1980 Rod to Air Hose on Front Suspension
05-18-2006, 14:54
There is a rod going up and down from the center of the front
suspension that is causing air to dump when I do not want the air to
dump, or at least if I mess with that rod air stops dumping. Anyone
know what that rod is for, and if okay for me to just adjust it (up I
think) to stop the air from dumping out. I did have the bus on a
sloping street lifted high on the sidewalk side to make level, but I
have had intermittent large air leaks from the same place for a long
time.
Also, there is a junction of I think 3 air hoses near this spot.
Anyone know where these are going? I appear to only be using 2 of the
3, and the 3rd appears abandoned by a prior owner.
Tks,
SDF
80FC35 Boulder
05-18-2006, 14:55
time.
Tks,
SDF
80FC35 Boulder
05-18-2006, 23:27
Suspension leveling valve, rod connects to the AXLE. There are two on the rear
axle. Be careful under there, you could die.
MH
Sent: Thursday, May 18, 2006 9:55 PM
Subject: [WanderlodgeForum] 1980 Rod to Air Hose on Front Suspension
time.
Tks,
SDF
80FC35 Boulder
SPONSORED LINKS Recreational vehicles Recreational vehicle financing
Recreational vehicle repair
Recreational vehicle rental Recreational vehicle camper Recreational
vehicle rate
YAHOO! GROUPS LINKS
05-19-2006, 01:07
What Mike said.
The three hose deal sounds like the dump valve, one line to supply,
one to the leveling valve (top of the aforementioned rod), third is
exhaust.
Block it up before going under.
- Jeff Miller
in Holland, MI
two on the rear axle. Be careful under there, you could die.
> MH
> From: shawn_fountain
Suspension
air to
Anyone
(up I
but I
long
> time.
of the
> Tks,
> SDF
> 80FC35 Boulder
financing Recreational vehicle repair
Recreational vehicle rate
> YAHOO! GROUPS LINKS
of Service.
