foggy humid wet windows
02-06-2010, 00:48
Check the defrost vents and fan air flow for blockage.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "freewill2008" wrote:
> When our coach gets saturated with humidity we hook up to 50 amps and run the
air conditioners and the heat together for however long it takes, a couple hours
at least, better yet on and off for a day or two. The excess coach humidity
runs out the AC condensation drains and you are done with if for a while.
> A leaking heater core usually makes itself known because the coach starts to
smell like a radiator.
> Bob Griesel '84 FC31 WLII WA
> --- In WanderlodgeForum@yahoogroups.com, Patty Austin wrote:
> > It is not just the windshield it is the entire coach, all windows become so
wet they soak the frames at the bottoms. Does this still sound like a heater
core leak? How can i tell the difference? Is the fresh air the vents?
> > Thanks
> > Patty Austin
> > 88 BB Wanderlodge WBPT40
> > Tampa Fl
> > --- On Fri, 2/5/10, Chuck Wheeler wrote:
> > From: Chuck Wheeler
> > Subject: RE: [WanderlodgeForum] foggy humid wet windows
> > To: WanderlodgeForum@yahoogroups.com
> > Date: Friday, February 5, 2010, 11:59 AM
> > I have found that when we are in really humid weather I have to open the
fresh air to the heater to help the defrosters prevent fogging. There is also a
possibility that you have a leak in the heater core. This will cause severe
fogging.
> > - Chuck Wheeler-
> > 1982 FC 31SB Fort Worth TX
> > From: WanderlodgeForum@yahoogroups.com [mailto:
WanderlodgeForum@yahoogroups.com ] On Behalf Of patty_austin
> > Sent: Friday, February 05, 2010 10:41 AM
> > Subject: [WanderlodgeForum] foggy humid wet windows
> > Can anyone help us? Everytime we hit rain the windshield fogs so badly the
coach is undrivable. We wipe them down, the defroster is on (does not help).
Seems the only thing that improves the condition is to turn the airconditioners
on all around to a popcicle temperature and freeze but hey the windshield is
clear. I cant believe they made the coach to run this way, it must be some
settings that we are overlooking. Anyone experience this and find out how to
correct it? It is just so annoying and time consuming.
> > Thanks in advance for anything that could help us out,
> > Patty Austin
> > 88 wanderlodge PT40
> > Tampa FL
