Water in fuel alarm
06-09-2005, 22:34
Water in fuel alarm
Hi Scott,
The Racor has a water in fuel sensor in the bowl at the bottom of the filter.
Bill & Rita in Roanoke, VA
1987 FC-35
06-10-2005, 01:53
Water in fuel alarm
While in the overhead chasing the spot/flood issues I noticed that the
water in fuel alarm had been cut by someone...so I just crimped the
WHITE wire back together..FIXED..HMM WRONG..turn on the ignition and
low and behold it starts going off..The sender is it in the fuel filter
or in the fuel tank??
TIA
Scott
86FC35 "Ruby"
SC
06-10-2005, 10:07
Water in fuel alarm
Scott,
I have 2 "water in fuel" alarms. The one for the Racor
says "water in filter" and is located near the Racor gauge.
The one on the dash says "water in fuel". The sender for
that I remember Jeff Miller telling someone else was in the
fuel tank.
I have 2 sensors at the front end of my tank. Jeff said
the top sensor is for the "low fuel" light and the lower one
is for "water in fuel".
As always, you should probably open the drain valve and
drain a gallon or so out to be sure it's not an actual alert. ;o)
George Witt
81 FC 35
Lincoln, Nebraska
filter
> TIA
> Scott
> 86FC35 "Ruby"
> SC
