Dometic Ref. Recall
03-17-2007, 14:01
Dometic Ref. Recall
We have been away several weeks so don't know if this has been covered on our
groups. Opened accumulated mail yesterday and found letter advising a Dometic refrigerator recall. A fatigue crack can develope in the boiler tube and is source of potential fire. They supplied the serial and model numbers. Too many to enter here but if you have one manufactured between April 1997 and May 2003 and for some reason haven't received notice you might want to contact them. The number is 1-888-446-5157. Maury 80 fc 31' [Non-text portions of this message have been removed] |
03-18-2007, 04:21
Dometic Ref. Recall
--- Maury:
Thanks for putting out recall info....I checked and my Dometic is under the recall but I have to wait til Monday......you may have saved me an RV FIRE!!!!! Encourage everyone to check the Dometic recall if appropriate...Thanks again Maury! Regards, Hank Hannigan...chillin is Vegas 1990SP36..lovin it! In WanderlodgeForum@yahoogroups.com, "M.L. Perkinson" <mp222116@...> wrote: > > We have been away several weeks so don't know if this has been covered on our groups. > > Opened accumulated mail yesterday and found letter advising a Dometic refrigerator recall. A fatigue crack can develope in the boiler tube and is source of potential fire. > > They supplied the serial and model numbers. Too many to enter here but if you have one manufactured between April 1997 and > May 2003 and for some reason haven't received notice you might want to contact them. The number is 1-888-446-5157. Maury 80 fc 31' > > [Non-text portions of this message have been removed] > |
03-18-2007, 07:45
Dometic Ref. Recall
I'm in the same boat. Has anyone had the repair done yet or know what is
required? Is it the kind of thing a person could order the repair kit and do it themselves or does it require a lot of technical knowledge to install? Kerry 82 Fc 35 Denver |
03-18-2007, 10:15
Dometic Ref. Recall
The kits won't be out until April. There is an exterior back up fire box
and some fuses to be added. It is a patch to contain any fire in the LP lighted area if need be. 99.98% of the units do not have a problem. Dometic is supplying Dometic certified dealers or mobile tech's with the kits and are only paying $40.00 per install. They are not replacing the cooling coils which the boiler tube is part of. That is all I know on the behind the scenes so far. Will up date as I learn more. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 06:45 PM 3/18/2007 +0000, you wrote: >I'm in the same boat. Has anyone had the repair done yet or know what is >required? Is it the >kind of thing a person could order the repair kit and do it themselves or >does it require a lot >of technical knowledge to install? > >Kerry >82 Fc 35 >Denver > > |
03-18-2007, 12:50
Dometic Ref. Recall
The notice I received stated that the parts would not be to the dealers
until the middle of April. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Sunday, March 18, 2007 12:45 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Dometic Ref. Recall I'm in the same boat. Has anyone had the repair done yet or know what is required? Is it the kind of thing a person could order the repair kit and do it themselves or does it require a lot of technical knowledge to install? Kerry 82 Fc 35 Denver [Non-text portions of this message have been removed] |
