Bendix Brakes won't air up
07-09-2006, 06:05
Ralph, I don't think he has the AD-2 he has a BMC and I "think" it is
the bendix pure air???? Will it work the same way?? Good to know info though...Prolly should rebuild mine..you did it last time. Best of Luck Al ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello Al: > > Not sure which air drier you have on your Coach. Try this before taking the > plate off. There should be a 1/4 inch air line going to the pop off valve > with a connection on the out side of the drier. If you have this air line, > remove the connector and allow the back pressure to bleed off, start the > Coach and see if your air starts to build up, if it does, re connect the > 1/4 inch air line and go down the road. Also if this gets you out of a > bind, the air drier needs to be serviced with a new cartridge and pop off > valve re build. The back pressure on this air line serves to tell the air > governor that your tanks are full and up to pressure. > > How about that photo? it would help. Of course, all the safety precautions > to be taken under the Coach. > > Ralph > > At 02:49 PM 7/9/2006 +0000, you wrote: > >We just had the brakes serviced by McDonald Coachworks and everything > >seemed ok. Now are are in our 2nd week of vacation and we shut down > >like normal and jacked the bird up. Been here for 3 days and now we > >are ready to head to Charlotte, NC and the brakes will not air up. I > >hear a hissing sound at the Bendix valve. Looking thru my manual now > >as to what to do to get the valve to close so we can air up our brake > >system. I have searched the site and dont see anything that would > >lead me as to what to do next. I have tried turning off the engine > >and letting sit and restart with no result so far. > > > >Thanks for anyone that responds. > >Al, Kathy Alfred, Daniel Johnson > >Bear Den Campground Spruce Pine, NC > >'96 BMC > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
07-09-2006, 06:05
Ralph,
Thanks for the reply. I just uploaded the picture to Air Dryer folder. I will look for the line you suggest. Al Johnson '96 BMC --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello Al: > > Not sure which air drier you have on your Coach. Try this before taking the > plate off. There should be a 1/4 inch air line going to the pop off valve > with a connection on the out side of the drier. If you have this air line, > remove the connector and allow the back pressure to bleed off, start the > Coach and see if your air starts to build up, if it does, re connect the > 1/4 inch air line and go down the road. Also if this gets you out of a > bind, the air drier needs to be serviced with a new cartridge and pop off > valve re build. The back pressure on this air line serves to tell the air > governor that your tanks are full and up to pressure. > > How about that photo? it would help. Of course, all the safety precautions > to be taken under the Coach. > > Ralph > > At 02:49 PM 7/9/2006 +0000, you wrote: > >We just had the brakes serviced by McDonald Coachworks and everything > >seemed ok. Now are are in our 2nd week of vacation and we shut down > >like normal and jacked the bird up. Been here for 3 days and now we > >are ready to head to Charlotte, NC and the brakes will not air up. I > >hear a hissing sound at the Bendix valve. Looking thru my manual now > >as to what to do to get the valve to close so we can air up our brake > >system. I have searched the site and dont see anything that would > >lead me as to what to do next. I have tried turning off the engine > >and letting sit and restart with no result so far. > > > >Thanks for anyone that responds. > >Al, Kathy Alfred, Daniel Johnson > >Bear Den Campground Spruce Pine, NC > >'96 BMC > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
07-09-2006, 07:25
Ralph,
That got us going again. We just had coachworks rebuild the unit and replace the canister. Do you think it has to be done again or just a glitch. To everyone else, thanks so much for your immediate help. Al, Kathy, Alfred, Daniel '96 BMC Carowinds Heading to Charlottte, NC --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello Al: > > Not sure which air drier you have on your Coach. Try this before taking the > plate off. There should be a 1/4 inch air line going to the pop off valve > with a connection on the out side of the drier. If you have this air line, > remove the connector and allow the back pressure to bleed off, start the > Coach and see if your air starts to build up, if it does, re connect the > 1/4 inch air line and go down the road. Also if this gets you out of a > bind, the air drier needs to be serviced with a new cartridge and pop off > valve re build. The back pressure on this air line serves to tell the air > governor that your tanks are full and up to pressure. > > How about that photo? it would help. Of course, all the safety precautions > to be taken under the Coach. > > Ralph > > At 02:49 PM 7/9/2006 +0000, you wrote: > >We just had the brakes serviced by McDonald Coachworks and everything > >seemed ok. Now are are in our 2nd week of vacation and we shut down > >like normal and jacked the bird up. Been here for 3 days and now we > >are ready to head to Charlotte, NC and the brakes will not air up. I > >hear a hissing sound at the Bendix valve. Looking thru my manual now > >as to what to do to get the valve to close so we can air up our brake > >system. I have searched the site and dont see anything that would > >lead me as to what to do next. I have tried turning off the engine > >and letting sit and restart with no result so far. > > > >Thanks for anyone that responds. > >Al, Kathy Alfred, Daniel Johnson > >Bear Den Campground Spruce Pine, NC > >'96 BMC > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
