Television
03-16-2006, 15:14
Television
how do you know if the antenna is rotating when you turn the wheel?
-------------- Original message from putneyflash@...: --------------
Thanks Tom: am i to understand you repaired the silver box.? when you installed
the TV on the dog house do you use the TV connector on the floor by the
co-pilot. where is your back up monitor??i was thinking of installing it in
place of the orginal TVscreen. Thanks again for responding.
-------------- Original message from Tom Warner :
"The silver box" is part of the electronics for the Cathode Ray tube
mounted over the front of the driver. PMMI took apart a TV set and
put part of it in the "Silver Box" and part in the overhead in front
of the driver. There is really not enough room to replace the TV
screen with a TV so I made a cherry cabinet mounted on too of the dog
house for mine. I repaired mine and it works fine now.
tom warner
1982 FC35
Vernon Center,NY
The "Silver boxAt 10:13 PM 3/12/2006, you wrote:
>I have several questions about the TV in my 1983 FC-35.
>the TV screen comes on no rear picture, but the previous owner
>installed a 5" tv on the dash and the back up camera works fine on
>this TV.
>Is the silver box located above the drivers seat the actual TV? when i
>move some on the knobs i see movement on the TV sreen ( the orginal TV
>screen)verical, contrast etc.
>has anyone had one of these units repaired?
>can i installed another TV in place of the orginal and get rid of the
>silver box.?
>is there an indicator that shows the TV antenna is rotating?
>does the CB radio run through the silver box?
>how is the silver box mounted, mine is setting loose on the shelf.
>That for all the help I know I will get, this is a great site and you
>folks have a lot of knowledge
>re brake 1983 FC-35
>SPONSORED LINKS
ObWmSYTw>Recreational
>vehicles
anderlodge
4cC1O9CxA>Automotive
>maintenance
YHfELr6o72IW1A>Recreational
>vehicle dealer
-kXbDI4ZSadEw>Used
>recreational vehicles
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
03-16-2006, 23:22
Television
I installed a new one and i know it rotates with the hand held control because
like you say the picture gets better or worse, when i turn the wheel so far i
haven't seen any change. i didn't have the hand control hooked up when i moved
the wheel,
it will work like it is i am one of those guys who likes things to work like it
was disigned to even if its old tecnology.
Thanks for responding
re brake
-------------- Original message from krminyl@...: --------------
Not a real scientific answer, but I believe mine is turning because the
signal (picture) gets better (or worse) as you hold down the "rotate" rocker
switch.
I would guess that if your TV picture never changes (try different
channels), the element inside the dome isn't rotating like it is supposed to.
I guess
you could take the darn thing apart, and look inside the dome while someone
works the switch.
Have fun...I hear that the antennas are still available. Check the archives.
Kevin McKeown
Yorba Linda, CA
1986 38' PT
YAHOO! GROUPS LINKS
03-22-2006, 02:57
Television
Yes I have the diagrams and information for the "silver box" and have
repaired it. The monitor is overhead of the driver in its original
location. Now that I have the 85 PT40 I intend to put a new system
in it consisting of two LCD screens (one for the driver and one for
the passenger) with the appropriate electronics for a GPS system as
well as a back up monitor.
tom warner
1982 FC35
1985 PT40
>you installed the TV on the dog house do you use the TV connector on
>the floor by the co-pilot. where is your back up monitor??i was
>thinking of installing it in place of the orginal TVscreen. Thanks
>tom warner
>1982 FC35
>Vernon Center,NY
> >this TV.
> >silver box.?
> >re brake 1983 FC-35
> >SPONSORED LINKS
> ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recr
eational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic\
le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=D\
AUkCKkU7Dzhn_ObWmSYTw>http://groups.yahoo.com/gads?t=ms&k=Recr...cles&\
w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreationa\
l+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163\
&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational
> >vehicles
> ><<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+v
ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&\
w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3Q\
LPj9U0JvqYQ>http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\
9U0JvqYQ>Wanderlodge
> ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Rec
reational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi\
cle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=\
IF4u_5wI8Pmy34cC1O9CxA>http://groups.yahoo.com/gads?t=ms&k=Auto...enanc\
e&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreatio\
nal+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=1\
63&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive
> >maintenance
> ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w
1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational\
+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&\
.sig=z6_XahaeYHfELr6o72IW1A>http://groups.yahoo.com/gads?t=ms&k=Recreational+veh\
icle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4\
=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiato\
rs&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreational
> >vehicle dealer
> ><<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1
=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+\
vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.\
sig=UGEY5km4L-kXbDI4ZSadEw>http://groups.yahoo.com/gads?t=ms&k=Used+recreational\
+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=R\
ecreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators\
&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used
> ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recre
ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=eP\
NVMmISsCWgTnMq_4GlXA>http://groups.yahoo.com/gads?t=ms&k=Auto...rs&w1\
sig=ePNVMmISsCWgTnMq_4GlXA>Automotive
> >radiators
> >YAHOO! GROUPS LINKS
> > * Visit your group
"<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\
> on the web.
Wanderl\
> <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo!
> Terms of Service.
>YAHOO! GROUPS LINKS
>SPONSORED LINKS
>vehicles
anderlodge
>maintenance
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
03-22-2006, 03:00
Television
I actually built a nice Cherry mounting pod to anchor the TV in that
takes the place of the old "thing" (dont know what to call it) that
was mounted on the doghouse originally. It works very well and the TV
works as it was intended for the last 2 years.
tom warner
1982 FC35
1985 PT40
At 09:23 PM 3/13/2006, you wrote:
>Years ago, when we had our 84 35fC, we set a color tv on the doghouse.
