Help 85 PT 36
05-11-2006, 04:47
Help 85 PT 36
Does anyone have a diagram showing wiring from ignition switch to
starter solenoid. I turn the switch, it appears to work; I hear a solenoid making, but starter does not engage. Suggestions appreciated. Rex 85PT36 |
05-11-2006, 09:51
Help 85 PT 36
Wiggle the shifter to make sure you are definitely in park. I have
stopped for the day, set the parking brake and shut it off and it still be in gear the day when its time to start it. So check to make sure you are in neutral. Secondly, make sure the A/T switch on the dash is in the run mode. This switch disables something so that the Detroit won't start. Where you from Rex? Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Rex" > > Does anyone have a diagram showing wiring from ignition switch to > starter solenoid. I turn the switch, it appears to work; I hear a > solenoid making, but starter does not engage. Suggestions appreciated. > > Rex > 85PT36 > |
05-11-2006, 10:54
Help 85 PT 36
> From: "Jay Darst" > Date: 2006/05/11 Thu PM 05:51:34 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Help 85 PT 36 > > I had the same problem on the road,and a mechanic found a solenoid on the frame below the engine that was bad. very hard to find, particularly with all the grease-he bypassed the solenoid and when I returned home I replaced it. Bill Rush 84PT40 |
