Perplies W/D Drain Trap Upgrade
10-12-2008, 14:38
Eric,
I named this upgrade after your post last week about adding a small
hose that you can add water to the W/D drain trap.
I rerouted the water from the air flush system for winterizing into
the water pump / tool box bay. I use ¼ poly tubing and quick connect
fittings, air line type hardware. A small thumb screw valve to open
and close the flow then routed it back into the water tank bay then
up into the W/D closet. I then fashioned a elbow and attached the
hose to a 90 degree quick connect that is screwed into the new elbows
and pipe vent that I worked up.
I works great. I've posted some photos
Thanks for the idea.
Kurt Horvath
95 PT 42
10AC
