					Allison HTB741 fluid change
					03-04-2009, 09:33
					Can anyone tell me what I should pay to drain and refill with transynd?   Is it
			easy to do or does a shop have to do the work? Thanks Dan Williams, 88wb38, Jackson, MS  |
					03-04-2009, 10:45
					There are filters inside the 'pan' of the transmission that need to be replaced. If your transmission is like mine, the filters come in two sizes. A longer lasting version and a smaller (cheaper) version. Since we'll not be putting the miles on like a transit bus, it's best to get the cheaper small size as you'll "time out" before you "mile out" ...
			You can probably do it yourself, but personally, I prefer to let an experienced technician in a suitably qualified shop do the work as they have the lift or pit that makes access easier. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Mar 4, 2009, at 1:33 PM, maureyroad wrote:
					03-04-2009, 12:12
					Dan,
			When I did mine, I drove up on 2x10's(one layer), bags down, and got to it. Many bolts later, after the drain plug was used, the pan came off. At the dd shop, they said reuse the gasket, if it wasn't torn and wash the filter(it was a metal screen). They sold me the fluid($38@gal.) I bought the filter from NAPA. Oh, it took 7 gallons. They also said, do it again after 5 to 10k miles, as you don't get everything in the first change,coolers, torque converter, etc. You will see a noticeable difference in temp after. I'm almost due for the second change and I hate to see the price of the fluid now. 20/20 hindsight, I should have bought enough fluid for 2 changes and a couple of spares,in case of a leak. Easy job. Steve Gureasko 90WBWL40 Jus Chillin Ponchatoula, La.  |
					03-04-2009, 13:37
				 It's easier to do than a car, allisons have a good sized drain plug and there is alot of room under there to work. just slide a big plastic tote under there and pull the plug. When refilling with fluid you will reach a point where you have to start the engine to get the rest of thefluid in. There is an internal filter and a magnet inside the pan that would reguire dropping the pan if you want to change that filter and clean the magnet.
Wayne
From: maureyroad To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, March 4, 2009 3:33:14 PM Subject: [WanderlodgeForum] Allison HTB741 fluid change Can anyone tell me what I should pay to drain and refill with transynd? Is it easy to do or does a shop have to do the work? Thanks Dan Williams, 88wb38, Jackson, MS  |
					03-04-2009, 15:02
				 Pete, the local Allison shop quoted $571 Dan Williams, 88WB38, Jackson, MS From:  There are filters inside the 'pan' of the transmission that need to be replaced. If your transmission is like mine, the filters come in two sizes. A longer lasting version and a smaller (cheaper) version. Since we'll not be putting the miles on like a transit bus, it's best to get the cheaper small size as you'll "time out" before you "mile out" ... You can probably do it yourself, but personally, I prefer to let an Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For  El Sobrante CA "aeonix1@mac.com" On Mar 4, 2009, at 1:33 PM, maureyroad wrote:
 Can anyone tell me what I should pay to drain and refill with transynd?  |
					03-04-2009, 15:16
				 Steve, I was reading the Allison filter Thanks, Dan Williams, 88WB38, Jackson, MS From:  Dan, When I did mine, I drove up on 2x10's(one layer), bags down, and got to it. Many bolts later, after the drain plug was used, the pan came off. At the dd shop, they said reuse the gasket, if it wasn't torn and wash the filter(it was a metal screen). They sold me the fluid($38@gal. They also said, do it again after 5 to 10k miles, as you don't get everything in the first change,coolers, torque converter, etc. You will see a noticeable difference in temp after. I'm almost due for the second change and I hate to see the price of the fluid now. 20/20 hindsight, I should have bought enough fluid for 2 changes and a couple of spares,in case of a leak. Easy job. Steve Gureasko 90WBWL40 Jus Chillin  |
					03-04-2009, 15:21
				 Thanks  Dan Williams, 88WB38,  From:  It's easier to do than a car, allisons have a good sized drain plug and From: Can anyone tell me what I should pay to drain and refill with transynd? Is it easy to do or does a shop have to do the work? Thanks Dan Williams, 88wb38,  |
					03-04-2009, 15:41
					Industrial Automatic Transmission in Irving, TX charged me $354.00 for the
			job. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "maureyroad" > > Can anyone tell me what I should pay to drain and refill with transynd? Is it easy to do or does a shop have to do the work? Thanks > Dan Williams, 88wb38, Jackson, MS >  |
					03-04-2009, 15:48
					It seem high to me too... but a big part of the expense is the Transynd fluid:
