Shutting off the heat
05-29-2009, 03:15
There are 4 valves on the engine. One is low behind the bumber. Shut them all
off. You will not hurt anything. That will stop your heat.
--- In WanderlodgeForum@yahoogroups.com, "jburgessx2" wrote:
> Wayne,
> I have it set to summer but it still seems to poor the heat out. We are on
I-5 heading back to Port Hueneme and it was a hot one today. My wife set a
thermometer by her feet to check the temp - 105 degrees at the co-pilots seat
feet!!! My feet were at 87 degrees. I had the generator running with two of
the AC's going trying to cool it down. My dash AC doesn't work and I haven't
fixed it yet. I was hoping there was some way to turn the heat off at the
engine.
> I don't think the heat of the generator and the heat of the road could produce
105 degrees in the passengers seat but I could be wrong.
> Oh well, we will be home by noon tomorrow and I guess I can look into it
further. Maybe I have a stuck valve somewhere that isn't allowing the
winter/summer switch to work properly.
> Jerry
> 85 PT40
> --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila wrote:
> > There is a summer/winter rocker switch on the left side of the overhead dash
area, if it is set to summer the chassis heat system will be off.
> > Wayne
> > 1985 PT40
> > ________________________________
> > From: "amweatherly@"
> > To: WanderlodgeForum@yahoogroups.com
> > Sent: Thursday, May 28, 2009 4:38:27 PM
> > Subject: [WanderlodgeForum] Re: Shutting off the heat
> > --- In WanderlodgeForum@ yahoogroups. com, "jburgessx2"
> > > So, how do I shut the heat off in this 85 PT40? I've turned off all know
switches on dash and panels above. But, we are still getting heat out of the
vents. I'm guessing it's coming from the chassis heating system since all the
others are off. Surely their must be a valve to shut off somewhere. . .
> > > When it's 100 degrees outside I would rather not have any heat on. . .
> > > Jerry
> > > 85 PT40
> > Jerry,
> > There are four valves in the engine compartment. Two of which control the
pilot/copilot heat, the other two supply coolant to all the other
> > chassis heaters. My bluebook says three are located on the rear of the
engine and one is on the left bank, about 1/2 way up the side
> > of the engine. Never could find that one. I located the 4th one also in the
rear of the engine. Two are visible, two are down in front of the rear bumper,
practicly invisible. If all you want is to shut of heat, Ralph's post is a damn
sight easier
> > Art Weatherly
> > Riverside Ca.
> > '85 PT 36
05-29-2009, 13:03
Jerry:
As far as I know the winter summer switch supplies 12 volt power to the chassis heat thermostat to run the blowers at each of the heat exchangers and the switch also should supply power to the 12 volt solenoid coils on the water valve or valves that have to open to allow the heated antifreeze to flow thru the chassis heat exchangers and thru the pilot/copilot heat exchangers. I am assuming that when you turn the switch to winter and the ignition is on it energizes the coils and they open the water vaves. If this is how it works then if the switch is off that would indicate that a water valve is stuck and not closing when the coil is in the de-energized state.
Do you have the front heat switch on the lower dash switched to off?
Wayne
1985PT40
Sent: Friday, May 29, 2009 12:48:52 AM
Wayne,
I have it set to summer but it still seems to poor the heat out. We are on I-5 heading back to Port Hueneme and it was a hot one today. My wife set a thermometer by her feet to check the temp - 105 degrees at the co-pilots seat feet!!! My feet were at 87 degrees. I had the generator running with two of the AC's going trying to cool it down. My dash AC doesn't work and I haven't fixed it yet. I was hoping there was some way to turn the heat off at the engine.
I don't think the heat of the generator and the heat of the road could produce 105 degrees in the passengers seat but I could be wrong.
Oh well, we will be home by noon tomorrow and I guess I can look into it further. Maybe I have a stuck valve somewhere that isn't allowing the winter/summer switch to work properly.
