					Dinette booth width.
					04-17-2006, 00:42
					Johnny, Bluebird added some 90 degree brackets that the carpet maybe
			covering up. You'd have to pull the carpet back to see them. The previous owner of my coach cut the width of the booth down and it made a tremendous difference. Goood luck with your project. Ernie ekberg-83pt40 in louisiana [Non-text portions of this message have been removed]  |
					04-17-2006, 04:27
					Hello, has  anyone cut their dinette booth off to remove the offset
			that extends out in the isle. I'm trying to remove the box beneath the benches. I have every screw I can see out and it still won't budge. Are there any screws under the carpet that need to be removed. My coach is a 84 PT35 and I would like to cut the booth off to make it even with the fridge. Thanks, Johnny Slone Pikeville, Ky 84 PT35  |
					04-17-2006, 06:10
			> > Johnny, Bluebird added some 90 degree brackets that the carpet maybe > covering up. You'd have to pull the carpet back to see them. I took the benches out on my 85 and there were the brackets that Ernie mentions holding the bases. I left the bases as they were because there is a heater core in the base by the door on mine that could not be moved without a lot of work. You could cut about 6 '' off the bench without changing the base. We don't use the benches so I built storage over the existing bases. Good luck on your project, Lee Benson, 85FC35, Carthage, IN  |
					04-19-2006, 15:25
					Thanks Ernie, and Lee for your replys. I have decided to just remove
			the 6 inches from the seats and not change the width of the frames. The wife is happy and this way is much less work. I have one side done and it makes a big difference in the looks. Thanks again, Johnny M Slone Pikeville, Ky 84 PT35  |
