Any Idea's
06-20-2005, 02:30
Any Idea's
I went out yesterday and I was going to fill the diesel and my
regular gas tank and ran into a problem? My bird is 33 foot long and it has a Diesel engine and a gas generator and there for I have two tanks. I filled the diesel tank up but when I went to fill the gas tank up I could not get the pump hose into the proper location to fill up the tank. I have a lockable door that opens and the fill pipe is located inside and below that door. I cannot get the nozzel to fit on the pipe tight and part of the fuel that I was pumping just ran over the side of the gas tank pipe opening. I think this is because of the new type of nozzels used today have a rubber seat on them and I can not get this into the location of this fill pipe. Anybody have this same problem? I can always fill by using a 5 gallon fuel can but does anyone know of another way? Jon Jon Lechich 1978 Wanderlodge Back-door (Rebel Bird) Bremerton Washington |
06-20-2005, 05:15
Any Idea's
Jon,
See if a muffler shop can bend/fabricate a piece of steel pipe to act as an extension tube you could fit into the opening and then put the fuel filler nozzle in the extension tube. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "Jon" > I went out yesterday and I was going to fill the diesel and my > regular gas tank and ran into a problem? > > My bird is 33 foot long and it has a Diesel engine and a gas > generator and there for I have two tanks. > > I filled the diesel tank up but when I went to fill the gas tank up I > could not get the pump hose into the proper location to fill up the > tank. I have a lockable door that opens and the fill pipe is located > inside and below that door. I cannot get the nozzel to fit on the > pipe tight and part of the fuel that I was pumping just ran over the > side of the gas tank pipe opening. I think this is because of the new > type of nozzels used today have a rubber seat on them and I can not > get this into the location of this fill pipe. Anybody have this same > problem? > > I can always fill by using a 5 gallon fuel can but does anyone know > of another way? Jon > > Jon Lechich > 1978 Wanderlodge > Back-door (Rebel Bird) > Bremerton Washington |
06-20-2005, 05:22
Any Idea's
I know other BB owners that have this same configuration of diesel coach
engine and gas generator and they are not having this problem. Why not take a picture of your filler tube and post it on the forum for us to see. tom 1982 FC35 Vernon Center,NY At 05:15 PM 6/20/2005 +0000, you wrote: >Jon, > See if a muffler shop can bend/fabricate a piece of steel >pipe to act as an extension tube you could fit into the opening >and then put the fuel filler nozzle in the extension tube. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > >--- In WanderlodgeForum@yahoogroups.com, "Jon" > > I went out yesterday and I was going to fill the diesel and my > > regular gas tank and ran into a problem? > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > generator and there for I have two tanks. > > > > I filled the diesel tank up but when I went to fill the gas tank up I > > could not get the pump hose into the proper location to fill up the > > tank. I have a lockable door that opens and the fill pipe is located > > inside and below that door. I cannot get the nozzel to fit on the > > pipe tight and part of the fuel that I was pumping just ran over the > > side of the gas tank pipe opening. I think this is because of the new > > type of nozzels used today have a rubber seat on them and I can not > > get this into the location of this fill pipe. Anybody have this same > > problem? > > > > I can always fill by using a 5 gallon fuel can but does anyone know > > of another way? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > Back-door (Rebel Bird) > > Bremerton Washington > > > > > >Yahoo! Groups Links > > > > |
06-20-2005, 06:27
Any Idea's
Jon, How about a piece of plastic hose which fits on tho the pump
nosle? Just do't drop it in to the tank. Kurt Not having the problem '35FC35 --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > Jon, > See if a muffler shop can bend/fabricate a piece of steel > pipe to act as an extension tube you could fit into the opening > and then put the fuel filler nozzle in the extension tube. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I went out yesterday and I was going to fill the diesel and my > > regular gas tank and ran into a problem? > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > generator and there for I have two tanks. > > > > I filled the diesel tank up but when I went to fill the gas tank up I > > could not get the pump hose into the proper location to fill up the > > tank. I have a lockable door that opens and the fill pipe is located > > inside and below that door. I cannot get the nozzel to fit on the > > pipe tight and part of the fuel that I was pumping just ran over the > > side of the gas tank pipe opening. I think this is because of the new > > type of nozzels used today have a rubber seat on them and I can not > > get this into the location of this fill pipe. Anybody have this same > > problem? > > > > I can always fill by using a 5 gallon fuel can but does anyone know > > of another way? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > Back-door (Rebel Bird) > > Bremerton Washington |
06-20-2005, 08:49
Any Idea's
Clear plastic hose-sounds good! Jon