Jerry
85 PT40
--- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila wrote:
> There is a summer/winter rocker switch on the left side of the overhead dash area, if it is set to summer the chassis heat system will be off.
> Wayne
> 1985 PT40
> ____________ _________ _________ __
> From: "amweatherly@ ..."
PT40? I've turned off all know switches on dash and panels above. But, we are still getting heat out of the vents. I'm guessing it's coming from the chassis heating system since all the others are off. Surely their must be a valve to shut off somewhere. . .
> > Jerry
> > 85 PT40
> Jerry,
> There are four valves in the engine compartment. Two of which control the pilot/copilot heat, the other two supply coolant to all the other
> chassis heaters. My bluebook says three are located on the rear of the engine and one is on the left bank, about 1/2 way up the side
> of the engine. Never could find that one. I located the 4th one also in the rear of the engine. Two are visible, two are down in front of the rear bumper, practicly invisible. If all you want is to shut of heat,
Ralph's post is a damn sight easier
> Art Weatherly
> Riverside Ca.
> '85 PT 36
05-29-2009, 13:16
Hi Shane:
If the water valves controlled by the 12 volt solenoids are not dirty and working properly you just have to turn your switch's off and you shouldn't get any heated antifreeze to the heat exchangers. All it takes is a little debris in the water valve and the diaphram won't close off the valve. On my PT40 with the switch's off all the heat is off.
Wayne
1985 PT40
Sent: Friday, May 29, 2009 8:21:34 AM
Hi Jerry,
Kelly and I had a good laugh this morning- at your expense of course- We couldn't figure ours out either and used to roast up front all summer. I finally realized that you have to shut off the 4 valves in the engine compartment to completely turn the heat off. Otherwise, the hot coolant seems to keep circulating- even with the summer/winter switch on summer and the front heat dash switch off. It sounds like others have clued you into this as well.
Shane Fedeli
85PT40
On the road in San Antonio
--- In "WanderlodgeForum%40yahoogroups.com", "jburgessx2" wrote:
> So, how do I shut the heat off in this 85 PT40? I've turned off all know switches on dash and panels above. But, we are still getting heat out of the vents. I'm guessing it's coming from the
> Jerry
> 85 PT40
05-29-2009, 15:46
Thanks to all - good advice and very good info. I've made it home and will take
the time to look into solenoids because I don't believe they are working.
I just turned the water valves off this morning before I got underway - boy was
the ride more pleasant with the 105 degree heat!!
Jerry
85 PT40
> Hi Shane:
> Wayne
> 1985 PT40
> From: sfedeli3 <sfedeli3@...>
> Hi Jerry,
> Shane Fedeli
> 85PT40
> > Jerry
> > 85 PT40
05-30-2009, 01:15
In my 94 pt the electric valve that closes the heat circulation path is normally
open. to close it requires 12 volts and consumes amp hours 24-7. What many call
a phantom load is simply that not realized. this valve was a phantom. One path
of engine coolant that can be kept functioning while the hear register path is
turned off is the water heater. that is why there are so many valves.
Greg
94ptca
take the time to look into solenoids because I don't believe they are working.
was the ride more pleasant with the 105 degree heat!!
> Jerry
> 85 PT40
> > Hi Shane:
> > Wayne
> > 1985 PT40
> > From: sfedeli3 <sfedeli3@>
> > Hi Jerry,
> > Shane Fedeli
> > 85PT40
> > > Jerry
> > > 85 PT40
06-01-2009, 10:38
Hi Wayne,
Not sure what is up with mine- may have to check and see what (if any) crud is
in the sporlans. Funny thing with my dash heat is that when you turn it "on" and
the booster pump runs- it does not get warm. If you leave the switch off, the
pump does not run, but the dash heater core gets toasty. Had to run the heat
last night coming back from TX- this global warming has really cooled things off
here in the northeast LOL. The heater cores under the sofa and in the hallway
work as they should- it's just the front one that gives me fits.
