Low air
03-20-2007, 04:12
Low air
I had a similar problem, and replaced the air governor. I couldn't do it
myself, because of the location of the governor, so I had a local shop do it for me (wasn't cheap). I had them relocate the air governor so if I ever had to change it again, I could do so in about 10 minutes. The air governor itself was only about $30 (it's a Bendix part)...it was the labor that broke my wallet. My BB would only air up to about 30-40lbs, and wouldn't go any higher....and it was intermittent. Not even enough air to release my brakes. A few forum members advised me that the issues might have been the air pump "unloader". Fortunately, it was the air governor not the "unloader". That R&R looked a little tough for me also...not much room to work on the air pump on my PT. Good luck...if your Governor is accessible, I'd replace it and see what happens. Kevin McKeown Yorba Linda, CA 1986 38' PT ************************************** AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. [Non-text portions of this message have been removed] |
03-20-2007, 06:48
Low air
I have a 82 FC 35 SB. "Serendipity" I have been reading the post
for over a year now and have benefited from all of the knowledge here. I have been able to alot of upgrades repairs from reading the forum. But now I have a problem and cannot get into the archives to do some research so I would like some input on my problem. I picked up the bird from storage yesterday, as usual it started on the first crank and everything was fine. The air bags came up, the brake air presure read over 75 the seat and step all worked fine. I drove down the road about 3 miles turned into the the rv park and noticed the low air light and buzzer came on. When I got to my lot I let it idle for a few minutes but the warning never went off. My brake preasure was down a little the step would not work. The rear bags were up the front looked alittle low. As I touched the brake peddle the rear air guage started going down. So I parked it right away cuz I knew if I lost anymore air the rear brakes would lock up. I left the engine running and tryed to go around the coach to listen for an air leak. I couldn't hear any but with the engine noise it war hard to tell. After shutting down the engine. I still couldn't haer any thing. Where do I start? A day later and the rear air bags are still up and the front look low or down. I did not dump the air yet. Any help would be greatly appreciated. Thanks Jim Marsh 82 35FC |
03-20-2007, 06:52
Low air
Jim, try and dump your air and then flip your switches to air up.
Ernie Ekberg 83PT40 Livingston, Mt ************************************** AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. [Non-text portions of this message have been removed] |
03-20-2007, 08:05
Low air
For about 12 bucks you might try rebuilding the purge (spitter) valve at the
bottom of the air dryer. Could be intermittently hanging open. OR you could just buy my whole bird which does not have that issue but if it did it comes with two spare rebuild kits. dandarst86fc35rbhuntleyil. >From: "chunkymar" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Low air >Date: Tue, 20 Mar 2007 17:48:52 -0000 > >I have a 82 FC 35 SB. "Serendipity" I have been reading the post >for over a year now and have benefited from all of the knowledge >here. I have been able to alot of upgrades repairs from reading the >forum. But now I have a problem and cannot get into the archives to >do some research so I would like some input on my problem. I picked >up the bird from storage yesterday, as usual it started on the first >crank and everything was fine. The air bags came up, the brake air >presure read over 75 the seat and step all worked fine. I drove >down the road about 3 miles turned into the the rv park and noticed >the low air light and buzzer came on. When I got to my lot I let it >idle for a few minutes but the warning never went off. My brake >preasure was down a little the step would not work. The rear bags >were up the front looked alittle low. As I touched the brake peddle >the rear air guage started going down. So I parked it right away >cuz I knew if I lost anymore air the rear brakes would lock up. I >left the engine running and tryed to go around the coach to listen >for an air leak. I couldn't hear any but with the engine noise it >war hard to tell. After shutting down the engine. I still couldn't >haer any thing. Where do I start? A day later and the rear air >bags are still up and the front look low or down. I did not dump >the air yet. Any help would be greatly appreciated. > >Thanks >Jim Marsh >82 35FC > > > _________________________________________________________________ Interest Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate new payment http://www.lowermybills.com/lre/index.js...&moid=7581 |
03-20-2007, 08:25
Low air
Hi Jim, while I am not an "expert" on the subject the same thing happened to
