Help with Onan 7.5 kw generator fuel pump
11-17-2007, 09:26
OK guys, help me escape my mother-in-laws in New Jersey!
I started having generator troubles last night, it was losing rpm's and surging, finally would not run at all and would not restart. It felt like a fuel issue to me, I drained the on engine filter, all the fuel that came out looked clean but I went ahead and changed the filter anyway, still no go. It has an electric boost pump, and it does not appear to be functioning right from what I can tell. I have the pump off the generator. When I give it 12 volts from the battery, it will bump but not continue to run. Strangely enough, if I turn it upside down and give it power it will run 10-15 seconds and pumps strong before it cuts off. I have taken the bottom off the pump housing and taken everything out I can see, a couple of springs, ball plungers and 2 o rings, everything looks ok that I can get to. It is a Facet pump, no part or model numbers on the pump and the local NAPA store here did not have one. Any more ideas or wait til Monday and see what the Onan place in Newark can do for me? We can travel without the genny, but it would be nice to have. I don't have email access here so reply on the board or call me at 336-402-0943 if anyone has any ideas. Regards, Dave 1990 36 SP |
11-17-2007, 12:00
Hi Dave:
Most any 12vdc fuel pump will work so long as the meets or exceeds the pressure delivery. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 09:26 PM 11/17/2007 +0000, you wrote: >OK guys, help me escape my mother-in-laws in New Jersey! >I started having generator troubles last night, it was losing rpm's >and surging, finally would not run at all and would not restart. It >felt like a fuel issue to me, I drained the on engine filter, all the >fuel that came out looked clean but I went ahead and changed the >filter anyway, still no go. It has an electric boost pump, and it >does not appear to be functioning right from what I can tell. I have >the pump off the generator. When I give it 12 volts from the battery, >it will bump but not continue to run. Strangely enough, if I turn it >upside down and give it power it will run 10-15 seconds and pumps >strong before it cuts off. I have taken the bottom off the pump >housing and taken everything out I can see, a couple of springs, ball >plungers and 2 o rings, everything looks ok that I can get to. It is >a Facet pump, no part or model numbers on the pump and the local NAPA >store here did not have one. Any more ideas or wait til Monday and >see what the Onan place in Newark can do for me? We can travel >without the genny, but it would be nice to have. > >I don't have email access here so reply on the board or call me at >336-402-0943 if anyone has any ideas. > >Regards, >Dave >1990 36 SP > > |
