How to Improve LXi Engine Cooling Performance
11-24-2013, 23:42
(This post was last modified: 11-25-2013 00:27 by travelite.)
Post: #31
RE: How to Improve LXi Engine Cooling Performance
(11-24-2013 22:23)al perna Wrote: Thanks , now how did you go about the 3/4 gal @ mile ? 13000 btu/min: heat power sunk to cac & cooling system at 500hp 40%: portion sunk by evaporative cooling 5200 btu/min: heat power absorbed by water 52 mph: desired speed 1.15 minutes to go 1 mile 6000 btu/mile sunk by water 970.40 btu/lb: water latent heat of vaporization 6.18 lb/mile: water 8.34 lb/gal: water 0.74 gallons of water per mile (11-24-2013 22:23)al perna Wrote: Now if we use 1 gal per mile and use it 25% of the grade s millage , how much water must we hold on a 8 mile climb at 118 degrees with a 8% Grade . ? you see I didn t even need it on a recent trip with many tough climbs this summer in Colorado . But I do think Chuck was asking for the ability to go faster , not over heat . That's right Al, the only reason to use it is to go faster. Personally I enjoy driving within the limits of the machine, but at the same time I understand Baker Hill. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
11-25-2013, 00:56
Post: #32
(11-24-2013 23:03)BirdPilot Wrote: My "new" LXi is an '01. Good shape as far as wear 'n tear, only 49k miles. Problem is, as far as I can tell, it's been sitting since '06. Lots of little items to find/fix as well as some higher dollar items. Just bought six coach batteries, should replace the tires. Wasn't thinking too clearly when I looked at it and almost no tire wear. Problem is date code 0706. That's great stuff! Thanks! david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
02-13-2014, 13:18
Post: #33