me recently. What I found was the the flex lines which provide the air pressure to release the parking brakes on the rear axle were bad (orginal 1985). Note, the parking brakes are spring applied and air released, so when you push in the big Yellow button on the dash to drive, only then are you are putting air into those lines and they will then leak only when in the travel mode-not when parked. I replaced both of mine and was very concerned when I saw the condition of the lines. I am sure the same will apply in your case. Cheap easy fix. Regards, Neil PT36 I have a 82 FC 35 SB. "Serendipity" I have been reading the post for over a year now and have benefited from all of the knowledge here. I have been able to alot of upgrades repairs from reading the forum. But now I have a problem and cannot get into the archives to do some research so I would like some input on my problem. I picked up the bird from storage yesterday, as usual it started on the first crank and everything was fine. The air bags came up, the brake air presure read over 75 the seat and step all worked fine. I drove down the road about 3 miles turned into the the rv park and noticed the low air light and buzzer came on. When I got to my lot I let it idle for a few minutes but the warning never went off. My brake preasure was down a little the step would not work. The rear bags were up the front looked alittle low. As I touched the brake peddle the rear air guage started going down. So I parked it right away cuz I knew if I lost anymore air the rear brakes would lock up. I left the engine running and tryed to go around the coach to listen for an air leak. I couldn't hear any but with the engine noise it war hard to tell. After shutting down the engine. I still couldn't haer any thing. Where do I start? A day later and the rear air bags are still up and the front look low or down. I did not dump the air yet. Any help would be greatly appreciated. Recent Activity a.. 20New Members b.. 20New Photos c.. 1New Links Visit Your Group SPONSORED LINKS a.. Recreational vehicles b.. Recreational vehicle financing c.. Recreational vehicle repair d.. Recreational vehicle rental e.. Recreational vehicle camper NCAA Madness! Find a hoops group Talk Tourney ball with fellow fans Boxing Greats Who's the best? Share and vote on Bix.com Health Zone Look your best! Groups to help you look & feel great. . [Non-text portions of this message have been removed] |
03-20-2007, 08:26
Low air
For $12, why would anyone rebuild anything. I'll take your whole
Bird for that $12 offer! ;-) Tom McCarthy 95 PT42 Poway, CA --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote: > > For about 12 bucks you might try rebuilding the purge (spitter) valve at the > bottom of the air dryer. Could be intermittently hanging open. OR you could > just buy my whole bird which does not have that issue but if it did it comes > with two spare rebuild kits. > > dandarst86fc35rbhuntleyil. > > > >From: "chunkymar" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Low air > >Date: Tue, 20 Mar 2007 17:48:52 -0000 > > > >I have a 82 FC 35 SB. "Serendipity" I have been reading the post > >for over a year now and have benefited from all of the knowledge > >here. I have been able to alot of upgrades repairs from reading the > >forum. But now I have a problem and cannot get into the archives to > >do some research so I would like some input on my problem. I picked > >up the bird from storage yesterday, as usual it started on the first > >crank and everything was fine. The air bags came up, the brake air > >presure read over 75 the seat and step all worked fine. I drove > >down the road about 3 miles turned into the the rv park and noticed > >the low air light and buzzer came on. When I got to my lot I let it > >idle for a few minutes but the warning never went off. My brake > >preasure was down a little the step would not work. The rear bags > >were up the front looked alittle low. As I touched the brake peddle > >the rear air guage started going down. So I parked it right away > >cuz I knew if I lost anymore air the rear brakes would lock up. I > >left the engine running and tryed to go around the coach to listen > >for an air leak. I couldn't hear any but with the engine noise it > >war hard to tell. After shutting down the engine. I still couldn't > >haer any thing. Where do I start? A day later and the rear air > >bags are still up and the front look low or down. I did not dump > >the air yet. Any help would be greatly appreciated. > > > >Thanks > >Jim Marsh > >82 35FC > > > > > > > > _________________________________________________________________ > Interest Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate > new payment > http://www.lowermybills.com/lre/index.js...=lmb-9632- 18466&moid=7581 > |
03-20-2007, 13:19
Low air
Jim, it sounds to me that you started having problems, when you hit the brakes.
