					3208 Starter Source
					07-24-2011, 12:46
				3208 Starter Source
					Anyone know of a good source out west to pick up a new or rebuilt 3208 starter?
			My service sheet says the original was a Delco 1114826. I can find that starter with a Web search, but the source is on the east coast and says it is the starter for some kind of 3208-powered industrial equipment. Bob Griesel '84 FC31 WLII  |
					07-24-2011, 13:31
				3208 Starter Source
				 Hi Bob,
The little info I have says that part number is very common on Cat engines
I use this website a lot when I need information.
They show Caterpillar numbers to Delco numbers and a wealth of info.
Iââ¬â¢m not certain how you source stuff,but any good truck electric should supply it,even NAPA
Fred Hulse Morristown,Arizona 97 WLWB41  |
					07-24-2011, 16:06
				3208 Starter Source
					Thanks Fred!
			--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Hi Bob, > > The little info I have says that part number is very common on Cat engines > http://www.dixie-electric.com/catalog/Di...Series.pdf > > I use this website a lot when I need information. > They show Caterpillar numbers to Delco numbers and a wealth of info. > > Iââ¬â¢m not certain how you source stuff,but any good truck electric should supply it,even NAPA > > Fred Hulse > Morristown,Arizona > 97 WLWB41 >  |
					07-26-2011, 15:06
				3208 Starter Source
					Hi Bob,
			I'm not sure where you are located, but I had mine rebuilt last year here in Dallas. I found the starter place that I've used for other starters could handle the big Cat starter. Anyway, I can look up the contact information if something here helps you. Otherwise you might find out like I did that your local starter rebuilder can help you out. alan 87FC35 in Dallas --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > Anyone know of a good source out west to pick up a new or rebuilt 3208 starter? My service sheet says the original was a Delco 1114826. I can find that starter with a Web search, but the source is on the east coast and says it is the starter for some kind of 3208-powered industrial equipment. > > Bob Griesel '84 FC31 WLII >  |
					07-26-2011, 17:22
				3208 Starter Source
					Thanks Alan. NAPA fixed me up with a reman.  Its in and working fine.
			Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" > > Hi Bob, > > I'm not sure where you are located, but I had mine rebuilt last year here in Dallas. I found the starter place that I've used for other starters could handle the big Cat starter. > > Anyway, I can look up the contact information if something here helps you. Otherwise you might find out like I did that your local starter rebuilder can help you out. > > alan > 87FC35 in Dallas > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > > > Anyone know of a good source out west to pick up a new or rebuilt 3208 starter? My service sheet says the original was a Delco 1114826. I can find that starter with a Web search, but the source is on the east coast and says it is the starter for some kind of 3208-powered industrial equipment. > > > > Bob Griesel '84 FC31 WLII > > >  |
