oil type
03-28-2008, 06:07
oil type
What oil to use in 8v92 Delo 40 weight 400 or what. Thanks
Jack Jones 87 pt 40 |
03-28-2008, 06:23
oil type
Straight 40. I'm not overly brand-conscious, but it happens that I'm sitting in
the waiting room (the wonders of air cards!) of a DD service operation getting an oil change as I type this, and they are using Delo 100. As an aside, CCW tried to change my oil in January but couldn't get the plug out. It has/had a male square 5/8-inch plug. The guys here were only able to round it off some more, so they welded a large nut to it, and that allowed them to get enough torque to do the job. It was cross-threaded, with most of the damage done to the plug and not the pan. They think that cleaning the threads with a tap will allow a new plug to work OK. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 3/28/2008 at 5:07 PM birdboat45 wrote: >What oil to use in 8v92 Delo 40 weight 400 or what. Thanks >Jack Jones >87 pt 40 |
03-29-2008, 04:45
oil type
Jack,
There is many varied opinions about oil.
I use only Shell Rotella 40 weight in my 8V92. I buy it from the local distributor.
Howard Truitt
Camilla, Ga.
86 8V92 PT40
