					help with alternator replacement
					07-22-2007, 01:03
					Does anyone no the procedure to replace the rear alternator in a 1994
			with an 8v92.I could not find any trap door in the bedroom area or inside the closet. Any help will be appreciated. Thanks in advance Nelson Slinkman 1994 40'  |
					07-22-2007, 01:13
					If you have a cross-island bed, the access is in the floor of the
			bedroom between the bed and the rear cabinets. I've done it a couple of times. Let me know if that is your bed arrangement. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "nslinkman" wrote: > > Does anyone no the procedure to replace the rear alternator in a 1994 > with an 8v92.I could not find any trap door in the bedroom area or > inside the closet. Any help will be appreciated. > Thanks in advance > Nelson Slinkman 1994 40' >  |
					07-22-2007, 01:24
					If it is like mine one alternator is accessible by removing the mattress and
			removing a large plate. It has numerous screws.My other alternator is behind the r/h side of the rear bumper. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: nslinkman To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 22, 2007 8:03 AM Subject: [WanderlodgeForum] help with alternator replacement Does anyone no the procedure to replace the rear alternator in a 1994 with an 8v92.I could not find any trap door in the bedroom area or inside the closet. Any help will be appreciated. Thanks in advance Nelson Slinkman 1994 40' [Non-text portions of this message have been removed]  |
					07-22-2007, 01:35
					In addition to Ron's comment, if it is a forward facing bed, the
			access is through a plate under the bed just in front of the rear closet wall. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > If you have a cross-island bed, the access is in the floor of the > bedroom between the bed and the rear cabinets. I've done it a couple > of times. Let me know if that is your bed arrangement. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "nslinkman" > wrote: > > > > Does anyone no the procedure to replace the rear alternator in a 1994 > > with an 8v92.I could not find any trap door in the bedroom area or > > inside the closet. Any help will be appreciated. > > Thanks in advance > > Nelson Slinkman 1994 40' > > >  |
					07-22-2007, 10:10
					In a message dated 7/22/2007 6:27:18 P.M. Mountain Standard Time,
			fljensen@... writes: Nelson: If you belong to WOO group, (www dot wanderlodge dot us) I have a detailed pictorial on how to do this step by step. You will have to loosen and pick up the carpet between the bed and closet to get to the plate. It is a tight fit. OR- you could post that detail here~ Ernie Ekberg 83PT40 Weatherford, Tx Wanderlodgeforum.org, owner ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
					07-22-2007, 13:20
					Nelson:
			If you belong to WOO group, (www dot wanderlodge dot us) I have a detailed pictorial on how to do this step by step. You will have to loosen and pick up the carpet between the bed and closet to get to the plate. It is a tight fit. William Jensen 1993 PT40 WBWL Cross queen Deerfield Beach, FL --- In WanderlodgeForum@yahoogroups.com, "nslinkman" wrote: > > Does anyone no the procedure to replace the rear alternator in a 1994 > with an 8v92.I could not find any trap door in the bedroom area or > inside the closet. Any help will be appreciated. > Thanks in advance > Nelson Slinkman 1994 40' >  |
					07-22-2007, 15:08
			> OR- you could post that detail here~ > > Ernie Ekberg > 83PT40 > Weatherford, Tx > Wanderlodgeforum.org, owner > > > > Ernie: Would love too, not picking favorites, but Yahoo will not support such an extensive article with picture and descriptions. That I know of ???? correct me if I am wrong. William Jensen 1993 PT40 WBWL "Maudi" Deerfield Beach, Fl  |
					07-23-2007, 02:58
					--- In WanderlodgeForum@yahoogroups.com, "William Jensen"
			> > > > > OR- you could post that detail here~ > > > > Ernie Ekberg > > 83PT40 > > Weatherford, Tx > > Wanderlodgeforum.org, owner > > > > > > > > > Ernie: > > Would love too, not picking favorites, but Yahoo will not support > such an extensive article with picture and descriptions. That I > know of ???? correct me if I am wrong. > > William Jensen > 1993 PT40 WBWL "Maudi" > Deerfield Beach, Fl > Unless you have something very unique, you can post it here. As examples, look at the in Files at one called Racor Fuel Filter.pdf or at the FC Dog House Removal file. Both those files are full of text and pictures. The Racor is word and text in a .pdf and the FC Doghouse was scanned and saved as a .jpg, both of which are common file formats that can then be read by anyone without need for special software. Alternatively, Bob Lawrence just posted a pictorial of his tankless water heater addition in a Photo albumn with narratives on each picture that made it pretty clear what was involved. Michael Brundridge did the same thing in the Photos with an albumn showing his AC conversion from Dometic to Carrier units. For a narrative 'extensive article' with embedded pictures in the text, I would suggest setting the article in Word and load it as a File. Better yet, save it to a .pdf after setting it in Word, so that anyone can read it. That would be best. If you already have it set as an article, it should be no big deal to convert and post as a File. Yahoo has increased all the space allocations for Files, Photos, etc., so we have lots of room available to post such things now. There's your alternatives. If you need help, let me know. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX  |
					07-23-2007, 05:12
					My bed has the cross island queen.
