Low Water Pressure
10-25-2010, 10:46
Low Water Pressure
Agree.
Safe travels, Ralph &
Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
-----Original Message-----
Sender: WanderlodgeForum@yahoogroups.com
Date: Mon, 25 Oct 2010 22:38:53
To:
Reply-To: WanderlodgeForum@yahoogroups.com
Subject: [WanderlodgeForum] Low water pressure
I haven't taken the bus out since Labor Day, but had occasion to be in it over
the weekend. When I used the water, the water pump ran continuously and the
water pressure was low at all faucets. Soooo, I assume the wonderful Sporlan
valve has struck once again and is stuck. Anyone agree or disagree?
Thanks,
1991 WB40 "Texas Minivan"
Yahoo! Groups Links
10-25-2010, 10:50
Low Water Pressure
me too- unless you have water coming out the water fill- which could be the check valve.
Ernie fix: stick a screwdriver in the inlet and move the valve- a little calcium deposit can hurt ya.
Ernie, Pine Mountain, Ga
Brenda- at ATL waiting on crew to show up. Wonder if crew got last weeks paycheck??
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Mon, 10/25/10, Ralph wrote:
Subject: Re: [WanderlodgeForum] Low water pressure
To: "Wanderlodge Forum"
Date: Monday, October 25, 2010, 5:46 PM
Agree.
Safe travels, Ralph & Charolette Fullenwider
Duncan, Oklahoma
To: <WanderlodgeForum@yahoogroups.com>
I haven't taken the bus out since Labor Day, but had occasion to be in it over the weekend. When I used the water, the water pump ran continuously and the water pressure was low at all faucets. Soooo, I assume the wonderful Sporlan valve has struck once again and is stuck. Anyone agree or disagree?
Thanks,
Yahoo! Groups Links
10-25-2010, 10:58
Low Water Pressure
I had that happen once in a while. I
found that by setting the switch to shore water while filling the tank, turning
on the pump until I hear it pick up water, I have not had the problem since. I
drain the water each time we return home to prevent the “sour” water smell and
I think that at times I was getting an air lock where the pump couldn’t get
primed.
- Chuck
Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ernie Ekberg
Sent: Monday, October 25, 2010
5:51 PM
Low water pressure
Ernie, Pine
Mountain
, Ga
83PT40
Wanderlodge
--- On Mon, 10/25/10, Ralph <rlf47@...>
Agree.
Duncan, Oklahoma
Thanks,
1991 WB40 "Texas
Minivan"
Yahoo! Groups Links