Shane Fedeli
85PT40
Hershey, PA
> Hi Shane:
> Wayne
> 1985 PT40
> Hi Jerry,
> Shane Fedeli
> 85PT40
> > Jerry
> > 85 PT40
06-01-2009, 16:14
Maybe it's an intermitent problem caused by a dirty sporlan water valve like you mentioned, or an intermitent electrical problem with the front heat switch on the dash or the electric solenoid that opens and close the water valve for your front heat exchangers.
I know what you mean about this so called global warming, we have been consistantly below normal temps. here in Mn. for 2 years now, it's June andwe still need a jacket much of the time.
Wayne
1985PT40
Sent: Monday, June 1, 2009 5:38:01 PM
Hi Wayne,
Not sure what is up with mine- may have to check and see what (if any) crud is in the sporlans. Funny thing with my dash heat is that when you turn it "on" and the booster pump runs- it does not get warm. If you leave the switch off, the pump does not run, but the dash heater core gets toasty. Had to run the heat last night coming back from TX- this global warming has really cooled things off here in the northeast LOL. The heater cores under the sofa and in the hallway work as they should- it's just the front one that gives me fits.
Shane Fedeli
85PT40
Hershey, PA
> Hi Shane:
> Wayne
> 1985 PT40
> From: sfedeli3 <sfedeli3@.. .>
> Hi Jerry,
> Shane Fedeli
> 85PT40
> > So, how do I shut the heat off in this 85 PT40? I've turned off all know switches on dash and panels above. But, we are still getting heat out of the vents. I'm guessing it's coming from the chassis heating system since all the others are off. Surely their must be a valve to shut off somewhere. . .
> > Jerry
> > 85 PT40
06-02-2009, 11:13
hey there , the sporlan valees dont control the front heat, just the chassis
heat, so if the dash heat is still gettin hot, you can shut off the gate valves
at the engine, 2 for front heat and 2 for chassis heat,2 are hard to find, stuck
down between the frame across the back and the engine, but there should be a a
valve at the steering wheel, I was trying to think, they uses a pull cable with
a chrome knob by the steering column,to shut off a valve but not sure what
years, you pushed it of pulled it, then they went to a slide heater control,and
the valve was under the coach behind the step, and the had some problems with
it too, you could clamp off the hose with needle nose vise grips under there too
06-02-2009, 13:25
Shhhh! We're calling it "climate change" now, so it can mean anything.
Warm temperatures, cold temperatures, no temperatures, who knows! All
I know is, this "carbon" stuff is really dangerous and somebody needs
to be taxed!
... and here I thought the hole in the ozone layer was supposed to
have killed us all by now. Why does there always have to be a
boogeyman?
Oh, yeah. Forgot this is a Wanderlodge forum. Uh, clean the sporlans,
or something... ok? Great. ;-)
-Ryan
'86 PT-40 8V92, 2003 Hummer H2, clearly not buying any of this B.S....
> and we still need a jacket much of the time.
> Wayne
> 1985PT40
06-02-2009, 13:27
If there is no solenoid operated water valve for the front heat then what is the point of the front heat switch on the dash? Therehavea left and a right front heater blower switchs to turn either side to high/low or off
Sent: Tuesday, June 2, 2009 6:13:12 PM
hey there , the sporlan valees dont control the front heat, just the chassis heat, so if the dash heat is still gettin hot, you can shut off the gate valves at the engine, 2 for front heat and 2 for chassis heat,2 are hard to find, stuck down between the frame across the back and the engine, but there should be a a valve at the steering wheel, I was trying to think, they uses a pull cable with a chrome knob by the steering column,to shut off a valve but not sure what years, you pushed it of pulled it, then they went to a slide heater control,and the valve was under the coach behind the step, and the had some problems with it too, you could clamp off the hose with needle nose vise grips under there too
