Power Steering Filter
12-17-2006, 08:11
Does anyone know the number of the power steering filter on a 89 SP 36'. I
don't know if mine has ever been changed. Thanks
Don
89 SP 36'
Butler, PA Getting ready to head South ///////
12-17-2006, 13:23
My 82 FC has a label on the side of the reservoir with the filter number on it.
The number
was also visible on the top of the filter.
Kerry
82 FC 35
Denver
> Don
> 89 SP 36'
12-17-2006, 16:35
If I have a PS filter where is it? I know mine hasn't been changed since
Oct 01(when I bought the coach)
Lawrence Thornell 90 SP in Eclectic, AL
To:
Sent: Sunday, December 17, 2006 7:11 PM
Subject: [WanderlodgeForum] Power Steering Filter
> I
> Don
> 89 SP 36'
> Yahoo! Groups Links
12-17-2006, 16:45
Don,
If the filters (4 of them) are the same as our '87 PT38...
I purchased the filter, seals, gaskets from Bluebird.
Three filters, #2138246...one filter #2122026...one bowl o-ring #
21137024...one cover gasket #2138261.
Hope this helps.
Curt Sprenger
Anaheim Hills, Calif.
>Don
>89 SP 36'
>Yahoo! Groups Links
12-17-2006, 16:49
If I'm correct, it is the same unit for the pusher engine radiator fan.
Curt Sprenger
>From:
>To:
>>I
>>Don
>>89 SP 36'
>>Yahoo! Groups Links
>Yahoo! Groups Links
12-17-2006, 22:00
In a message dated 12/17/2006 11:52:18 P.M. Eastern Standard Time,
curtsprenger@... writes:
Curt Sprenger
>From: <_dspithaler@..._ (mailto:dspithaler@...) >
Curt --- Lawrence I think I only have one filter & it is in the back
lift up to the right of the rad on the curb side.It is a round black with a
lid on the top. Take the lid off & pull the filter out. A parts guy said he
could match it if he had the filter. I would like to have the parts number my
self. Do you think Blue Bird put a different system on the SP ? I have a Eaton
pump.
Don
89 SP 36'
Butler, PA
>To: <_WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) >
>>I
>>Don
>>89 SP 36'
>>[Non-text portions
12-18-2006, 03:09
Thanks Don I'll check it out LT
To:
Sent: Monday, December 18, 2006 9:00 AM
Subject: Re: [WanderlodgeForum] Power Steering Filter
> Curt Sprenger
> back
> a
> he
> number my
> Eaton
> pump.
> Don
> 89 SP 36'
> Butler, PA
>>>I
>>>Don
>>>89 SP 36'
>>>[Non-text portions
> Yahoo! Groups Links
12-18-2006, 05:13
Another non-documented component.
From the PS unit, follow the clamped/low pressure/
return/suction line to the reservoir where you check/
add PS fluid, unbolt the top, filer is at the bottom.
Order brom BB or have NAPA cross-referrence.
bob janes, '87fc35, greenville, sc
--- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell"
since
> From:
> To:
SP 36'.
> > I
> > Don
> > 89 SP 36'
> > Yahoo! Groups Links
