These "Air Fans"
08-09-2006, 02:33
These "Air Fans"
Am I correct in assuming that the Horton fans talked about here are
turned by air pressure rather than by a belt off the engine? Or does
the air pressure simply close the clutch to engage the belt drive?
Scott Forman
82 FC35RB
Memphis
08-09-2006, 04:01
These "Air Fans"
Air pressure keeps the clutch off so it will default "on" if pressure is lost..
A temp switch controls air signal to the fan clutch. Not complicated but
demanding in execution.
MH
Sent: Wednesday, August 09, 2006 9:33 AM
Subject: [WanderlodgeForum] These "Air Fans"
Scott Forman
82 FC35RB
Memphis
08-09-2006, 04:34
These "Air Fans"
Is there any easy way to tell, say by crawling under the coach and
looking up, what kind of fan is on the engine?
Kerry
82 FC 35
Denver
pressure is lost.. A temp switch controls air signal to the fan
clutch. Not complicated but demanding in execution.
> MH
> From: Scott Forman
> Scott Forman
> 82 FC35RB
> Memphis
08-09-2006, 09:23
These "Air Fans"
Does the power to make the fan spin come from air pressure or from a
belt like any other fan?
> MH
> From: Scott Forman
are
does
> Scott Forman
> 82 FC35RB
> Memphis
08-09-2006, 10:22
These "Air Fans"
Belt. Air only controls the clutch.
Kerry
> > MH
> > From: Scott Forman
> are
> does
> > Scott Forman
> > 82 FC35RB
> > Memphis
08-09-2006, 12:30
These "Air Fans"
If one has a working Facet Fan, as I do, is there any reason to
swtich to a Horton?
Scott
> Kerry
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
from a
> > > MH
> > > From: Scott Forman
here
> > are
Or
> > does
drive?
> > > Scott Forman
> > > 82 FC35RB
> > > Memphis
08-09-2006, 14:08
These "Air Fans"
Belt.
MH
Sent: Wednesday, August 09, 2006 4:23 PM
Subject: [WanderlodgeForum] Re: These "Air Fans"
> MH
> From: Scott Forman
are
does
> Scott Forman
> 82 FC35RB
> Memphis
08-09-2006, 14:23
These "Air Fans"
NO
MH
Sent: Wednesday, August 09, 2006 7:30 PM
swtich to a Horton?
Scott
> Kerry
from a
> > > MH
> > > From: Scott Forman
here
> > are
Or
> > does
drive?
> > > Scott Forman
> > > 82 FC35RB
> > > Memphis