			I assume all the carpet has to be removed from the rear bulkhead. Is there an access panel behind the carpet. Thank Nelson Slinkman --- mbulriss <mbulriss@...> wrote: > In addition to Ron's comment, if it is a forward > facing bed, the > access is through a plate under the bed just in > front of the rear > closet wall. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, > "ronmarabito2002" > > > > > If you have a cross-island bed, the access is in > the floor of the > > bedroom between the bed and the rear cabinets. > I've done it a couple > > of times. Let me know if that is your bed > arrangement. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, > "nslinkman" > > wrote: > > > > > > Does anyone no the procedure to replace the rear > alternator in a 1994 > > > with an 8v92.I could not find any trap door in > the bedroom area or > > > inside the closet. Any help will be appreciated. > > > Thanks in advance > > > Nelson Slinkman 1994 40' > > > > > > > > ________________________________________________________________________________\ ____ Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase. http://farechase.yahoo.com/  |
					07-23-2007, 07:54
					Nelson:
			You begin by removing two sections of carpeted base. Start with the short piece at the nightstand. There are screws hidden in the carpet that hold the base in place. Use a magnetic stud finder to assist in locating the screws. Next, pull the carpet back, again starting at the night stand. There are actually (2) pieces of plate. It is obvious which has to be removed first. The second and largest has screws into the back wall, so you probably will have to pull some plumbing clamps in order to see all of them. In order to provide more working room, you can remove a 10-12" piece of the plywood supporting the mattress along that isle. Once you remove the mattress, you can see it. Once the plates are removed, you can see the alternator. Loosen the anchor bolt before loosening the adjusting bolt. Do this after you have removed the (3) wires from the alternator. Since you have to work on your knees, bent over in a hole, you will find that this is not a fun job. I suggest you use a piece of plywood for kneeling over the opening. A trouble light will also help. When you have re-built the alternator, the process is just the reverse. You will need an air stapler or electric stapler to reinstall the carpet. Let me know if you need anything else. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, nelson slinkman > > My bed has the cross island queen. > I assume all the carpet has to be removed from the > rear bulkhead. Is there an access panel behind the > carpet. > > Thank > Nelson Slinkman > > > --- mbulriss <mbulriss@...> wrote: > > > In addition to Ron's comment, if it is a forward > > facing bed, the > > access is through a plate under the bed just in > > front of the rear > > closet wall. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, > > "ronmarabito2002" > > > > > > > > If you have a cross-island bed, the access is in > > the floor of the > > > bedroom between the bed and the rear cabinets. > > I've done it a couple > > > of times. Let me know if that is your bed > > arrangement. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > "nslinkman" > > > wrote: > > > > > > > > Does anyone no the procedure to replace the rear > > alternator in a 1994 > > > > with an 8v92.I could not find any trap door in > > the bedroom area or > > > > inside the closet. Any help will be appreciated. > > > > Thanks in advance > > > > Nelson Slinkman 1994 40' > > > > > > > > > > > > > > > > > > ________________________________________________________________________________\ ____ > Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase. > http://farechase.yahoo.com/ >  |
