					Alcoa Wheels
					03-02-2008, 04:38
				 Post: #11 | |||
| Alcoa Wheels
					As long as the wheels turn out to be in good condition I should be Ok with what I am going after. I talked to BB and the everything seems a go. This fellow is closer so unless trouble develops I will going to get them in a week or two. I will need longer studs but otherwise should be a direct cross over. Thanks and if for some reason....I'll be in touch. John Heckman central Pa 1973 FC. > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > >I have four firestone original oem 85 pt40 22.5X8.25 Lee > Condosta85PT40 Holden Beach N.C > > I've been lookin' for a while and I have a lead which might work out. > > Quick question. My ole 73 has the axles off a 1984 I believe. I am > > assuming that the wheels will fit. The alcoa's are off a BB bus. > > Before I get into this too deep would the wheels on the pushers be > the > > same as the FC's? I know I have not provided much information but if > > the wheels on the pushers don't fit the FC's then my hunt continues. > My > > bus has 22.5 inch steel wheels. Ten bolt stud piloted but beyond that > I > > will have to reseach. Thanks in advance. > > John Heckman > > central Pa > > 1973 FC > > > | |||
					03-03-2008, 14:11
				 Post: #12 | |||
| Alcoa Wheels
					Not to pick, but late '83s came with the 8.25s. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > The only concern is the width. 83s came with 7.5s, ya want 8.25" wide. 10 bolt stud pilot is older, careful you don't get sold some hub pilot. Ya gotta watch the bead seat area, it can get worn out, sharp edge that can cut into the tire bead. > MH > ----- Original Message ----- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, February 27, 2008 3:27 PM > Subject: Re: [WanderlodgeForum] Re: Alcoa Wheels > > > Call this company. They make specialty valve stems for dual wheels, steel and Alcoa. He was very helpful. Plus, I like his product. > Borg Equipment Supply, Tujunga, CA 800-300-2674 or 818-352-8717 > Leroy Eckert > 1990 WB -40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > bubblerboy64 > > Well, Just a little more information, The wheels are off a pusher > mid eighties. They are stud piloted and 22.5 inches which is what I > need but beyond that the fellow parting out the bus doesn't know. So > any information would be appreciated. I tried call BB and to this > point have only been able to talk to an answering machine. I'd like > be able to tell the fellow ASAP that I will take them so they don't > get gone. > > John Heckman > central Pa > 1973 FC > > > > I do not know if this will help. > > When I changed my valve stems I found that pre-1995 22.5" Alcoa's > have a two inch round hand hole. Later models have two and one half > inch handhole. It is a ten lug set up. Classifications were for motor > homes and buses-diesel so one might conclude they are the same for > those years. Perhaps someone else may have more info. > > > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > bubblerboy64 > been lookin' for a while and I have a lead which might work out. > > Quick question. My ole 73 has the axles off a 1984 I believe. I > am > > assuming that the wheels will fit. The alcoa's are off a BB bus. > > Before I get into this too deep would the wheels on the pushers be > the > > same as the FC's? I know I have not provided much information but > if > > the wheels on the pushers don't fit the FC's then my hunt > continues. My > > bus has 22.5 inch steel wheels. Ten bolt stud piloted but beyond > that I > > will have to reseach. Thanks in advance. > > John Heckman > > central Pa > > 1973 FC > > > > > > > > > > > > > > --------------------------------- > > Looking for last minute shopping deals? Find them fast with Yahoo! > Search. > > > > > > > > > ------------------------------------------------------------------- ----------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > | |||
					03-03-2008, 14:33
				 Post: #13 | |||
| Alcoa Wheels Yer pickin'. MH
					03-22-2008, 13:15
				 Post: #14 | |||
| Alcoa Wheels
					Well I have them home. They're nice but of course not like new and not polished the why a proud BB's owner would like them. I started "working" on one of them and I just don't think I have it in me to do four of them. I suppose it I have to do it myself I will but does anyone know of a professional wheel shop or a way to have them done professionally. A location in the Pa Maryland area would be helpful since shipping could get pricy. I searched on the net and only found a place in BC which out of reach. John Heckman central Pa 1973 FC | |||
					03-22-2008, 13:53
				 Post: #15 | |||
| Alcoa Wheels
					I think the key is starting out with a laundrysoap washing then wet sanding up to 500 grit. even if you plan to send them out. If you have an angle grinder, pads and grit sticks are about the same cost as hiring the balance of the job out. You can often find independent polishers at a local truckwash. or ask a local bigrig tire shop for a number. You only need to polish 2 of them on one side and two of them on the other side. dont forget to get new hub covers for the remount on the rear. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > Well I have them home. They're nice but of course not like new and not > polished the why a proud BB's owner would like them. I > started "working" on one of them and I just don't think I have it in me > to do four of them. I suppose it I have to do it myself I will but > does anyone know of a professional wheel shop or a way to have them > done professionally. A location in the Pa Maryland area would be > helpful since shipping could get pricy. I searched on the net and only > found a place in BC which out of reach. > > John Heckman > central Pa > 1973 FC > | |||
					03-22-2008, 13:59
				 Post: #16 | |||
| Alcoa Wheels
