Alternator/Voltage Regulator problem
09-10-2008, 04:18
I am having an intermittent problem that started about 3 weeks ago.
Sometimes, when starting the engine, my alternator pegs at maximum
output (300 amps) and the coach batteries peg the gauge at maximum
voltage charge (18 volts). The cranking batteries charge shows only 12
volts when this happens which indicates to me they aren't charging at
all . If I shut down and restart the engine several times, the
alternator and the charging voltage on the coach batteries and engine
cranking batteries eventually will work correctly. Normally, when
starting this coach, the engine starts and the alternator goes to 300
amps and then drops quickly to normal output (30 to 40 amps) and the
coach batteries, as well as the engine cranking batteries, charge at
their normal level (about 14 volts). The engine is a Detroit Series 60
with the large alternator.
I would appreciate information on what should be done to identify and
correct this problem.
Royal Washburn
'97 43'WB
09-10-2008, 04:57
Check the regulator
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "bbwlwb88"
> Royal Washburn
> '97 43'WB
09-10-2008, 07:19
if there is a reading with engine off and key on, it may be a gauge
ground prob.
Greg 94ptCalif
> Check the regulator
> Stephen 77fc35
ago.
maximum
maximum
only 12
charging at
engine
when
300
at
Series 60
> > Royal Washburn
> > '97 43'WB
09-10-2008, 13:40
Royal, I had the same problem a few months back
The alternator tached to 300 amps. The engine batts went down to 11V.
The Coach Batts. went up to 15.5V. The check engine light came on.
I'm happy this was only the bi-monthly 50 mile drive around the block!
The roadside fix, jumper cables from the engine Batts. to the house
Batts. It bypasses the solenoid, It got me home without frying
anything.
I just found these relays, Eaton / Cutler-Hammer # 6041H105 for
> $115.35
> http://www.masaero.com
Kurt Horvath
PT-42 WLWB
10AC
> Check the regulator
> Stephen 77fc35
ago.
maximum
maximum
only 12
charging at
engine
when
300
at
Series 60
> > Royal Washburn
> > '97 43'WB
09-12-2008, 08:15
Thanks for the roadside fix tip. You mentioned bypassing the
solenoid but did you have to replace it to stop the problem? You
also mentioned 3 relays but I wasn't clear on whether you had to
replace them or where they are located.
Royal Washburn
97 43'WL
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
11V.
block!
> anything.
> > $115.35
> Kurt Horvath
> PT-42 WLWB
> 10AC
> > Check the regulator
> > Stephen 77fc35
> ago.
> maximum
> maximum
> only 12
> charging at
> engine
> when
to
> 300
> the
charge
> at
> Series 60
identify
> and
> > > Royal Washburn
> > > '97 43'WB
09-12-2008, 12:33
Royal,
Yes I did have to replace the relay/solenoid. It did fix the problem.
Generally they are expensive and hard to find $400.00 PLUS $'S. I
found a great source, after I bought mine somewhere else---
Eaton / Cutler-Hammer # 6041H105 for $115.35
The company is Mas Aero
East Coast Headquarters
5330 Spectrum Drive
Frederick, MD 21703
(T) 301-631-8400
Toll Free: 800-489-0439
(F) 301-631-8425
It's not hard to replace. Remove power from the relay/solenoid, just
follow the ground to the frame and unhook it then follow the hot,
(RED), to the shunt just below the relay. take all the wires off.
Remove bad relay/solenoid then just reverse the process and you
should be good to go. I did the swap myself and I'm not that happy
working with Electricity of any kind. If you need more help just ask
these guys will fill in the gaps.
Kurt Horvath
95 PT-42
10AC
> Royal Washburn
> 97 43'WL
> 11V.
> block!
house
> > anything.
> > > $115.35
> > Kurt Horvath
> > PT-42 WLWB
> > 10AC
> > wrote:
> > > Check the regulator
> > > Stephen 77fc35
weeks
> > ago.
> > maximum
> > maximum
shows
> > only 12
> > charging at
> > engine
> > when
goes
> to
> > 300
> and
> > the
> charge
> > at
> > Series 60
> identify
> > and
> > > > Royal Washburn
> > > > '97 43'WB
09-13-2008, 00:37
Kurt, thanks again for your help and for the additional info.
Royal Washburn
97 43'WL
> Royal,
problem.
> 5330 Spectrum Drive
> Frederick, MD 21703
> (T) 301-631-8400
> (F) 301-631-8425
just
ask
> Kurt Horvath
> 95 PT-42
> 10AC
> > Royal Washburn
> > 97 43'WL
to
> > 11V.
on.
> > block!
> house
> > > anything.
> > > > $115.35
> > > Kurt Horvath
> > > PT-42 WLWB
> > > 10AC
> > > wrote:
> > > > Check the regulator
> > > > Stephen 77fc35
> weeks
> > > ago.
> > > maximum
> > > maximum
> shows
> > > only 12
> > > charging at
> the
> and
> > > engine
Normally,
> > > when
> goes
> > to
> > > 300
amps)
> > and
> > > the
> > charge
> > > at
Detroit
> > > Series 60
> > identify
> > > and
> > > > > Royal Washburn
> > > > > '97 43'WB
