heat while driving
10-13-2009, 00:35
heat while driving
Wayne,
The S60 doesn't have the gate valves the v92s have. Just turn the heat on and it should work. Paul 97wb43 --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > Does anyone know where the gate valves are on a 1996 PT42 with a 60 series? > Wayne Kotila > 1996 PT42 > > > > > ________________________________ > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Mon, October 12, 2009 9:48:46 PM > Subject: Re: [WanderlodgeForum] heat while driving > > à > Jana, > > I needed to do some more investigation into the heating so did so the last day. Here is what I find. Hopefully this helps. > > > Gate Valve Operation- 1987 PT38 Your coach is most likely the same. > Five Gate Valvesare located at the rear of the coach.à à > Two Valvesare located on the street side at or just forward at the 8V92 water pump. They control the coolant flow to Dash Heat. In the open position they allowà heated coolant to flow to the dash heater.à > Two more valvesââ¬Â¦one is located forward of and below the top of the rear bumper inside the frame rail. The other one is located curb side of the 8V92 and the Thermostat housing. They control the coolant flow to the chassis heaters, perhaps four heaters depending on year and length. > The 5th valveââ¬Â¦ is located curb side about shoulder height just inside the engine room door. It seems to be for isolating the water heater in the event of a blowout in the heat exchanger or if you are working on the heater. > Keep us post as we learn as others. > > > > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > > > On Mon, Oct 12, 2009 at 3:48 PM, Jana Ewart > > à > >Thanks for all the suggestions -- we found two valves in the back -- will continue to try different combs. > >Jana > > > > > >On Sun, Oct 11, 2009 at 3:27 PM, GARY MINKER > > > >à > >>Front heat is a cavalcade of events.à You have gate valves on the engine that need to be open. There are magnetic valves that have to work to let hot water flow. There are 4 or more fuses that need to be good and a dash switch.à Then it helps if the booster pump works.à then once it all works, it won't shut off and cooks you in the summer time.à Oh did I mention you might have a winter/summer switch that may be wired wrong and open the wrong valve and run the wrong pump. > >>Gary > >>85 PT-40 > >> > >>--- On Sat, 10/10/09, Jana Ewart > >> > >> > >>>From: Jana Ewart > >>>Subject: [WanderlodgeForum] heat while driving > >>>To: WanderlodgeForum@ yahoogroups. com > >>>Date: Saturday, October 10, 2009, 1:55 PM > >>> > >>> > >>> > >>>à > >>>We are finally on the road "full-time" as of this morning. à It is cooooollllldddd up here in the north. à Can anyone give us some ideas how to get dash heat while going down the road? à We have the right vent and left vent closed, the front heat under the camera is all the way to heat -- but the right and left fan switches only blow cold air. à Is there another button or switch we need to turn on? à Thanks so much. > >>> > >>> > >>>Jana (with ice cube feet) > >>>89pt40wb > >>>The Bird House is on the road! > >>>Still in South Dakota > >>> > >>>-- > >>>Blessed are the people whose God is the Lord. (Psalm 144:15) > >>> > >>> > >> > > > > > >-- > >Blessed are the people whose God is the Lord. (Psalm 144:15) > > > > > |
10-13-2009, 02:17
heat while driving
Thanks for the info Curt.
Wayne
From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Tue, October 13, 2009 12:00:07 AM Subject: Re: [WanderlodgeForum] heat while driving Look for round 2+" that rotate either way. Could be ball vales instead of gate vales...look for handles vs. round handles. I'm not up to speed on the 60 series. But, my guess, BB plumbed the 60's basically the same as the 8V92. Someone wil chime in with more info. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Mon, Oct 12, 2009 at 9:30 PM, Wayne Kotila <"waynekotila@yahoo.com"> wrote:
Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
10-13-2009, 16:25
heat while driving
Thanks Paul.
Wayne
96 PT42
From: p_a_lazar To: WanderlodgeForum@yahoogroups.com Sent: Tue, October 13, 2009 7:35:51 AM Subject: [WanderlodgeForum] Re: heat while driving Wayne, The S60 doesn't have the gate valves the v92s have. Just turn the heat on and it should work. Paul 97wb43 --- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila > > Does anyone know where the gate valves are on a 1996 PT42 with a 60 series? > Wayne Kotila > 1996 PT42 > > > > > ____________ _________ _________ __ > From: Curt Sprenger > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Mon, October 12, 2009 9:48:46 PM > Subject: Re: [WanderlodgeForum] heat while driving > > Ãâ > Jana, > > I needed to do some more investigation into the heating so did so the last day. Here is what I find. Hopefully this helps. > > > Gate Valve Operation- 1987 PT38 Your coach is most likely the same. > Five Gate Valvesare located at the rear of the coach.Ãâ Ãâ > Two Valvesare located on the street side at or just forward at the 8V92 water pump. They control the coolant flow to Dash Heat. In the open position they allowÃâ heated coolant to flow to the dash heater.Ãâ > Two more valvesâââ¬Ã¦one is located forward of and below the top of the rear bumper inside the frame rail. The other one is located curb side of the 8V92 and the Thermostat housing. They control the coolant flow to the chassis heaters, perhaps four heaters depending on year and length. > The 5th valveâââ¬Ã¦ is located curb side about shoulder height just inside the engine room door. It seems to be for isolating the water heater in the event of a blowout in the heat exchanger or if you are working on the heater. > Keep us post as we learn as others. > > > > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > > > On Mon, Oct 12, 2009 at 3:48 PM, Jana Ewart > > Ãâ > >Thanks for all the suggestions -- we found two valves in the back -- will continue to try different combs. > >Jana > > > > > >On Sun, Oct 11, 2009 at 3:27 PM, GARY MINKER > > > >Ãâ > >>Front heat is a cavalcade of events.Ãâ You have gate valves on the engine that need to be open. There are magnetic valves that have to work to let hot water flow. There are 4 or more fuses that need to be good and a dash switch.Ãâ Then it helps if the booster pump works.Ãâ then once it all works, it won't shut off and cooks you in the summer time.Ãâ Oh did I mention you might have a winter/summer switch that may be wired wrong and open the wrong valve and run the wrong pump. > >>Gary > >>85 PT-40 > >> > >>--- On Sat, 10/10/09, Jana Ewart > >> > >> > >>>From: Jana Ewart > >>>Subject: [WanderlodgeForum] heat while driving > >>>To: WanderlodgeForum@ yahoogroups. com > >>>Date: Saturday, October 10, 2009, 1:55 PM > >>> > >>> > >>> > >>>Ãâ > >>>We are finally on the road "full-time" as of this morning. ÃâIt is cooooollllldddd up here in the north. ÃâCan anyone give us some ideas how to get dash heat while going down the road? ÃâWe have the right vent and left vent closed, the front heat under the camera is all the way to heat -- but the right and left fan switches only blow cold air. ÃâIs there another button or switch we need to turn on? ÃâThanks so much. > >>> > >>> > >>>Jana (with ice cube feet) > >>>89pt40wb > >>>The Bird House is on the road! > >>>Still in South Dakota > >>> > >>>-- > >>>Blessed are the people whose God is the Lord. (Psalm 144:15) > >>> > >>> > >> > > > > > >-- > >Blessed are the people whose God is the Lord. (Psalm 144:15) > > > > > |