My guess is you either have a leaking service, or maxi pancake (diaphram). The reason you didn't hear anything, is because if it's on the service end, it won't make any leaking noises, untill you step on the pedal ( which is when you saw the pressure dropping) If it's on the Maxi,(parking) side, you won't hear it leaking, untill you press the button in. I'd have someone sit in the seat while you walk around. First chock the wheels, on a level surface, have them press in the parking brake button, and listen, if you hear leaks, it's on the parking end, either the pancake, or a cracked housing leaking enternally if you don't have them step on the pedal and listen again if you hear leaks, it's on the service end. Don't attempt to take those rear chambers apart, unless you know what you're doing and cage them first, There's a coil spring inside, about the diameter of a car suspension coil spring and if they're not caged, they can be lethal. If you still don't hear anything leaking, I'll say the air governor, attached to the air compressor, may be gummed up, and sticking. Please bear in mind, I'm only about 2 weeks into Bluebird busses,so there could be some other valve in the system, that I'm not aware of. Oh, and one more thing to check. Make sure the treadle valve (foot valve), is returning back all of the way some pedals are made from Alluminum, and they use a steel pin, for the pivot, the two unlike metals cause electrollosis, or corrosion. I drive the pin out, and run a drill through the hole, to clean it out, then I apply never seize to the pin. Good luck Jimmy Harvie Tom McCarthy $12, why would anyone rebuild anything. I'll take your whole Bird for that $12 offer! ;-) Tom McCarthy 95 PT42 Poway, CA --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote: > > For about 12 bucks you might try rebuilding the purge (spitter) valve at the > bottom of the air dryer. Could be intermittently hanging open. OR you could > just buy my whole bird which does not have that issue but if it did it comes > with two spare rebuild kits. > > dandarst86fc35rbhuntleyil. > > > >From: "chunkymar" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Low air > >Date: Tue, 20 Mar 2007 17:48:52 -0000 > > > >I have a 82 FC 35 SB. "Serendipity" I have been reading the post > >for over a year now and have benefited from all of the knowledge > >here. I have been able to alot of upgrades repairs from reading the > >forum. But now I have a problem and cannot get into the archives to > >do some research so I would like some input on my problem. I picked > >up the bird from storage yesterday, as usual it started on the first > >crank and everything was fine. The air bags came up, the brake air > >presure read over 75 the seat and step all worked fine. I drove > >down the road about 3 miles turned into the the rv park and noticed > >the low air light and buzzer came on. When I got to my lot I let it > >idle for a few minutes but the warning never went off. My brake > >preasure was down a little the step would not work. The rear bags > >were up the front looked alittle low. As I touched the brake peddle > >the rear air guage started going down. So I parked it right away > >cuz I knew if I lost anymore air the rear brakes would lock up. I > >left the engine running and tryed to go around the coach to listen > >for an air leak. I couldn't hear any but with the engine noise it > >war hard to tell. After shutting down the engine. I still couldn't > >haer any thing. Where do I start? A day later and the rear air > >bags are still up and the front look low or down. I did not dump > >the air yet. Any help would be greatly appreciated. > > > >Thanks > >Jim Marsh > >82 35FC > > > > > > > > __________________________________________________________ > Interest Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate > new payment > http://www.lowermybills.com/lre/index.js...=lmb-9632- 18466&moid=7581 > --------------------------------- Don't be flakey. Get Yahoo! Mail for Mobile and always stay connected to friends. [Non-text portions of this message have been removed] |