			Here's what CCW-Riverside charged for the transmission service I had in May of 08: 2 hour labor @90.00 per hour  ..... $180.00 Transynd fluid, 8 (gallons)     ..... $208.00 33120 trans filter (secondary)  ..... $   6.46 33118 trans filter (primary)    ..... $   6.67 For a total of .................................. $401.13 Since I have a DD Series 60, I may have a different transmission (that may have a different fluid capacity). Way back in late 06, I had a local shop service the transmission (I forgot I'd had it done when I requested CCW to do it -- I probably could have waited longer, since the recommendation is every 48 months, as I recall at the moment.) Anyway, they charged Labor (time not stated)       $110.00 Dextron III ATF, 39 qts,        $126.75 Trans Filter Kit PT8515-MPGKIT  $152.85 total . . . . . . . . . . . . . . . . . . . . .  $389.60 However, that did not include the synthetic ATF, but dino-type instead. It's interesting to note that the earlier place charged a fortune for the filters (they commented that they'd had trouble locating them locally). They installed the more expensive "long life" transmission filters. They're rated for a zillion miles, but with the 48 month replacement schedule, you'll never get the value out of them. So, $571 doesn't seem totally out of line, merely somewhat high. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Mar 4, 2009, at 7:02 PM, Dan Williams wrote:
					03-04-2009, 16:35
					$208 for 8 gallons of real Transynd would be a steal, this year or last. As I
			recall, CCW pulls from bulk, and it is impossible to know what you got. On 3/4/2009 at 7:48 PM Pete Masterson wrote: >It seem high to me too... but a big part of the expense is the >Transynd fluid: > >Here's what CCW-Riverside charged for the transmission service I had >in May of 08: >2 hour labor @90.00 per hour ..... $180.00 >Transynd fluid, 8 (gallons) ..... $208.00 >33120 trans filter (secondary) ..... $ 6.46 >33118 trans filter (primary) ..... $ 6.67 > >For a total of .................................. $401.13 > >Since I have a DD Series 60, I may have a different transmission (that >may have a different fluid capacity). > >Way back in late 06, I had a local shop service the transmission (I >forgot I'd had it done when I requested CCW to do it -- I probably >could have waited longer, since the recommendation is every 48 months, >as I recall at the moment.) > >Anyway, they charged >Labor (time not stated) $110.00 >Dextron III ATF, 39 qts, $126.75 >Trans Filter Kit PT8515-MPGKIT $152.85 > >total . . . . . . . . . . . . . . . . . . . . . $389.60 > >However, that did not include the synthetic ATF, but dino-type instead. > >It's interesting to note that the earlier place charged a fortune for >the filters (they commented that they'd had trouble locating them >locally). They installed the more expensive "long life" transmission >filters. They're rated for a zillion miles, but with the 48 month >replacement schedule, you'll never get the value out of them. > >So, $571 doesn't seem totally out of line, merely somewhat high. > >Pete Masterson >'95 Blue Bird Wanderlodge WBDA 42 (For Sale) ><http://www.aeonix.biz/BBforsale.html> >El Sobrante CA >aeonix1@... > > > > >On Mar 4, 2009, at 7:02 PM, Dan Williams wrote: > >> Pete, the local Allison shop quoted $571 for drain and fill with >> filter. I asked if it included any service besides the drain and >> fill and he said no. It seems a little high to me but what do you >> think? >> Dan Williams, 88WB38, Jackson, MS >> >> From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com >> ] On Behalf Of Pete Masterson >> Sent: Wednesday, March 04, 2009 4:45 PM >> To: WanderlodgeForum@yahoogroups.com >> Subject: Re: [WanderlodgeForum] Allison HTB741 fluid change >> >> There are filters inside the 'pan' of the transmission that need to >> be replaced. If your transmission is like mine, the filters come in >> two sizes. A longer lasting version and a smaller (cheaper) version. >> Since we'll not be putting the miles on like a transit bus, it's >> best to get the cheaper small size as you'll "time out" before you >> "mile out" ... >> >> >> You can probably do it yourself, but personally, I prefer to let an >> experienced technician in a suitably qualified shop do the work as >> they have the lift or pit that makes access easier. >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 (For Sale) >> <http://www.aeonix.biz/BBforsale.html> >> El Sobrante CA >> aeonix1@... >> >> >> >> On Mar 4, 2009, at 1:33 PM, maureyroad wrote: >> >> >> Can anyone tell me what I should pay to drain and refill with >> transynd? Is it easy to do or does a shop have to do the work? >> Thanks >> Dan Williams, 88wb38, Jackson, MS >> >> >> >>  |
