changing gen diesel filters
01-10-2009, 12:21
thanks for your help on the compressor. i ordered the rebuild kit.
today i changed the oil and filters on the bus motor and serviced the genarator. i have the fuel filters for the gen but was afraid of changing them. i have had so many problems with small diesel motors after breaking the fuel lines. is there any method of changing these filters without having problems starting after the change? thanks. robert rahn 88 pt 40 kalispell, mt |
01-10-2009, 12:50
01-10-2009, 13:09
When I changed the fuel filter on my PowerTech generator (Kubota diesel engine), I made sure that I filled the spin-on fuel filter to the brim with diesel just before putting it on, trying to spill as little as possible.
The engine started up with only a slightly longer effort than usual -- I presume that it was due to the small amount of air in the fuel line. But then, I didn't know that there might be a problem... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Jan 10, 2009, at 4:21 PM, Robert Rahn wrote:
01-10-2009, 15:00
the injectors are cooled with diesel so the pump will put out more
than the fire needs. if it wont start right off after you remount a filter, crack the lines at the injectors. turn it over untill it messes up and sprays no air than snug them and start. with it running, crack one open at a time and tighten it for good. if the genset is way dry it wont hurt to presoak the fuel line atop of the injector with a bit of PBblaster overnight. I presoak all projects so I wont be able to tell you if it helps. I add a mix of 50/50 diesel/atf in the filter to clean the injectors. I dont like to put injector cleaner solvents in the tank in fear that it will clean the tank pushing crap at the filter. Gregory ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Robert Rahn" > > thanks for your help on the compressor. i ordered the rebuild kit. > > today i changed the oil and filters on the bus motor and serviced the genarator. i have the > fuel filters for the gen but was afraid of changing them. i have had so many problems with > small diesel motors after breaking the fuel lines. is there any method of changing these > filters without having problems starting after the change? thanks. > > robert rahn > 88 pt 40 > kalispell, mt > |
01-10-2009, 15:14
Hey Tim & Greg. Any update on your Q 2009 ETA?
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Sat, Jan 10, 2009 at 7:00 PM, timvasqz <"Petrover1@aol.com"> wrote:
01-10-2009, 15:26
Curt,Tim wants to go 21 but I got community service that day. I
might have him slow down and pick me up roadside on the way out. GregoryO'Connor ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Hey Tim & Greg. Any update on your Q 2009 ETA? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > On Sat, Jan 10, 2009 at 7:00 PM, timvasqz > > > the injectors are cooled with diesel so the pump will put out more > > than the fire needs. if it wont start right off after you remount a > > filter, crack the lines at the injectors. turn it over untill it > > messes up and sprays no air than snug them and start. with it > > running, crack one open at a time and tighten it for good. > > if the genset is way dry it wont hurt to presoak the fuel line atop > > of the injector with a bit of PBblaster overnight. I presoak all > > projects so I wont be able to tell you if it helps. > > > > I add a mix of 50/50 diesel/atf in the filter to clean the > > injectors. I dont like to put injector cleaner solvents in the tank > > in fear that it will clean the tank pushing crap at the filter. > > Gregory ofTim&Greg 94ptca > > > > --- In WanderlodgeForum@yahoogroups.com > > "Robert Rahn" > > > > > > > > thanks for your help on the compressor. i ordered the rebuild kit. > > > > > > today i changed the oil and filters on the bus motor and serviced > > the genarator. i have the > > > fuel filters for the gen but was afraid of changing them. i have > > had so many problems with > > > small diesel motors after breaking the fuel lines. is there any > > method of changing these > > > filters without having problems starting after the change? thanks. > > > > > > robert rahn > > > 88 pt 40 > > > kalispell, mt > > > > > > > > > > |
