Engine oil temp.
07-01-2007, 04:29
Engine oil temp.
When I bought my PT36 in April the engine oil temp guage was inop.
I have replaced that guage with a working one and I see the engine
oil temp running at 230 degrees. I believe that is close to the upper
limit. This temperature is reached driving local freeways with
little congestion and no grades. Do I have something to be concerned
about? You folks who have similiar engines, what is your normal engine
oil temp? Coolant temp runs 185 to 195.
Art Weatherly
Riverside Ca.
'85 PT36
07-01-2007, 05:06
Engine oil temp.
I just looked in my Detroit manual last night and found the oil range for my
8v92TAC engine. 200-250 for mine. If you know what engine and turbo you have I
can look it up and tell you what it says for you engine.
Was the new gauge the same index as the old gauge? If not, you need to replace
the sender with a compatible version. As for actual temperatures, mine routinely
runs 220 at 1950 rpm and 67 mph. As water temperature increases, so does the oil
temp.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
----- Original Message ----
Sent: Sunday, July 01, 2007 11:29 AM
Subject: [WanderlodgeForum] Engine oil temp.
Art Weatherly
Riverside Ca.
'85 PT36
07-01-2007, 05:41
Engine oil temp.
The replacment guage is identical - same indexing, same ID numbers.
It came out of an '84 FC35 the previous owner of mine was parting
out.
Art Weatherly
Riverside Ca.
'85 PT36
range for my 8v92TAC engine. 200-250 for mine. If you know what
engine and turbo you have I can look it up and tell you what it says
for you engine.
need to replace the sender with a compatible version. As for actual
temperatures, mine routinely runs 220 at 1950 rpm and 67 mph. As
water temperature increases, so does the oil temp.
> Leroy Eckert
> Niceville, FL
> From: amweath
inop.
engine
upper
concerned
engine
> Art Weatherly
> Riverside Ca.
> '85 PT36
07-01-2007, 11:13
Engine oil temp.
My 8V92's usual oil temp is 230-235....water temp is around 190 +/- 5
degrees, even when under a load. If it starts to climb, I turn on the fan
overide,
and it comes right back down.
Kevin Mc
YL CA 86 38 pt
8v92
07-01-2007, 12:10
Engine oil temp.
You can dial in ww2.tflx.com/tech/html and follow the trouble shooting guide for
Teleflex gauge systems and determine if the system is working properly.
Leroy Eckert
Niceville, FL
Sent: Sunday, July 01, 2007 12:41 PM
Subject: [WanderlodgeForum] Re: Engine oil temp.
out.
Art Weatherly
Riverside Ca.
'85 PT36
for you engine.
> Leroy Eckert
> Niceville, FL
> From: amweath
inop.
engine
upper
concerned
engine
> Art Weatherly
> Riverside Ca.
> '85 PT36
07-02-2007, 02:42
Engine oil temp.
Art,
I cleaned my radiators and it has brought down my temps abt. 7 degrees on
avgerage.
Howard T., Ga., 86 PT40
> From: "amweath"
> Date: 2007/07/01 Sun PM 12:29:44 EDT
> Art Weatherly
> Riverside Ca.
> '85 PT36
07-02-2007, 03:04
Engine oil temp.
Thanks everyone for your responses. I feel much more comfortable now
with the temps I'm running.
Art Weatherly
Riverside Ca.
'85 PT36
07-02-2007, 03:09
Engine oil temp.
Howard
You said radiators, plural. Is there another one besides the main
engine and generator radiator.
Art Weatherly
Riverside Ca.
'85 PT36
--- In WanderlodgeForum@yahoogroups.com, wrote:
> Art,
degrees on avgerage.
> > From: "amweath"
inop.
engine
upper
concerned
engine
> > Art Weatherly
> > Riverside Ca.
> > '85 PT36
07-02-2007, 09:30
Engine oil temp.
Art,
One for the transmission mounted on engine side of main engine radiator. I
pressure washed with a good brand of cleaner being careful not to damage hoses
or radiators.
Howard T., Sowega., 86 PT40
> From: "amweath"
> Date: 2007/07/02 Mon AM 11:09:03 EDT
> Howard
> Art Weatherly
> Riverside Ca.
> '85 PT36
> > Art,
> > > From: "amweath"
> inop.
> engine
> upper
> concerned
> engine
> > > Art Weatherly
> > > Riverside Ca.
> > > '85 PT36
User(s) browsing this thread: 10 Guest(s)
