Towbar Baseplate Problem
12-09-2008, 11:32
This is a reminder for everyone to check their towbar system on a regular
basis,
especially the baseplate where it bolts to the tow car frame. After returning
from a trip
this past weekend the front of my wife's 2003 Jeep Liberty literally fell off!
Luckily it
happened within 1 block of where I park the bird.
Studying the Blue Ox towbar system, which has been on for over 3 years, I see
a
possible design flaw in the baseplate system. The baseplate itself has 3/8inch
holes and
calls for 3/8 inch bolts to go into the frame, which mine had. But the frame on
the Jeep
Liberty is a unibody type, very thin stamped steel, with 1/2inch holes. Looking
closely at
the Jeep frame the 1/2inch holes are now very elongated from the bigger hole
size and
movement related to 3 years/20,000 miles. The bolts on one side of the baseplate
came
completely out causing the towbar frame to pull the front end of the Jeep off
and causing
the Jeep to swerve to one side. Again, luckily all this happened at 10mph and
within 1
block of my parking spot. Another disturbing discovery is the 10,000 lb safety
cables do
nothing in this case to prevent a runaway vehicle as they are attached to the
same
baseplate.
So, this is a reminder to everyone to check your baseplate bolts for
tightness on
whatever vehicle you might tow.....and if you tow a Jeep Liberty.....check the
bolts and
bolt holes immediately.
Rick Archie
85PT40 "Fort R"
Fort Worth
12-09-2008, 11:44
Rick:
All current Blue Ox bas plates call for cables to be attached from the
frame to the baseplate.
Bruce
1988FC35
12-09-2008, 11:50
Rick,
My 1995 jeep Blue Ox did the same thing, except I discovered it a
little sooner. I ended up making backing plates out of heavy angle
iron with nuts welded to them. I was able to insert them through the
front of the frame. So far it has held well, but I do check regularly.
I put some pictures up on the old wanderlodge forum I think. I will
check. It might have been on this forum.
Gardner
--- In WanderlodgeForum@yahoogroups.com, "Rick A."
a regular basis,
After returning from a trip
literally fell off! Luckily it
years, I see a
has 3/8inch holes and
the frame on the Jeep
holes. Looking closely at
bigger hole size and
the baseplate came
the Jeep off and causing
10mph and within 1
10,000 lb safety cables do
attached to the same
> baseplate.
for tightness on
Liberty.....check the bolts and
> Rick Archie
> 85PT40 "Fort R"
> Fort Worth
12-09-2008, 12:04
Rick,
Try this URL. It has some pictures of what I did. These just show
the basic idea. It is in the WanderLodge Owners Group Forum.
http://www.wanderlodgeownersgroup.com/fo...hread.php?
t=829&highlight=blue+elongated
Gardner
1983 FC 35
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> Rick,
regularly.
will
> Gardner
on
> a regular basis,
3
> years, I see a
itself
But
of
> the baseplate came
at
> 10mph and within 1
> > baseplate.
bolts
> for tightness on
> > Rick Archie
> > 85PT40 "Fort R"
> > Fort Worth
12-09-2008, 12:53
> front of the frame.
I thought all the Blue Ox base plates came with backing plates for
added support inside the frame rail? I know my two units did for my
1995 and 2005 Jeep GC.
By the way, I have a Blue Ox base plate for a 95-98(?) Jeep GC if
anyone needs one. (with backing plates)
1991 WB40 "Texas Minivan"
> Rick,
regularly.
will
> Gardner
> a regular basis,
3
> years, I see a
> the baseplate came
at
> 10mph and within 1
> > baseplate.
bolts
> for tightness on
> > Rick Archie
> > 85PT40 "Fort R"
> > Fort Worth
12-09-2008, 13:47
Mike,
I know that mine did not have any backing plates supplied.
Gardner Yeaw
83FC35
> > front of the frame.
my
> Mike Bulriss
> San Antonio, TX
> > Rick,
a
angle
> regularly.
> will
> > Gardner
on
> > a regular basis,
over
> 3
> > years, I see a
itself
But
1/2inch
of
> > the baseplate came
of
happened
> at
> > 10mph and within 1
> > > baseplate.
> bolts
> > for tightness on
> > > Rick Archie
> > > 85PT40 "Fort R"
> > > Fort Worth
12-09-2008, 14:06
Rick,
Thanks for the heads-up. I tow a 2006 Honda Pilot. The Honda's
have had a history of baseplate issues. Thanks for the reminder to
go out and check it again.
Another parameter which can really put a lot of strain on the
baseplate is the angle of the tow bar. It should be as close to
level as possible. If it's not, the bar can transmit tons of force
into the baseplate.
David Brady
'02 LXi, NC
> regular basis,
> years, I see a
> 3/8inch holes and
> frame on the Jeep
> baseplate came
> 10mph and within 1
> lb safety cables do
> to the same
> baseplate.
> tightness on
> Rick Archie
> 85PT40 "Fort R"
> Fort Worth
> Checked by AVG.
> Version: 7.5.552 / Virus Database: 270.9.15/1838 - Release Date: 12/8/2008
6:16 PM
12-09-2008, 15:19
Sorry to hear about the base plate. Glad no one was hurt.
regular basis,
years, I see a
the baseplate came
10mph and within 1
lb safety cables do
> baseplate.
for tightness on
> Rick Archie
> 85PT40 "Fort R"
> Fort Worth
12-09-2008, 15:23
Rick If you look at blue ox liberty 2005there is a design change over the two bolt per side arangement on your 2003 unit.If the jeep uniframe remained the same during that model year change,, could be that the loose bace plate situation proved typical and the newer design was a correction.
the third hole per side on o5 blueox does not line up to a uniframe hole. in 05 you bolt the platewith the Jeep 2 holes(as in 03?) then drill an exact third hole in the frame. I think the 3rd hole exact lineup keepsthe ox from shifting and rotating the bolts lose.
grade 5 and 8 bolts differ in strength but they also differ in character. stronger grade 8 snapunder stress that would twist and bend grade 5a bit. I try and mix up 5 and 8's when mounting crap in vaurnarable positions. leaves you with strength and flexability. I say thisbecause everyone goes for 8's as an assumed added protection costing only $0.70 per the bolt. ..must be a reason grade 5 was the choice for this application by ox engineeres.?????
flex is built into the unibody frames. that is why the cross bar is necessary between the docking points for the pins. prob with overbuilding a repair is loosing jeep designed flex. all stress is then transfered toan eventual crack .
GregoryO'Connor ofTim&Greg
94ptca
