Alternator Question??
06-11-2005, 09:02
A BAD SWITCH????? DAY IN RAINY JAX FLA 83 PT-40
06-11-2005, 09:58
I have a 1994 40'wb. When I have my alternator switch on the dash in
the middle position when starting the bus I read about 150 amps. But
when I turn the switch to alternator 1 or alternator 2 I the needle
does not move. It stays on `0'. What does this mean? The bus runs
great.
Thanks
Nelson Slinkman
Westminster, Maryland
06-11-2005, 10:42
--- In WanderlodgeForum@yahoogroups.com, "nslinkman"
> great.
> Thanks
> Nelson Slinkman
Don't understand your 150 amps but, you probably have one or more
relays that are bad or circuit breakers that are in the alternator
gauge circuit. Call Benny and have him send you the wiring diagram.
There are at least two circuit breakers that could be your problem
right after the shunt on the firewall. There are also 6 relays in the
inverter/battery compartment, right at the top left that control the
ammeter.
Moderator
06-11-2005, 12:55
i'm not so sure about that switch.i'm working on a 1990 wb and it has the
switch.i just replaced both alternators with new 160 amp leece-nevilles,the red
light stays on and the switch does the same as yours.i know the alt. are
working,i just don't know what powers the switch and the light.as long as the
alternators charge i'm not to worried about the switch. randydupree93wb
Sent: Saturday, June 11, 2005 5:58 PM
Subject: [WanderlodgeForum] Alternator Question??
great.
Thanks
Nelson Slinkman
Yahoo! Groups Links
06-11-2005, 13:07
ron,all 6 of those relays are for the amp meter?randydupree93wb
Sent: Saturday, June 11, 2005 6:42 PM
Subject: [WanderlodgeForum] Re: Alternator Question??
> great.
> Thanks
> Nelson Slinkman
ammeter.
Moderator
Yahoo! Groups Links
06-11-2005, 15:01
The six relays either control which alternator you are running or
the ammeter circuit. Could be both. I'm studying the wiring
diagram that Benny sent me.
Moderator
--- In WanderlodgeForum@yahoogroups.com, randydupree
> From: ronmarabito2002
dash in
amps. But
needle
runs
> > great.
> > Thanks
> > Nelson Slinkman
more
alternator
diagram.
problem
in the
> ammeter.
> Moderator
> Yahoo! Groups Links
of Service.
06-11-2005, 15:04
I believe that the switch and relays connect the gauge across either
one shunt or the other, bad relays would cause erratic readings and
are a cheap place to start.
- Jeff Miller
has the switch.i just replaced both alternators with new 160 amp
leece-nevilles,the red light stays on and the switch does the same as
yours.i know the alt. are working,i just don't know what powers the
switch and the light.as long as the alternators charge i'm not to
> From: nslinkman
in
But
needle
> great.
> Thanks
> Nelson Slinkman
> Yahoo! Groups Links
Service.
06-11-2005, 23:58
keep us advised please! the leece-neville alternators are a one wire set
up.meaning you don't need a wire to excite the unit.they use a ground wire,and
the main battery wire.when you rev the engine to 1000 rpm or so they self
excite.so,i'm thinking that those relays and switch will no longer do anything
for my bird.that switch and all that stuff is cool,but not really needed! i
never touch the switch in my 93 wb..randydupree93wb
Sent: Saturday, June 11, 2005 11:01 PM
Moderator
dash in
amps. But
needle
runs
> > great.
> > Thanks
> > Nelson Slinkman
more
alternator
diagram.
problem
in the
> ammeter.
> Moderator
> Yahoo! Groups Links
of Service.
Yahoo! Groups Links
06-12-2005, 13:10
Ron how many battery banks are there?
Tom
1982 FC35
Vernon
>Moderator
>dash in
>amps. But
>needle
>runs
> > > great.
> > > Thanks
> > > Nelson Slinkman
>more
>alternator
>diagram.
>problem
>in the
>the
> > ammeter.
> > Moderator
> > Yahoo! Groups Links
>of Service.
>Yahoo! Groups Links
06-12-2005, 13:30
There are two. 3 chassis and 8 house.
> Tom
> 1982 FC35
> Vernon >
> >Moderator
> >dash in
> >amps. But
> >needle
bus
> >runs
> > > > great.
> > > > Thanks
> > > > Nelson Slinkman
> >more
> >alternator
> >diagram.
> >problem
relays
> >in the
control
> >the
> > > ammeter.
> > > Moderator
> > > Yahoo! Groups Links
Terms
> >of Service.
> >Yahoo! Groups Links
