3208NA driving tips
04-21-2007, 12:41
3208NA driving tips
Hey, On our recent trip to Moab (3 passes between here and anything
remotely flat)I recently went into "full fuel" (read:overfuel) mode. Propane helps when acelerating, but when you get into an overfuel situation, it seems to have no real benefit. My question is: when pulling a grade, what driving style do you prefer? As far as going by the full fuel light, should I back out until it just flickers and have some popcorn until I reach the top, or just keep pouring the coals to her (or him as the case may be)? What seems to work best?? Best to all, Doug n' Pokey. Doug Engel, Gunnison, CO., 1981 FC35SB, "Pokey" |
04-21-2007, 13:28
3208NA driving tips
If you have looked at the circuit, the "Full fuel flow" display just
indicates that the injector pump has hit it's stop and will not flow any more fuel. You have probably noted that it is a function of RPMs and throttle position. My cruise control will put it into "Full fuel flow" rather frequently. If we are maintain speed and temperatures are within range I don't worry about it. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of doug_ngl Sent: Saturday, April 21, 2007 7:41 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] 3208NA driving tips Hey, On our recent trip to Moab (3 passes between here and anything remotely flat)I recently went into "full fuel" (read:overfuel) mode. Propane helps when acelerating, but when you get into an overfuel situation, it seems to have no real benefit. My question is: when pulling a grade, what driving style do you prefer? As far as going by the full fuel light, should I back out until it just flickers and have some popcorn until I reach the top, or just keep pouring the coals to her (or him as the case may be)? What seems to work best?? Best to all, Doug n' Pokey. Doug Engel, Gunnison, CO., 1981 FC35SB, "Pokey" [Non-text portions of this message have been removed] |
04-23-2007, 01:49
3208NA driving tips
Doug,
We don't have propane injection nor do we have a full fuel light to watch. We gained some hill climbing experience on Monarch Pass last summer that may apply to your question. We're normally flat landers by comparison to Colorado so we had a steep learning curve on our drive to Ouray. We found that we could overheat the coach fairly easy by holding the throttle to the floor for extended periods while the coach gradually lost speed and bogged down. Part of our overheat/boilover problem was a weak spring on the old radiator cap which was replaced during the trip. On our trip home to Texas, we experienced less overheating by proactively selecting lower gears and accepting slower speeds (say 20-30 mph) that could be maintained at something less than full throttle. We've since installed a switch that allows us to engage the radiator fan before getting too hot and that is also helpful. We recently had the valves adjusted on the 3208 and I've noticed a distinct improvement in power. It'll be interesting to see how the coach works the next time we hit some serious grade. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > Hey, On our recent trip to Moab (3 passes between here and anything > remotely flat)I recently went into "full fuel" (read:overfuel) mode. > Propane helps when acelerating, but when you get into an overfuel > situation, it seems to have no real benefit. My question is: when > pulling a grade, what driving style do you prefer? As far as going by > the full fuel light, should I back out until it just flickers and have > some popcorn until I reach the top, or just keep pouring the coals to > her (or him as the case may be)? What seems to work best?? Best to all, > Doug n' Pokey. > Doug Engel, Gunnison, CO., 1981 FC35SB, "Pokey" > |
04-23-2007, 02:52
3208NA driving tips
Thanks for teh input. Yours being a 84 should be turbo, so there is some
difference there for sure. Best Wishes, Doug n' Pokey Eric Johnson We don't have propane injection nor do we have a full fuel light to watch. We gained some hill climbing experience on Monarch Pass last summer that may apply to your question. We're normally flat landers by comparison to Colorado so we had a steep learning curve on our drive to Ouray. We found that we could overheat the coach fairly easy by holding the throttle to the floor for extended periods while the coach gradually lost speed and bogged down. Part of our overheat/boilover problem was a weak spring on the old radiator cap which was replaced during the trip. On our trip home to Texas, we experienced less overheating by proactively selecting lower gears and accepting slower speeds (say 20-30 mph) that could be maintained at something less than full throttle. We've since installed a switch that allows us to engage the radiator fan before getting too hot and that is also helpful. We recently had the valves adjusted on the 3208 and I've noticed a distinct improvement in power. It'll be interesting to see how the coach works the next time we hit some serious grade. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > Hey, On our recent trip to Moab (3 passes between here and anything > remotely flat)I recently went into "full fuel" (read:overfuel) mode. > Propane helps when acelerating, but when you get into an overfuel > situation, it seems to have no real benefit. My question is: when > pulling a grade, what driving style do you prefer? As far as going by > the full fuel light, should I back out until it just flickers and have > some popcorn until I reach the top, or just keep pouring the coals to > her (or him as the case may be)? What seems to work best?? Best to all, > Doug n' Pokey. > Doug Engel, Gunnison, CO., 1981 FC35SB, "Pokey" > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. [Non-text portions of this message have been removed] |
04-23-2007, 03:06
3208NA driving tips
Doug:
I suspect you don't have a pyrometer, but the EGT's are a pretty important measure in deciding how hard to push the coach. Last year, when running through the hills of WV, the crossover pipe which feeds my aftermarket turbo started to fail, resulting in lower air inputs and overfueling. I noticed a marked increase in EGT's to the point that I was becoming quite concerned. It was running about 200 degrees hotter than normal. I would be concerned that the propane injection might produce a similar result. Without piston coolers (which the turbo motor has, but the NA doesn't), this puts the pistons in danger of melting. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Doug Engel > > Thanks for teh input. Yours being a 84 should be turbo, so there is some difference there for sure. Best Wishes, Doug n' Pokey |
04-23-2007, 10:36
3208NA driving tips
Kerry,
Thanks for the input. Mine is NA, so no turbo and no pyrometer. To the best of my knowledge, the propane does not significantly increase the EGT, which can be a real killer as I'm sure you know. Thanks again, Doug davidkerryedwards Doug: I suspect you don't have a pyrometer, but the EGT's are a pretty important measure in deciding how hard to push the coach. Last year, when running through the hills of WV, the crossover pipe which feeds my aftermarket turbo started to fail, resulting in lower air inputs and overfueling. I noticed a marked increase in EGT's to the point that I was becoming quite concerned. It was running about 200 degrees hotter than normal. I would be concerned that the propane injection might produce a similar result. Without piston coolers (which the turbo motor has, but the NA doesn't), this puts the pistons in danger of melting. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Doug Engel > > Thanks for teh input. Yours being a 84 should be turbo, so there is some difference there for sure. Best Wishes, Doug n' Pokey Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. [Non-text portions of this message have been removed] |
