New member - posting info. A& air brake "learning" needed
02-14-2007, 13:04
I'm the pride owner of a 1965+/- Bus/RV with a Chevy 366V8 gas
engine, 4-spd. manual transmission, etc. that's a great old RV. Trouble is - I had air compressor issues and let it sit for several (count like 7 yrs.) and now I want to make it come alive! I'm changing fluids, pre-lubing engine, install new engine monitoring gauges, etc. before I crank it up. But my real concern is the clutch, the compressor for the brakes, and the air brake system itself. Do I go w/ what I've got and fix leaks as they occur or do I replace all my air lines due to their 35+ yrs. This was a school transit bus so it was built tough...in the 1960's though? *Where can I go to learn more about my air brakes and how they operate? I've got parts I cannot ID and I'd like to photo them and ask group's advice! **How do I attach photos to a post to this group? Larry Ga. |
02-14-2007, 21:06
Larry, It sounds like you have alot of work ahead of you but I would do the same
thing. Air brakes are air brakes no matter what vehicle they are on so I would start looking around 18 wheeler shops or web sites or whatever. They work on the same setup and they may help you more since the deal with it every day. dan I'm the pride owner of a 1965+/- Bus/RV with a Chevy 366V8 gas engine, 4-spd. manual transmission, etc. that's a great old RV. Trouble is - I had air compressor issues and let it sit for several (count like 7 yrs.) and now I want to make it come alive! I'm changing fluids, pre-lubing engine, install new engine monitoring gauges, etc. before I crank it up. But my real concern is the clutch, the compressor for the brakes, and the air brake system itself. Do I go w/ what I've got and fix leaks as they occur or do I replace all my air lines due to their 35+ yrs. This was a school transit bus so it was built tough...in the 1960's though? *Where can I go to learn more about my air brakes and how they operate? I've got parts I cannot ID and I'd like to photo them and ask group's advice! **How do I attach photos to a post to this group? Larry Ga. Yahoo! Groups Links --------------------------------- Looking for earth-friendly autos? Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. [Non-text portions of this message have been removed] |
02-15-2007, 04:53
Larry,
Welcome to the WanderlodgeForum! Look in the Files section for an Airbrake Troubleshooting Guide for an overview of the system. Of course the easy approach is to fire it up and see if you have brakes, before you just start replacing everything. I'd inspect all the lines for obvious wear and tear or breaks. I'd look for rust and corrosion on all the components if there was moisture in the system while it sat. Does it have an air dryer on it? As far as the clutch, on that old a vehicle it should be just a mechanical linkage clutch. If the clutch lining is/was good, there shouldn't be much of a problem. It's just been sitting there sandwiched between the pressure plate and the flywheel safely tucked in bed all these years. It's either going to work or not. If it wasn't glazed or worn out to begin with, it should work. Good luck. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX - on the way to Lubbock on business rather than to the LSB Rally! :^( --- In WanderlodgeForum@yahoogroups.com, "larry_word" wrote: > > I'm the pride owner of a 1965+/- Bus/RV with a Chevy 366V8 gas > engine, 4-spd. manual transmission, etc. that's a great old RV. > > Trouble is - I had air compressor issues and let it sit for several > (count like 7 yrs.) and now I want to make it come alive! > > I'm changing fluids, pre-lubing engine, install new engine monitoring > gauges, etc. before I crank it up. But my real concern is the clutch, > the compressor for the brakes, and the air brake system itself. Do I > go w/ what I've got and fix leaks as they occur or do I replace all > my air lines due to their 35+ yrs. This was a school transit bus so > it was built tough...in the 1960's though? > > *Where can I go to learn more about my air brakes and how they > operate? I've got parts I cannot ID and I'd like to photo them and > ask group's advice! > > **How do I attach photos to a post to this group? > > Larry > Ga. > |