07-09-2006, 08:43
Great Al:
Not a glitch, it will happen again. Bet on it. They replaced the filter, good, but did not rebuild the pop off valve and that is what your problem is. The re build kit is around $15.00 and can be had at or through O'Riely's or Napa. You can do the rebuild when you get to home base. Have a good trip. Ralph At 07:25 PM 7/9/2006 +0000, you wrote: >Ralph, > That got us going again. We just had coachworks rebuild the unit >and replace the canister. Do you think it has to be done again or >just a glitch. To everyone else, thanks so much for your immediate >help. > >Al, Kathy, Alfred, Daniel >'96 BMC >Carowinds >Heading to Charlottte, NC >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hello Al: > > > > Not sure which air drier you have on your Coach. Try this before >taking the > > plate off. There should be a 1/4 inch air line going to the pop >off valve > > with a connection on the out side of the drier. If you have this >air line, > > remove the connector and allow the back pressure to bleed off, >start the > > Coach and see if your air starts to build up, if it does, re >connect the > > 1/4 inch air line and go down the road. Also if this gets you out >of a > > bind, the air drier needs to be serviced with a new cartridge and >pop off > > valve re build. The back pressure on this air line serves to tell >the air > > governor that your tanks are full and up to pressure. > > > > How about that photo? it would help. Of course, all the safety >precautions > > to be taken under the Coach. > > > > Ralph > > > > At 02:49 PM 7/9/2006 +0000, you wrote: > > >We just had the brakes serviced by McDonald Coachworks and >everything > > >seemed ok. Now are are in our 2nd week of vacation and we shut >down > > >like normal and jacked the bird up. Been here for 3 days and now >we > > >are ready to head to Charlotte, NC and the brakes will not air >up. I > > >hear a hissing sound at the Bendix valve. Looking thru my manual >now > > >as to what to do to get the valve to close so we can air up our >brake > > >system. I have searched the site and dont see anything that would > > >lead me as to what to do next. I have tried turning off the >engine > > >and letting sit and restart with no result so far. > > > > > >Thanks for anyone that responds. > > >Al, Kathy Alfred, Daniel Johnson > > >Bear Den Campground Spruce Pine, NC > > >'96 BMC > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
07-09-2006, 09:37
I had a similar situation...after some searching, and obtaining professional
help, we found and replaced the air governor (about a $50 part, and a thousand in labor...also rebuilt the air dryer). No problems since. Before it was fixed, the air would air up to 30 lbs, and just stay there...hissing sound somewhere near the top of the engine. Best of luck. Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
07-09-2006, 10:24
Ok we got about an hour or so heading towards Charlotte and it
started blowing air from the bottom of the dryer again. We tried repeating the process you gave to us before and got a different result this time. Last time, we had not air comping out of the two holes that we disconnected the line on. This time we get hot air from the dryer and then it switches to the bottom again. I guess the air is hot because of the driving. Anyway, no it will not pump up the system. Should I let it cool off and retry? I also leveled the bird like it was before so we had no air in the system and this did not help. Now we are Gastonia, NC which is closer to Charlotte where we have a couple of members recommending a service center. Al, Kathy, Alfred, Daniel '96 BMC Gastonia, NC next to I85 --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello Al: > > Not sure which air drier you have on your Coach. Try this before taking the > plate off. There should be a 1/4 inch air line going to the pop off valve > with a connection on the out side of the drier. If you have this air line, > remove the connector and allow the back pressure to bleed off, start the > Coach and see if your air starts to build up, if it does, re connect the > 1/4 inch air line and go down the road. Also if this gets you out of a > bind, the air drier needs to be serviced with a new cartridge and pop off > valve re build. The back pressure