8K Onan Generator
10-21-2005, 08:05
8K Onan Generator
Hi Everyone,
Has anyone removed the 7.5/8K Onan from a late model FC. It appears to hangs from four long rod bolts. Looks simple enough, but we all know how these jobs turn into major projects. I want to replace insulation and service the radiator, hoses and cooling motor. Any advice will be appreciated. Bill 88 FC Michigan |
10-22-2005, 07:55
8K Onan Generator
> > removing generator...my ole 77fc had 4 bolts..i put two jacks underneat the steel platform holding it and then let it down after undoing the bolts etc..??this make any sense?? regards, Haqnk Hannigan ole 77FC33 now 90Sp36 > > Hi Everyone, > > Has anyone removed the 7.5/8K Onan from a late model FC. > > It appears to hangs from four long rod bolts. > Looks simple enough, but we all know how these jobs turn > into major projects. I want to replace insulation and > service the radiator, hoses and cooling motor. > Any advice will be appreciated. > Bill 88 FC Michigan > |
10-23-2005, 01:48
8K Onan Generator
Hank,
Yep, you make sense. I had the Bird in storage and was looking for ideas. Now that it is home, it looks as you say, a steel platform and four big bolts. The problem will be removing the rusty exhaust and getting the motivation for a project. I may wait until next Spring/Summer. Stephen is shipping the insulation. I must first winterize the plumbing, change the oil, filters, and squirt some grease into the chassis ( I hate that dirty job ) Going to change the propane detector, solenoid shut-off and propane regulator. We had some intermittent propane pressure problems last winter. 35 degrees this morning, Will use an additive and fill with winter diesel. Still around $3.00/gal THanks, Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > > > > removing generator...my ole 77fc had 4 bolts..i put two jacks > underneat the steel platform holding it and then let it down after > undoing the bolts etc..??this make any sense?? > regards, > Haqnk Hannigan > ole 77FC33 now 90Sp36 > > > > Hi Everyone, > > > > Has anyone removed the 7.5/8K Onan from a late model FC. > > > > It appears to hangs from four long rod bolts. > > Looks simple enough, but we all know how these jobs turn > > into major projects. I want to replace insulation and > > service the radiator, hoses and cooling motor. > > Any advice will be appreciated. > > Bill 88 FC Michigan > > > |
10-23-2005, 09:27
8K Onan Generator
-Bill: watch out how u hook up the exhaust pipe for genny when u
do the job..i learned the hard way as it was hooked too close to passenger side back BRAKE HOSE..and I lost it AFTER arriving in RENO from california...lucky it did not burn out comming down the mountain...happened in a parking in RENO...i had spare hose and was on my way in an hour. Hank Hannigan 90sp36 in Hawaii for now -- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Hank, > > Yep, you make sense. > > I had the Bird in storage and was looking for ideas. > Now that it is home, it looks as you say, a steel platform and four > big bolts. The problem will be removing the rusty exhaust and > getting the motivation for a project. I may wait until next > Spring/Summer. Stephen is shipping the insulation. > > I must first winterize the plumbing, change the oil, filters, and > squirt some grease into the chassis ( I hate that dirty job ) > Going to change the propane detector, solenoid shut-off and propane > regulator. We had some intermittent propane pressure problems last > winter. 35 degrees this morning, Will use an additive and fill with > winter diesel. Still around $3.00/gal > > THanks, > > Bill 88 FC Michigan > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > > > > > > > removing generator...my ole 77fc had 4 bolts..i put two jacks > > underneat the steel platform holding it and then let it down after > > undoing the bolts etc..??this make any sense?? > > regards, > > Haqnk Hannigan > > ole 77FC33 now 90Sp36 > > > > > > Hi Everyone, > > > > > > Has anyone removed the 7.5/8K Onan from a late model FC. > > > > > > It appears to hangs from four long rod bolts. > > > Looks simple enough, but we all know how these jobs turn > > > into major projects. I want to replace insulation and > > > service the radiator, hoses and cooling motor. > > > Any advice will be appreciated. > > > Bill 88 FC Michigan > > > > > > |