					John:  I used the shop where I bought my tires, Petes Road Service, here in SoCal. They sent them out and it took a few days. Couldnt belive the great job they did, almost had to wear my dark glasses.. $35 a wheel, as I remember.. Jack Smith 73FC35 SoCal --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Well I have them home. They're nice but of course not like new and not > polished the why a proud BB's owner would like them. I > started "working" on one of them and I just don't think I have it in me > to do four of them. I suppose it I have to do it myself I will but > does anyone know of a professional wheel shop or a way to have them > done professionally. A location in the Pa Maryland area would be > helpful since shipping could get pricy. I searched on the net and only > found a place in BC which out of reach. > > John Heckman > central Pa > 1973 FC > | |||
					03-22-2008, 14:01
				 Post: #17 | |||
| Alcoa Wheels
					Check for "automobile detailing" shops. There are oodles of them, mostly one or two man operations. A few might be willing to polish your aluminum wheels for you. =============================================== Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers "Aeonix1@Mac.com" Aeonix Publishing Group   http://www.aeonix.com =============================================== On Mar 22, 2008, at 5:15 PM, bubblerboy64 wrote:
					03-22-2008, 14:04
				 Post: #18 | |||
| Alcoa Wheels
					A source I looked at was a local motorcycle shop. They do a lot of polishing on the bikes. This is where I found someone to do mine. Made some good contacts and they in turn came up with an individual who came to the rig and did the wheels. Regards Chuck Somers 81FC35SB, Florida > I think the key is starting out with a laundrysoap washing then wet > sanding up to 500 grit. even if you plan to send them out. If you > have an angle grinder, pads and grit sticks are about the same cost > as hiring the balance of the job out. You can often find > independent polishers at a local truckwash. or ask a local bigrig > tire shop for a number. > > You only need to polish 2 of them on one side and two of them on the > other side. dont forget to get new hub covers for the remount on the > rear. > > GregoryO'Connor > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > >> >> Well I have them home. They're nice but of course not like new and > not >> polished the why a proud BB's owner would like them. I >> started "working" on one of them and I just don't think I have it > in me >> to do four of them. I suppose it I have to do it myself I will > but >> does anyone know of a professional wheel shop or a way to have > them >> done professionally. A location in the Pa Maryland area would be >> helpful since shipping could get pricy. I searched on the net and > only >> found a place in BC which out of reach. >> >> John Heckman >> central Pa >> 1973 FC >> > > > | |||
					03-22-2008, 15:54
				 Post: #19 | |||
| Alcoa Wheels
					Hi John, There is a guy on Carlisle Pike off I-81 behind the strip club that does them at odd times. If you stop by one of the garages at the flying hook or TA they can tell you more. I had a fun time doing mine with wet sandpaper. Started at 400 or 600 grit and worked up to 1500 or 2000 grit and finally a buffing wheel on a mechanical buffer. Still was not as good as a pro can get them with the right tools and attachments. They probably know where to get them done at the John Wayne chrome shop down at Greencastle too. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Well I have them home. They're nice but of course not like new and not > polished the why a proud BB's owner would like them. I > started "working" on one of them and I just don't think I have it in me > to do four of them. I suppose it I have to do it myself I will but > does anyone know of a professional wheel shop or a way to have them > done professionally. A location in the Pa Maryland area would be > helpful since shipping could get pricy. I searched on the net and only > found a place in BC which out of reach. > > John Heckman > central Pa > 1973 FC > | |||
					03-22-2008, 17:56
				 Post: #20 | |||
| Alcoa Wheels
					Thanks Shane,  I'll check both of those out Monday. My fingers and hands are sore from my efforts. Not a good thing for my day job. I would have to start with something a lot more aggressive then 400 or I would attempt it. So considering the point at which I am starting and the results I would like to have I better get some help. Same ole story know your limits. The wheels are decent but there are some pits. I actually think from what I've been able to find on the web that the professionals turn them on a lathe to start. That would be about the only why I could see doing this from a practical stand point. Probably only have to take a couple thousands off but that's a lot of sanding. I tried a couple things using an drill and that was too aggressive and too difficult to get a smooth result. Just too much to do it by hand for me. I did start on the worst one I think but still my best bet is to farm this one out. Thanks and I'll make some calls Monday and let ya know. Looking forward to the run to Maxton in a ten days. John Heckman central Pa 1973 FC > > Hi John, > > There is a guy on Carlisle Pike off I-81 behind the strip club that > does them at odd times. If you stop by one of the garages at the > flying hook or TA they can tell you more. I had a fun time doing mine > with wet sandpaper. Started at 400 or 600 grit and worked up to 1500 > or 2000 grit and finally a buffing wheel on a mechanical buffer. Still > was not as good as a pro can get them with the right tools and > attachments. They probably know where to get them done at the John > Wayne chrome shop down at Greencastle too. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > Well I have them home. They're nice but of course not like new and not > > polished the why a proud BB's owner would like them. I > > started "working" on one of them and I just don't think I have it in me > > to do four of them. I suppose it I have to do it myself I will but > > does anyone know of a professional wheel shop or a way to have them > > done professionally. A location in the Pa Maryland area would be > > helpful since shipping could get pricy. I searched on the net and only > > found a place in BC which out of reach. > > > > John Heckman > > central Pa > > 1973 FC > > > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