on this air line serves to tell the air > governor that your tanks are full and up to pressure. > > How about that photo? it would help. Of course, all the safety precautions > to be taken under the Coach. > > Ralph > > At 02:49 PM 7/9/2006 +0000, you wrote: > >We just had the brakes serviced by McDonald Coachworks and everything > >seemed ok. Now are are in our 2nd week of vacation and we shut down > >like normal and jacked the bird up. Been here for 3 days and now we > >are ready to head to Charlotte, NC and the brakes will not air up. I > >hear a hissing sound at the Bendix valve. Looking thru my manual now > >as to what to do to get the valve to close so we can air up our brake > >system. I have searched the site and dont see anything that would > >lead me as to what to do next. I have tried turning off the engine > >and letting sit and restart with no result so far. > > > >Thanks for anyone that responds. > >Al, Kathy Alfred, Daniel Johnson > >Bear Den Campground Spruce Pine, NC > >'96 BMC > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
07-09-2006, 11:04
Al:
Was hoping that would get you in to Charolette. Am not sure how to access the pop off valve on your unit. On the AD-2, before removing the plate for access to the filter cartridge, you can take a large open end wrench or pipe wrench and break loose the threads on the hexagonal end of the cap, with that done you remove the three 7/16 inch blots that serve to keep the plate in place, force the plate up and with a flat blade screw driver, remove the round retaining ring then slide the plate out of the canister. With that done, you can screw off the end of the pop off valve, then hold the upper part of the screw shaft holding the pop off valve and un screw the nut off the shaft. This lets you remove the pop off valve shaft. Clean the inner housing with a clean rag, lube it liberally with grease, ( not sure what you carry on board ) then lube the o-rings and plunger and re install. Again it would help to have an actual photo of your unit. Sorry, Al, we tried, but if nothing else you know where the problem is. Have a suggestion though. When you get to Charlotte, it might well be in your best interest to replace the air governor ($17.00 or so part) as well. Let us know how you fair with it. My home phone is 580-252-7694, if you need to talk about it. Ralph At 10:24 PM 7/9/2006 +0000, you wrote: > Ok we got about an hour or so heading towards Charlotte and it >started blowing air from the bottom of the dryer again. We tried >repeating the process you gave to us before and got a different >result this time. > >Last time, we had not air comping out of the two holes that we >disconnected the line on. This time we get hot air from the dryer >and then it switches to the bottom again. I guess the air is hot >because of the driving. Anyway, no it will not pump up the system. >Should I let it cool off and retry? > >I also leveled the bird like it was before so we had no air in the >system and this did not help. > >Now we are Gastonia, NC which is closer to Charlotte where we have a >couple of members recommending a service center. > >Al, Kathy, Alfred, Daniel >'96 BMC >Gastonia, NC next to I85 > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hello Al: > > > > Not sure which air drier you have on your Coach. Try this before >taking the > > plate off. There should be a 1/4 inch air line going to the pop >off valve > > with a connection on the out side of the drier. If you have this >air line, > > remove the connector and allow the back pressure to bleed off, >start the > > Coach and see if your air starts to build up, if it does, re >connect the > > 1/4 inch air line and go down the road. Also if this gets you out >of a > > bind, the air drier needs to be serviced with a new cartridge and >pop off > > valve re build. The back pressure on this air line serves to tell >the air > > governor that your tanks are full and up to pressure. > > > > How about that photo? it would help. Of course, all the safety >precautions > > to be taken under the Coach. > > > > Ralph > > > > At 02:49 PM 7/9/2006 +0000, you wrote: > > >We just had the brakes serviced by McDonald Coachworks and >everything > > >seemed ok. Now are are in our 2nd week of vacation and we shut >down > > >like normal and jacked the bird up. Been here for 3 days and now >we > > >are ready to head to Charlotte, NC and the brakes will not air >up. I > > >hear a hissing sound at the Bendix valve. Looking thru my manual >now > > >as to what to do to get the valve to close so we can air up our >brake > > >system. I have searched the site and dont see anything that would > > >lead me as to what to do next. I have tried turning off the >engine > > >and letting sit and restart with no result so far. > > > > > >Thanks for anyone that responds. > > >Al, Kathy Alfred, Daniel Johnson > > >Bear Den Campground Spruce Pine, NC > > >'96 BMC > > > > > > > > > > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
07-12-2006, 03:54
To everyone that responded, thanks!
