Gen Fan Relay
05-23-2005, 03:58
Gen Fan Relay
Derk,
If you are getting 120 volts on both legs you're getting 240 volts from the genset. Sounds like the fan (blower on mine) is not getting current or is defective. Bill in Roanoke, VA 1987 FC-35 12.5 Kohler with Yanmar engine [Non-text portions of this message have been removed] |
05-23-2005, 05:20
Gen Fan Relay
Ok I'm confused, if there is no thermostat relay to turn the fan motor
on how will the diesel engine get up to operating temp? The other reply says that it in the neck set which is where? Derk 79FC 35 |
05-23-2005, 06:04
Gen Fan Relay
The perkins engine has a thermostat valve in the return to the radiator
like most engines, doesn't open until the engine is warm enough to require radiator cooling. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "derkallaben" wrote: > Ok I'm confused, if there is no thermostat relay to turn the fan motor > on how will the diesel engine get up to operating temp? The other reply > says that it in the neck set which is where? > Derk > 79FC 35 |
05-23-2005, 06:48
Gen Fan Relay
I have a '85 12.5 Kohler and from the neck to the expansion tank is
mounted a Kysor thermo switch. There is a 1/2" pipe coming off the top of the block that tee's , one to the expansion tank, the other is where the switch is mounted. That is how mine is set up. Not saying yours is that way. I will look at mine tonight to see if there is a thermostat. I do not know what they did in '79 just trying to help. >>> dallaben@... 05/23/05 1:20 PM >>> Ok I'm confused, if there is no thermostat relay to turn the fan motor on how will the diesel engine get up to operating temp? The other reply says that it in the neck set which is where? Derk 79FC 35 Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. |
05-23-2005, 07:49
Gen Fan Relay
Ok the the electric fan on the radiator is suppose to run all of the
time the genset is on, if the genset is making 220 and the thermostat opens and closes like it should. How can I tell if I am making 220? I know I am getting 115 out of the genset. Derk 79FC 35 |
05-23-2005, 09:25
Gen Fan Relay
Hi Bill in Roanoke,
Just curious, I thought all 87,88, 89FC's had the 8.0 k Onan. Bill in Michigan 88 FC --- In WanderlodgeForum@yahoogroups.com, racin41@a... wrote: > Derk, > > If you are getting 120 volts on both legs you're getting 240 volts from the > genset. Sounds like the fan (blower on mine) is not getting > current or is defective. > > Bill in Roanoke, VA > 1987 FC-35 12.5 Kohler with Yanmar engine > > > [Non-text portions of this message have been removed] |
05-23-2005, 12:09
Gen Fan Relay
The 8.0 Onan became standard in the FC in '88, streetside, along with
2 roof A/Cs. The 12.5kw on a streetside slideout (side-bath) or curbside (rear bath) was still optional as were triple roof A/Cs. http://www.millercoachworks.com/Silver.html - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Hi Bill in Roanoke, > > Just curious, > I thought all 87,88, 89FC's had the > 8.0 k Onan. > > Bill in Michigan 88 FC > > --- In WanderlodgeForum@yahoogroups.com, racin41@a... wrote: > > Derk, > > > > If you are getting 120 volts on both legs you're getting 240 volts > from the > > genset. Sounds like the fan (blower on mine) is not getting > > current or is defective. > > > > Bill in Roanoke, VA > > 1987 FC-35 12.5 Kohler with Yanmar engine > > > > > > [Non-text portions of this message have been removed] |
