water. The switch was
completely rusted. I was very surprized that it was still working to
some extent. I was told that some of our 88 WB40 had this problem and
that BB was installing a duck bill check valve in the bottom ogf the
enclosure allowing water to escape without having debris enter. I
purchased a replacement switch from Holland (much cheaper than
BB).Everything is now working well. I would check your coach to see if
this is related to your problem and if not install this check valve to
prevent future problems.
Andy
88 WLWB40
Caledon East, Ontario, Canada
engine
> Bryan Altier
> Greenville, SC
> 88 WLWB40 "Xanadu"