Kurt Achenbach fits on tho the pump nosle? Just do't drop it in to the tank. Kurt Not having the problem '35FC35 --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" wrote: > Jon, > See if a muffler shop can bend/fabricate a piece of steel > pipe to act as an extension tube you could fit into the opening > and then put the fuel filler nozzle in the extension tube. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" wrote: > > I went out yesterday and I was going to fill the diesel and my > > regular gas tank and ran into a problem? > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > generator and there for I have two tanks. > > > > I filled the diesel tank up but when I went to fill the gas tank up I > > could not get the pump hose into the proper location to fill up the > > tank. I have a lockable door that opens and the fill pipe is located > > inside and below that door. I cannot get the nozzel to fit on the > > pipe tight and part of the fuel that I was pumping just ran over the > > side of the gas tank pipe opening. I think this is because of the new > > type of nozzels used today have a rubber seat on them and I can not > > get this into the location of this fill pipe. Anybody have this same > > problem? > > > > I can always fill by using a 5 gallon fuel can but does anyone know > > of another way? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > Back-door (Rebel Bird) > > Bremerton Washington Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football [Non-text portions of this message have been removed] |
06-20-2005, 09:45
Any Idea's
How about a piece of 1 1/2" pvc that would fit below the cap, but could be
pulled up for an extension. The nozzle weight should hold it in place while filling. Glenn Shehorn 83FC35 Kansas City Mo ----- Original Message ----- From: jon lechich To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 20, 2005 3:49 PM Subject: Re: [WanderlodgeForum] Re: Any Idea's Clear plastic hose-sounds good! Jon Kurt Achenbach which fits on tho the pump nosle? Just do't drop it in to the tank. Kurt Not having the problem '35FC35 --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" wrote: > Jon, > See if a muffler shop can bend/fabricate a piece of steel > pipe to act as an extension tube you could fit into the opening > and then put the fuel filler nozzle in the extension tube. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" wrote: > > I went out yesterday and I was going to fill the diesel and my > > regular gas tank and ran into a problem? > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > generator and there for I have two tanks. > > > > I filled the diesel tank up but when I went to fill the gas tank up I > > could not get the pump hose into the proper location to fill up the > > tank. I have a lockable door that opens and the fill pipe is located > > inside and below that door. I cannot get the nozzel to fit on the > > pipe tight and part of the fuel that I was pumping just ran over the > > side of the gas tank pipe opening. I think this is because of the new > > type of nozzels used today have a rubber seat on them and I can not > > get this into the location of this fill pipe. Anybody have this same > > problem? > > > > I can always fill by using a 5 gallon fuel can but does anyone know > > of another way? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > Back-door (Rebel Bird) > > Bremerton Washington Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-20-2005, 10:20
Any Idea's
kind of a custom funnel,we used them all the time in race cars..randydupree93wb
----- Original Message ----- From: mrdonut12 To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 20, 2005 1:15 PM Subject: [WanderlodgeForum] Re: Any Idea's Jon, See if a muffler shop can bend/fabricate a piece of steel pipe to act as an extension tube you could fit into the opening and then put the fuel filler nozzle in the extension tube. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "Jon" > I went out yesterday and I was going to fill the diesel and my > regular gas tank and ran into a problem? > > My bird is 33 foot long and it has a Diesel engine and a gas > generator and there for I have two tanks. > > I filled the diesel tank up but when I went to fill the gas tank up I > could not get the pump hose into the proper location to fill up the > tank. I have a lockable door that opens and the fill pipe is located > inside and below that door. I cannot get the nozzel to fit on the > pipe tight and part of the fuel that I was pumping just ran over the > side of the gas tank pipe opening. I think this is because of the new > type of nozzels used today have a rubber seat on them and I can not > get this into the location of this fill pipe. Anybody have this same > problem? > > I can always fill by using a 5 gallon fuel can but does anyone know > of another way? Jon > > Jon Lechich > 1978 Wanderlodge > Back-door (Rebel Bird) > Bremerton Washington ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-20-2005, 11:27
Any Idea's
--- In WanderlodgeForum@yahoogroups.com, jon lechich
