PT Air Intake Change
11-06-2008, 15:59
Has anyone modified the engine air intake on the PT roof?
My bus collects leaves on the roof this time of year, and that means that the forward-facing "ram air" style air intake on the roof ends up clogged with leaves. Has anyone modified the intake with some sort of different "mouth"? With the blower and a turbo, I can't imagine there is any real benefit from any "ram air" effect. I thought of turning it around so the intake faces the rear, but was concerned about whether I'd encounter some sort of vaccuum that made it harder to suck air in. Suggestions? Scott Forman 86 PT38 Memphis |
11-06-2008, 17:52
maybe your intake is modified. I've seen it both ways???????????
Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > Has anyone modified the engine air intake on the PT roof? > > My bus collects leaves on the roof this time of year, and that means > that the forward-facing "ram air" style air intake on the roof ends up > clogged with leaves. Has anyone modified the intake with some sort of > different "mouth"? With the blower and a turbo, I can't imagine there > is any real benefit from any "ram air" effect. I thought of turning it > around so the intake faces the rear, but was concerned about whether > I'd encounter some sort of vaccuum that made it harder to suck air in. > > Suggestions? > > Scott Forman > 86 PT38 > Memphis > |
11-07-2008, 00:01
My coach is parked under our pecan trees. The whole length of the roof is full of leaves. I'll blow those away with my air hose before firing the engine.
Ernie Ekberg 83PT40 Weatherford, Texas |
11-07-2008, 04:33
Mine has a grill on the front. Maybe you could get some stainless mesh and attach it to the front so you wouldn't get debris of any size down in there. Jim Riordan Stuart, Fl 88 WBWL XXV Scott Forman <scottforman75@...> wrote:
11-07-2008, 05:36
I note that the air intake on the DD Series 60 engines are simply a
grate on the curb-side of the coach above the grate-style side access door. There is zero ram effect from this arrangement. I believe that you are correct that with the turbo system, the ram effect is probably negligible. I would, however, concur that turning the intake toward the rear might cause a 'negative' (suction) effect that is undesirable. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at On Nov 6, 2008, at 9:59 PM, Scott Forman wrote: > Has anyone modified the engine air intake on the PT roof? > > My bus collects leaves on the roof this time of year, and that means > that the forward-facing "ram air" style air intake on the roof ends up > clogged with leaves. Has anyone modified the intake with some sort of > different "mouth"? With the blower and a turbo, I can't imagine there > is any real benefit from any "ram air" effect. I thought of > turning it > around so the intake faces the rear, but was concerned about whether > I'd encounter some sort of vaccuum that made it harder to suck air in. > > Suggestions? > > Scott Forman > 86 PT38 > Memphis > |
11-07-2008, 13:10
I put hardware cloth over the front about 2 inches in front of the scoop so it catches the leaves and when i shut down they fall off
RE -------------- Original message from jim riordan |
11-09-2008, 09:00
The mesh is what gets clogged
Scott --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > Mine has a grill on the front. Maybe you could get some stainless mesh and attach it to the front so you wouldn't get debris of any size down in there. > > Jim Riordan > Stuart, Fl > 88 WBWL XXV > > Scott Forman <scottforman75@...> wrote: > Has anyone modified the engine air intake on the PT roof? > > My bus collects leaves on the roof this time of year, and that means > that the forward-facing "ram air" style air intake on the roof ends up > clogged with leaves. Has anyone modified the intake with some sort of > different "mouth"? With the blower and a turbo, I can't imagine there > is any real benefit from any "ram air" effect. I thought of turning it > around so the intake faces the rear, but was concerned about whether > I'd encounter some sort of vaccuum that made it harder to suck air in. > > Suggestions? > > Scott Forman > 86 PT38 > Memphis > |
11-11-2008, 00:18
The screen will plug with leaves and you can't develop enough power thru in 5th gear. also you exhaust temp will go thru the roof.
re brake 1984 Pt-40