Ok to bring everyone up to speed, we were able to get off the mountain in Spruce Pine by taking the 1/4 air hose off and the system started building presssure. We got to Gastonia, NC and the dryer started purging air again. Thank God it did not act up in the mountains on our way off Spruce Pine. So we tried to repeat the process and that did not fix it. So we went down to Napa and purchased an air governer and installed it. That did not fix it. We had two friendly truckers stop for breakfast and Kathy pounced on them to ask questions. She is good at that. LOL Anyway before I knew it one of the truckers pulled out a fitting to join the two hoses ( in & out ) and eliminate the dryer till I get home. I spoke to Bob Loomas the night before and he suggusted we do that as well. So we joined the two hoses together and did not need the trucker's fitting since we had all the fittings we needed on the dryer. It was a close fit with no room to spare. Anyway so I spent the next two days calling every Haldex Dist. in Charlotte and no one has the purge assembly. But I did locate one in Atlanta which is on our way home. Also the unit has a purge valve which is part of the major repair kit. Just want to make sure the everyone is in agreement that the purge assemble which is different from the purge valve is what I need to make the repair. I am leaning towards waiting till I get home on Friday to start the repair so I don't dampen anymore of the trip. Again thanks goes out to everyone that responded to my help call. Hopefully someday I can return the favor. Al, Kathy, Alfred & Daniel Johnson '96 BMCCharlotte, NC ==> Atlanta, Ga. --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > I had a similar situation...after some searching, and obtaining professional > help, we found and replaced the air governor (about a $50 part, and a > thousand in labor...also rebuilt the air dryer). No problems since. Before it was > fixed, the air would air up to 30 lbs, and just stay there...hissing sound > somewhere near the top of the engine. > > Best of luck. > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > |
07-12-2006, 06:33
Al.
Glad to hear you are moving along. Now you know you have a good air governor. Howard truitt ----- Original Message ----- From: Al To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 12, 2006 11:54 AM Subject: [WanderlodgeForum] Re: Bendix Brakes won't air up To everyone that responded, thanks! Ok to bring everyone up to speed, we were able to get off the mountain in Spruce Pine by taking the 1/4 air hose off and the system started building presssure. We got to Gastonia, NC and the dryer started purging air again. Thank God it did not act up in the mountains on our way off Spruce Pine. So we tried to repeat the process and that did not fix it. So we went down to Napa and purchased an air governer and installed it. That did not fix it. We had two friendly truckers stop for breakfast and Kathy pounced on them to ask questions. She is good at that. LOL Anyway before I knew it one of the truckers pulled out a fitting to join the two hoses ( in & out ) and eliminate the dryer till I get home. I spoke to Bob Loomas the night before and he suggusted we do that as well. So we joined the two hoses together and did not need the trucker's fitting since we had all the fittings we needed on the dryer. It was a close fit with no room to spare. Anyway so I spent the next two days calling every Haldex Dist. in Charlotte and no one has the purge assembly. But I did locate one in Atlanta which is on our way home. Also the unit has a purge valve which is part of the major repair kit. Just want to make sure the everyone is in agreement that the purge assemble which is different from the purge valve is what I need to make the repair. I am leaning towards waiting till I get home on Friday to start the repair so I don't dampen anymore of the trip. Again thanks goes out to everyone that responded to my help call. Hopefully someday I can return the favor. Al, Kathy, Alfred & Daniel Johnson '96 BMCCharlotte, NC ==> Atlanta, Ga. --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > I had a similar situation...after some searching, and obtaining professional > help, we found and replaced the air governor (about a $50 part, and a > thousand in labor...also rebuilt the air dryer). No problems since. Before it was > fixed, the air would air up to 30 lbs, and just stay there...hissing sound > somewhere near the top of the engine. > > Best of luck. > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.9.9/382 - Release Date: 7/4/2006 [Non-text portions of this message have been removed] |
