CB radio troubleshooting
09-09-2005, 07:10
I get no sound from the CB. I turn the squelch all the way both ways
but still no sound, not even static. When I press the transmit button
the power guage moves to the right as I would expect and when I
release the button I can hear a "pop" thru the speakers that are
closest to the driver and passenger. Also when I switch to "PA" mode
nothing happens. The CB is a "President" model AX44.
Troy, Waconia MN
1983 FC 33
09-09-2005, 07:20
Troy,
A couple things...is there is an external speaker plugged into the external
speaker jack at the rear of the radio? If there is, try unplugging it, and
see if the radio blows any squelch. If it does, your "Privacy" toggle switch
might be in the privacy position (this switch should be in the area of your
master a/c toggle switches (most likely above and to the left of the driver's
head). Plug the speaker jack back in, open the squelch, and try flipping the
"Privacy" switch. This could be the culprit. (Switches in the wrong
position usually are)
Ralph had a good idea also...you should get some noise from the speaker even
without an antenna with the squelch open, but you will get a lot more with
an antenna hooked up. If you don't have an antenna, just stick an old wire
clothes hanger in the center part of the antenna jack on the radio **Do not
transmit with this clothes wire antenna**...you will definitely hurt the
radio's transmitter.
If the radio is shot, they can be easily found at Radio Shack, or for a
really good selection, try Scanner World out of NY. Scannerworld.com I think.
Good luck!
Kevin McKeown
Yorba Linda, CA
1986 38' PT
N6PSY ham call
09-09-2005, 10:31
Troy:
If you have an old antenna laying around, try hooking that up to see if it
is your radio or antenna. It sounds like the finals are gone in the radio
though. Others on this forum are more versed in CB's/ Ham than I.
Ralph
>Troy, Waconia MN
>1983 FC 33
>Yahoo! Groups Links
Safe travels,
