Grille removal
09-05-2005, 07:45
Grille removal
Anyone out there know the procedure for removing the grille over the
radiator on a 92WB40. The top is held in place with a non-removable allen head screw anchor of some sort. If you turn it cw till it stops, it holds firm. If you turn it ccw till it stops, the grille is loose but will not come off. There has to be a simple trick to this. R.E. (Ron) Marabito, Dallas, TX 92WB40 |
09-05-2005, 10:27
Grille removal
O.K. everyone, I figured it out, but BB natched the body too little to
make for easy removal. The three latches at the top of the grille are similar to drawer locks with a cam, except when in the locked position, they can be screwed in and tightened. I am taking my grinder to the notch to improve removal and installation tolerances. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > Anyone out there know the procedure for removing the grille over the > radiator on a 92WB40. The top is held in place with a non-removable > allen head screw anchor of some sort. If you turn it cw till it > stops, it holds firm. If you turn it ccw till it stops, the grille is > loose but will not come off. There has to be a simple trick to this. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 |
09-05-2005, 10:38
Grille removal
Hey Ron,
Inquiring minds want to know: Why you are taking the radiator grille off in the first place? Something bad happen? Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > O.K. everyone, I figured it out, but BB natched the body too little to > make for easy removal. The three latches at the top of the grille are > similar to drawer locks with a cam, except when in the locked > position, they can be screwed in and tightened. > > I am taking my grinder to the notch to improve removal and > installation tolerances. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > Anyone out there know the procedure for removing the grille over the > > radiator on a 92WB40. The top is held in place with a non-removable > > allen head screw anchor of some sort. If you turn it cw till it > > stops, it holds firm. If you turn it ccw till it stops, the grille > is > > loose but will not come off. There has to be a simple trick to this. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 |
09-05-2005, 12:04
Grille removal
I wanted to clean any road dirt out of the face of the radiator. It
wasn't bad surprisingly, but a little dirty at the bottom. I don't want any surprises like overheating when I'm on the road. Ron --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > Hey Ron, > > Inquiring minds want to know: Why you are taking the radiator grille > off in the first place? Something bad happen? > > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale > 91 PT40 "Texas Minivan" > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > O.K. everyone, I figured it out, but BB natched the body too little to > > make for easy removal. The three latches at the top of the grille are > > similar to drawer locks with a cam, except when in the locked > > position, they can be screwed in and tightened. > > > > I am taking my grinder to the notch to improve removal and > > installation tolerances. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Anyone out there know the procedure for removing the grille over the > > > radiator on a 92WB40. The top is held in place with a non- removable > > > allen head screw anchor of some sort. If you turn it cw till it > > > stops, it holds firm. If you turn it ccw till it stops, the grille > > is > > > loose but will not come off. There has to be a simple trick to this. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 |
09-05-2005, 13:29
Grille removal
From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 05, 2005 7:04 PM Subject: [WanderlodgeForum] Re: Grille removal Ron Blow it out with air water can turn it to mud and when it dryes you will be worse off also the water you use may have hi hp.and that can cause your radiator to deteriorate Bob Loomas 85 PT 36 I wanted to clean any road dirt out of the face of the radiator. It wasn't bad surprisingly, but a little dirty at the bottom. I don't want any surprises like overheating when I'm on the road. Ron --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > Hey Ron, > > Inquiring minds want to know: Why you are taking the radiator grille > off in the first place? Something bad happen? > > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale > 91 PT40 "Texas Minivan" > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > O.K. everyone, I figured it out, but BB natched the body too little to > > make for easy removal. The three latches at the top of the grille are > > similar to drawer locks with a cam, except when in the locked > > position, they can be screwed in and tightened. > > > > I am taking my grinder to the notch to improve removal and > > installation tolerances. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Anyone out there know the procedure for removing the grille over the > > > radiator on a 92WB40. The top is held in place with a non- removable > > > allen head screw anchor of some sort. If you turn it cw till it > > > stops, it holds firm. If you turn it ccw till it stops, the grille > > is > > > loose but will not come off. There has to be a simple trick to this. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
09-05-2005, 13:51
Grille removal
Bob: I used a coil cleaner that the service men use on A/C coils.
It boils out the dirt. I'll finish it off with air, once it has dried in the morning. Sure glad to hear from you. I sent you two emails but didn't get any response. Been keeping up with messages from others. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, bobloomas wrote: > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, September 05, 2005 7:04 PM > Subject: [WanderlodgeForum] Re: Grille removal > > Ron Blow it out with air water can turn it to mud and when it dryes you will be worse off also > the water you use may have hi hp.and that can cause your radiator to deteriorate > Bob Loomas 85 PT 36 > > > I wanted to clean any road dirt out of the face of the radiator. It > wasn't bad surprisingly, but a little dirty at the bottom. I don't > want any surprises like overheating when I'm on the road. > > Ron > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> > wrote: > > Hey Ron, > > > > Inquiring minds want to know: Why you are taking the radiator > grille > > off in the first place? Something bad happen? > > > > Mike Bulriss > > 83 PT40 "Stagecoach" - For Sale > > 91 PT40 "Texas Minivan" > > San Antonio, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > O.K. everyone, I figured it out, but BB natched the body too > little to > > > make for easy removal. The three latches at the top of the > grille are > > > similar to drawer locks with a cam, except when in the locked > > > position, they can be screwed in and tightened. > > > > > > I am taking my grinder to the notch to improve removal and > > > installation tolerances. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > Anyone out there know the procedure for removing the grille > over the > > > > radiator on a 92WB40. The top is held in place with a non- > removable > > > > allen head screw anchor of some sort. If you turn it cw till > it > > > > stops, it holds firm. If you turn it ccw till it stops, the > grille > > > is > > > > loose but will not come off. There has to be a simple trick > to this. > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] |
09-05-2005, 14:28
Grille removal
From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 05, 2005 8:51 PM Subject: [WanderlodgeForum] Re: Grille removal Ron My email service was down for two days last week.Fri. & Sat. Bob Loomas 85 PT 36 > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
09-05-2005, 15:42
Grille removal
Well! I'm glad that you and Letty are O.K.
Ron --- In WanderlodgeForum@yahoogroups.com, bobloomas wrote: > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, September 05, 2005 8:51 PM > Subject: [WanderlodgeForum] Re: Grille removal > > Ron My email service was down for two days last week.Fri. & Sat. > Bob Loomas 85 PT 36 > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] |
