Cruise Air
09-24-2006, 08:15
Cruise Air
Robert, under your couch, there is a return air with 2 tabs on the top that
will give you access to the first filter. Way inside is a screen, or filter
that needs cleaning also.
83 PT40
Livingston, Montana
09-24-2006, 09:58
Cruise Air
i'm needing instruction on how to change or clean air conditioner
filter on the front a/c of a 1985 pt40 w/cruise a/c.
thank you robert
o.k.c. ok
1985 pt40
09-24-2006, 10:21
Cruise Air
That Cruise Air filter has tabs on the side that make it stay put. You have
to either pry it out-- or that filter may have been removed and discarded.
Bluebird had many couches. On mine, I have to pull up and then pull toward the
center of the coach. Its a pain. When folks ask how many people can your coach
sleep? I say 2 and then our 3 pups.
83 PT40
Livingston, Montana
09-24-2006, 13:17
Cruise Air
top that
or filter
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
ernie, i found the vent under the couch, but i can't see how to
remove the filter, is there a screen and a filter? do you remove or
clean it. also i have another question about the factory couch i
can't seem to pull it out far enough to make it into a bed. how wide
is the bed when it is pulled out? (queen)? are there three cushions
on the back?
thanks,robert
85 pt40i pur a couc
okc ok.
