6 wire toad connector
05-23-2007, 12:03
Folks,
I'm wiring my toad and need to know which connector the tail lights connects to. It's a six pin connector. Ground, Left Turn, and Right Turn are clearly labled. That leaves 3 connectors labeled: S, TM, and A. Which of these connects to the tail lights? Thanks, David Brady '02 LXi, Smokey NC |
05-23-2007, 12:50
Viewed from the back of the plug on the coach it should be as follows: No
guarantee, check with a test light with the park lights on to verify. In a circle: 12 O'clock TM trailer lights. 2 O'clock Electric Brakes(S), 5 O'clock Right Turn, Screw hole at 6 O'clock, 8 O'clock Left Turn, 10 O'clock Ground(GD), and center 12v presumably for battery charge. Mirror image the sequence for the Toad. That is what I have in my file. Hope this helps. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: David Brady To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Wednesday, May 23, 2007 7:03 PM Subject: [WanderlodgeForum] 6 wire toad connector Folks, I'm wiring my toad and need to know which connector the tail lights connects to. It's a six pin connector. Ground, Left Turn, and Right Turn are clearly labled. That leaves 3 connectors labeled: S, TM, and A. Which of these connects to the tail lights? Thanks, David Brady '02 LXi, Smokey NC [Non-text portions of this message have been removed] |
05-23-2007, 13:18
Got it. Thanks Leroy,
David Brady '02 LXi, Smokey NC Leroy Eckert wrote: > > Viewed from the back of the plug on the coach it should be as follows: > No guarantee, check with a test light with the park lights on to verify. > > In a circle: 12 O'clock TM trailer lights. 2 O'clock Electric > Brakes(S), 5 O'clock Right Turn, Screw hole at 6 O'clock, 8 O'clock > Left Turn, 10 O'clock Ground(GD), and center 12v presumably for > battery charge. Mirror image the sequence for the Toad. That is what I > have in my file. > Hope this helps. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: David Brady > To: WanderlodgeForum@yahoogroups.com > > wanderlodge@yahoogroups.com > Sent: Wednesday, May 23, 2007 7:03 PM > Subject: [WanderlodgeForum] 6 wire toad connector > > Folks, > > I'm wiring my toad and need to know which connector > the tail lights connects to. It's a six pin connector. Ground, > Left Turn, and Right Turn are clearly labled. That leaves > 3 connectors labeled: S, TM, and A. Which of these connects > to the tail lights? > > Thanks, > David Brady > '02 LXi, Smokey > NC > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.467 / Virus Database: 269.7.6/815 - Release Date: 5/22/2007 3:49 PM > [Non-text portions of this message have been removed] |
05-23-2007, 13:59
Smokey
There is a drawing of the BB rear plug in the files of this forum. This may help. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > I'm wiring my toad and need to know which connector > the tail lights connects to. It's a six pin connector. Ground, > Left Turn, and Right Turn are clearly labled. That leaves > 3 connectors labeled: S, TM, and A. Which of these connects > to the tail lights? > > Thanks, > David Brady > '02 LXi, Smokey > NC > |
05-23-2007, 15:13
Dave, I never try and remember what is what. I test with a test light
every time. if you have amber turns, the stop and turn are seperate. My 94pt has volvo amber turns, but the origional plug at the back of my bus is set up to share a turn and stop I am sure there are diodes someplace. You need air pressure to glow the stop taillights. When I complete a connection I pump the socket full of bathroom silicone. I am not a fan of Dielectric grease because it melts off and traps in road salt on old connections. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > I'm wiring my toad and need to know which connector > the tail lights connects to. It's a six pin connector. Ground, > Left Turn, and Right Turn are clearly labled. That leaves > 3 connectors labeled: S, TM, and A. Which of these connects > to the tail lights? > > Thanks, > David Brady > '02 LXi, Smokey > NC > |
