High beams on dim
11-10-2008, 12:13
High beams on dim
Hi group,
Has anybody had this problem?
Turn on headlights and low beams come on ok, but high beams also come
on very faintly.
So far have had replaced dimmer switch, headlight switch, all 4
headlights but no go.
If take the low beams out, the high beam goes off..plug in low beam and
high comes back on. This holds true for both sides.
Any thoughts?
Bob Lawrence
84 PT 36
On the road fulltiming
11-10-2008, 12:28
High beams on dim
Ground.
Regards, Bruce Morris in Raleigh, NC
Webmaster - Wanderlodge Owners Online
Vietnam Vet 1966-67 Navy "Doc" 3rd MarDiv
1983 FC35RB FMCA #7142s
Sent: Monday, November 10, 2008 7:13 PM
Subject: [WanderlodgeForum] High beams on dim
Hi group,
on very faintly.
Any thoughts?
Bob Lawrence
84 PT 36
11-10-2008, 12:30
High beams on dim
Have your headlights been rewired thought a relay?If not it may be
time to do so.
Bob Loomas
1985 PT 36
> Hi group,
come
> on very faintly.
> Any thoughts?
> Bob Lawrence
> 84 PT 36
11-10-2008, 12:48
High beams on dim
Bruce,
You are absolutely correct, this is a classic bad ground symptom.
Gardner
83FC35
--- In WanderlodgeForum@yahoogroups.com, "Bruce Morris" <bamnc@...>
> Ground.
> From: Bob Lawrence
> Hi group,
come
> on very faintly.
beam and
> Any thoughts?
> Bob Lawrence
> 84 PT 36
11-11-2008, 14:36
High beams on dim
Well, got the high beam on dim problem fixed by Ralph here in Duncan,
Ok.
Turns out a previous owner had made the headlight mod ok, but swapped
wires (high to low) on one side and swapped them wrong on the other
side. Also a ground wire wasn't that well grounded.
This problem has been on the bird for about 9 years before it got fixed
today.
Kudos to Ralph for finding this problem. This guy can find ANY electric
problem.
Bob Lawrence
84 PT 36
Duncan, Ok
> Bruce,
> Gardner
> 83FC35
11-11-2008, 16:44
High beams on dim
Bob,
Thank you for the update. Glad it's fixed.
On Tue, Nov 11, 2008 at 6:36 PM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
Ok.
today.
problem.
Bob Lawrence
84 PT 36
Duncan, Ok
> Bruce,
> Gardner
> 83FC35
Curt Sprenger
Anaheim Hills, CA