>Something happened to the color in that set.Is there any electrical
>field that may
>have interfered with the color on that tv- or was it the tv's time to go
>south? Ernie-83pt40 in louisiana
>SPONSORED LINKS
>vehicles
anderlodge
>maintenance
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
03-22-2006, 05:28
Television
I pulled the 'silver box' and the picture tube out of my coach. If
anyone would like it, ask and its yours.
I mounted a 5.6" color LCD in place of the interior rear view mirror
and connected that to the rear-view camera full time.
In place of the TV tuner control panel, I mounted the remote panel
for my Xantrex inverter/charger.
The original stereo equipment that was next to the TV is no more, a
fellow listee has it. My current head-end unit is in the center dash
next to the CB Radio, the system amplifier(s) are mounted where the
old system once was and tie into the existing speaker wiring at that
point.
I'll try to post some photos soon.
Tim Hannink
Winter Park, FL
1981 FC-33SB
have
system
for
as
> tom warner
> 1982 FC35
> 1985 PT40
03-22-2006, 07:26
Television
If the picture tube still works, I could use it. Mine died shortly
after I bought the coach last year. I'm guessing it is probably the
same size/model as in my 83. I'll gladly pay the shipping charge.
Phil Olson
83FC35SB
Appleton, WI
--- In WanderlodgeForum@yahoogroups.com, "Tim Hannink"
mirror
dash
that
> point.
> Tim Hannink
> Winter Park, FL
> 1981 FC-33SB
> have
original
> system
> for
> as
> > tom warner
> > 1982 FC35
> > 1985 PT40
03-22-2006, 07:44
Television
Tom,
Let me know how that works out, I'm thinking of doing the same thing on
mine.
I hear 'sparking' Noises coming from the "silver Box" when I plug the fuse
in (no wonder the fuse was missing)-So I was thinking of doing the same
thing as you-Upgrade to LCD- and get a color backup camera for the rear. I
'wandered' also, could I use the same camera cable that exists? Or would I
have to run another :-~
Stephen
81 FC-33SB
Plant City, FL
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner
Sent: Wednesday, March 22, 2006 9:58 AM
Subject: Re: [WanderlodgeForum] Television
tom warner
1982 FC35
1985 PT40
>tom warner
>1982 FC35
>Vernon Center,NY
> >this TV.
> >silver box.?
> >re brake 1983 FC-35
> >SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recr>
3&.sig=DAUkCKkU7Dzhn_ObWmSYTw>http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU
&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti
ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&
w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational
> >vehicles
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+v>
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8
HJdysB3QLPj9U0JvqYQ>http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2
=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
j9U0JvqYQ>
&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten
ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot
ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Rec>
63&.sig=IF4u_5wI8Pmy34cC1O9CxA>http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+
aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF
&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot
ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles
&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive
> >maintenance
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w>
onal+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=
6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati
&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au
tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh
icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreati
onal
> >vehicle dealer
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1>
&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio
&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut
omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi
cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recre>
&.sig=ePNVMmISsCWgTnMq_4GlXA>http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV
MmISsCWgTnMq_4GlXA>
&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv
e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w
6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automotive
> >radiators
> >YAHOO! GROUPS LINKS
> > * Visit your group
> on the web.
Wan
> Terms of Service.
>YAHOO! GROUPS LINKS
>SPONSORED LINKS
>vehicles
j9U0JvqYQ>
>maintenance
onal
>vehicle dealer
MmISsCWgTnMq_4GlXA>
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
web.
Wan
SPONSORED LINKS
Recreational
kCKkU7Dzhn_ObWmSYTw> vehicles
Wanderlodge
j9U0JvqYQ>
Automotive
4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer
Used
g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
MmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
_____
03-22-2006, 07:52
Television
I might be interested in them.. I live In Plant City-not too far.. I could
use them until I can get my new LCD system up and running!
Let me know. Would love to see pics when they are avail.. (or better yet, If
I get the monitor- I can see the coach in person!)
Stephen --Twin coach to yours-
81 FC-33SB
Plant City, Fl
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tim Hannink
Sent: Wednesday, March 22, 2006 12:28 PM
Subject: [WanderlodgeForum] Re: Television
point.
Tim Hannink
Winter Park, FL
1981 FC-33SB
SPONSORED LINKS
Recreational
Wanderlodge
j9U0JvqYQ>
Automotive
Recreational
Used
Automotive
_____
YAHOO! GROUPS LINKS
_____
03-22-2006, 07:55
Television
I'm sorry. Didn't see this post. Well, If he does not take the 'silver
box' Then I will I guess.
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of olson_phil
Sent: Wednesday, March 22, 2006 2:26 PM
Phil Olson
83FC35SB
Appleton, WI
mirror
dash
that
> point.
> Tim Hannink
> Winter Park, FL
> 1981 FC-33SB
> have
original
> system
> for
> as
> > tom warner
> > 1982 FC35
> > 1985 PT40
_____
YAHOO! GROUPS LINKS
_____
03-22-2006, 09:38
Television
Stephen, if you are local why don't you take the monitor. I'm
leaning towards replacing the whole works with a LCD monitor and new
camera anyway. I have been looking at rvcams.com, anyone use them
before or have a suggestion on where to get a system?
Phil Olson
83FC35SB
Appleton, WI
the 'silver
> _____
> Phil Olson
> 83FC35SB
> Appleton, WI
If
> mirror
panel
a
> dash
> that
> > point.
> > Tim Hannink
> > Winter Park, FL
> > 1981 FC-33SB
> > have
> original
> > system
> > for
system
> > as
> > > tom warner
> > > 1982 FC35
> > > 1985 PT40
> _____
> YAHOO! GROUPS LINKS
> subject=Unsubscribe>
> _____