07-12-2006, 10:39
Hi Howard,
I replaced the new one with the old one since it was not the problem. Plus I would have to adjust the pounds since it was set for 130 and the old one was 110 lbs. I have a computer background so I did not want to complicate the equation. Plus now I have a new spare just in case. When I get home, I am going to change out the purge assembly and see if that fixes my problems. I am going to call coachworks as well and see exactly what they did. I thought they rebuild the assembly for me and changed the filter. This is our first major trip since the repairs so it should have lasted longer than this. Al, Kathy, Alfred & Daniel Lake Hartwell State Park Fair Play, SC '96 BMC --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Al. > Glad to hear you are moving along. Now you know you have a good air governor. > Howard truitt > > > ----- Original Message ----- > From: Al > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, July 12, 2006 11:54 AM > Subject: [WanderlodgeForum] Re: Bendix Brakes won't air up > > > To everyone that responded, thanks! > > Ok to bring everyone up to speed, we were able to get off the > mountain in Spruce Pine by taking the 1/4 air hose off and the > system started building presssure. We got to Gastonia, NC and the > dryer started purging air again. Thank God it did not act up in the > mountains on our way off Spruce Pine. > > So we tried to repeat the process and that did not fix it. So we > went down to Napa and purchased an air governer and installed it. > That did not fix it. We had two friendly truckers stop for breakfast > and Kathy pounced on them to ask questions. She is good at that. > LOL Anyway before I knew it one of the truckers pulled out a > fitting to join the two hoses ( in & out ) and eliminate the dryer > till I get home. I spoke to Bob Loomas the night before and he > suggusted we do that as well. So we joined the two hoses together > and did not need the trucker's fitting since we had all the fittings > we needed on the dryer. It was a close fit with no room to spare. > > Anyway so I spent the next two days calling every Haldex Dist. in > Charlotte and no one has the purge assembly. But I did locate one > in Atlanta which is on our way home. Also the unit has a purge > valve which is part of the major repair kit. > > Just want to make sure the everyone is in agreement that the purge > assemble which is different from the purge valve is what I need to > make the repair. I am leaning towards waiting till I get home on > Friday to start the repair so I don't dampen anymore of the trip. > > Again thanks goes out to everyone that responded to my help call. > Hopefully someday I can return the favor. > > Al, Kathy, Alfred & Daniel Johnson > '96 BMCCharlotte, NC ==> Atlanta, Ga. > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > I had a similar situation...after some searching, and obtaining > professional > > help, we found and replaced the air governor (about a $50 part, > and a > > thousand in labor...also rebuilt the air dryer). No problems > since. Before it was > > fixed, the air would air up to 30 lbs, and just stay > there...hissing sound > > somewhere near the top of the engine. > > > > Best of luck. > > > > Kevin McKeown > > Yorba Linda, CA > > 1986 38' PT > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------- ----------- > > > Internal Virus Database is out-of-date. > Checked by AVG Free Edition. > Version: 7.1.394 / Virus Database: 268.9.9/382 - Release Date: 7/4/2006 > > > [Non-text portions of this message have been removed] > |
User(s) browsing this thread: 10 Guest(s)