wrote: > Clear plastic hose-sounds good! Jon No, it doesn't. The filler nozzle has an air bleed for the automatic shut-off. If the air bleed is blocked, it thinks the tank is full and shuts off the gas. George Witt 81 FC 35 Lincoln, Nebraska > > Kurt Achenbach hose which fits on tho the pump > nosle? Just do't drop it in to the tank. > Kurt > Not having the problem > '35FC35 > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" > wrote: > > Jon, > > See if a muffler shop can bend/fabricate a piece of steel > > pipe to act as an extension tube you could fit into the opening > > and then put the fuel filler nozzle in the extension tube. > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" wrote: > > > I went out yesterday and I was going to fill the diesel and my > > > regular gas tank and ran into a problem? > > > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > > generator and there for I have two tanks. > > > > > > I filled the diesel tank up but when I went to fill the gas tank > up I > > > could not get the pump hose into the proper location to fill up > the > > > tank. I have a lockable door that opens and the fill pipe is > located > > > inside and below that door. I cannot get the nozzel to fit on > the > > > pipe tight and part of the fuel that I was pumping just ran over > the > > > side of the gas tank pipe opening. I think this is because of the > new > > > type of nozzels used today have a rubber seat on them and I can > not > > > get this into the location of this fill pipe. Anybody have this > same > > > problem? > > > > > > I can always fill by using a 5 gallon fuel can but does anyone > know > > > of another way? Jon > > > > > > Jon Lechich > > > 1978 Wanderlodge > > > Back-door (Rebel Bird) > > > Bremerton Washington > > > > > > Yahoo! Groups Links > > > > > > > > > > > One of my favorite sayings goes! "You never own anything, everything owns you!" > > > > > > --------------------------------- > Yahoo! Sports > Rekindle the Rivalries. Sign up for Fantasy Football > > [Non-text portions of this message have been removed] |
06-20-2005, 16:40
Any Idea's
Does anyone here have a problem with fueling up there 31 or 33 foot Wanderlodges
as far as the gas goes? Just wondering as I posted something today about that I have trouble placing the fuel nozzel in place to refill gas tank. jon lechich Kurt Achenbach wrote:Jon, How about a piece of plastic hose which fits on tho the pump nosle? Just do't drop it in to the tank. Kurt Not having the problem '35FC35 --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" wrote: > Jon, > See if a muffler shop can bend/fabricate a piece of steel > pipe to act as an extension tube you could fit into the opening > and then put the fuel filler nozzle in the extension tube. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" wrote: > > I went out yesterday and I was going to fill the diesel and my > > regular gas tank and ran into a problem? > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > generator and there for I have two tanks. > > > > I filled the diesel tank up but when I went to fill the gas tank up I > > could not get the pump hose into the proper location to fill up the > > tank. I have a lockable door that opens and the fill pipe is located > > inside and below that door. I cannot get the nozzel to fit on the > > pipe tight and part of the fuel that I was pumping just ran over the > > side of the gas tank pipe opening. I think this is because of the new > > type of nozzels used today have a rubber seat on them and I can not > > get this into the location of this fill pipe. Anybody have this same > > problem? > > > > I can always fill by using a 5 gallon fuel can but does anyone know > > of another way? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > Back-door (Rebel Bird) > > Bremerton Washington Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football [Non-text portions of this message have been removed] Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
06-20-2005, 23:46
Any Idea's
John, I have a 1981 31' and have not had a problem. As I'm traveling across
country right now, that includes a # of states. I can forward you a picture of my filler if you'd like so you can compare. Al S. Now in Charleston, SC From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jon lechich Sent: Tuesday, June 21, 2005 12:41 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Any Idea's Does anyone here have a problem with fueling up there 31 or 33 foot Wanderlodges as far as the gas goes? Just wondering as I posted something today about that I have trouble placing the fuel nozzel in place to refill gas tank. jon lechich Kurt Achenbach wrote:Jon, How about a piece of plastic hose which fits on tho the pump nosle? Just do't drop it in to the tank. Kurt Not having the problem '35FC35 --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" wrote: > Jon, > See if a muffler shop can bend/fabricate a piece of steel > pipe to act as an extension tube you could fit into the opening > and then put the fuel filler nozzle in the extension tube. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" wrote: > > I went out yesterday and I was going to fill the diesel and my > > regular gas tank and ran into a problem? > > > > My bird is 33 foot long and it has a Diesel engine and a gas > > generator and there for I have two tanks. > > > > I filled the diesel tank up but when I went to fill the gas tank up I > > could not get the pump hose into the proper location to fill up the > > tank. I have a lockable door that opens and the fill pipe is located > > inside and below that door. I cannot get the nozzel to fit on the > > pipe tight and part of the fuel that I was pumping just ran over the > > side of the gas tank pipe opening. I think this is because of the new > > type of nozzels used today have a rubber seat on them and I can not > > get this into the location of this fill pipe. Anybody have this same > > problem? > > > > I can always fill by using a 5 gallon fuel can but does anyone know > > of another way? Jon > > > > Jon Lechich > > 1978 Wanderlodge > > Back-door (Rebel Bird) > > Bremerton Washington Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football [Non-text portions of this message have been removed] Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] |
User(s) browsing this thread: 15 Guest(s)
